Hi guys...
Just wanted you to know about the new Corsair VS1GB400C3 modules.
Here they are, Samsung UCCC ICs, BrainPower D6800 PCB (only diffenrence from the B6U808 being the module's height):
They are rated CAS 3, with default SPD settings of CAS 3, RAS to CAS 3, RAS Precharge 3, Min RAS Active 8 (in short: 3-3-3-8). Here's for some short OC tests. All below screenies are done using the Abit AN8 and a voltage of 2.8V (adjusted DDR Ref. Voltage to -30mV) + crappy Venice 3200+ (sorry, had nothing else on hand at the time of testing).
Memtest86+ #5 & #8 stable @ 260 MHz 3-4-3-7 1T (Read to Write Delay is 2) - notice the high bandwidth at only 2600 MHz (over 3500 MB/s):
SPI 32M stable:
A64Tweaker & SPD Screen:
CPU-Z Validation: here.
Forgot to mention: Memtest was done with Winnie 3200+ and SPI test with a Venice 3200+ (board having problems with reporting CPU temp in Winchester's case - causes shutdown when I stress the CPU, so I had to use Venice for the SPI test)...
I realy think it's a screaming result for a value memory... especialy if it can compete (frequency wise) with G.Skill's and OCZ's 2GB kits.![]()
