My silent rig![]()
My silent rig![]()
Live to Mod.. Mod to Live!
It looks so well
I love that nf4 home-made chipset cooler![]()
Nicely done.... I have an HTPC something like this but I had to cut the voltage to the 939 chip and drop the multi to keep it cool enough in a tight little case...
"Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
BOYCOTT MIR's
If you are cooling the rig in your sig totally fanless i am really impressed . Very nice job.
BTW , i liked the UTT cooler![]()
E6600@3.3Ghz
P5B-Dlx ( 0711 bios )
BBA X1900XTX
4x512 Corsair 5400UL
"They couldn't hit an elephant at
this distance" (last words of Gen.
John Sedgwick, Spotsylvania 1864) "
nicely done![]()
System #1:
i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6X58 Premium, 3x2048 Corsair Dominator 2000CL7, Sapphire 5970 @ stock, Corsair HX1000, 1xOCZ Vertex2 120GB, 3x1TB WD Green
Cooled by:
Loop 1: Watercool HK rev 3.0, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
Loop 2: EK 5970 Nickle, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Phobya Fans @ 5V Pull
Loop 3: EK Asus NB/SB, Mips Asus Mosfet 1 + 2, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.2 /w Phobya Fans @ 5V Pull
4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
http://img402.imageshack.us/img402/1251/83962063.jpg
AMD @ testing
X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
nice ideas
- DFI nF4 Ultra-D
- 344FSB@1,6V 1029HTT BUS
- OCZ PC4000 VX 1,5 2 2 6@DDR500 3,1V
- Venice3000+ 1,47V@2920MHz
CPU max 55deg C
GPU max 80deg C (non OC`ed X800XL)
Chipset max 45deg C
RAM max 55deg C @3,5V (tested for purpose)
RAM MOSFET max 60deg C (w/4V enable)
Mainboard max 50deg C
HD 1 max 55deg C
HD 2 max 50deg C (zalmancooler)
All stresstest except for GPU was run in 20deg C ambient and case closed (Prime95). All test`s run at very high clocks and voltage
The GPU was stressed with ATI Tool
Still enhancing my cooler.. Also solved the problem with high temps on the powercuircut for the memory (4V jumper). The copper heatbridge takes care of that
Attached
Applied LOTS of pressure and thermalpaste before tightening the bolts
impressive..
now the only noise you have is the harddrives and the optical drive.. which i assume you have padded.
Originally Posted by nn_step
Very well done. Really imnpressive!
I plan on using a RAM-heatsink similar to your design. I'm still in the first developing stage (need to do some Autocad schematics). I'm going to make my version a little more flexible than yours, though.
BTW, further improvements to your already great setup could also be:
-using thicker copper for you mosfet heat bridge
-using some copper on the heatpipe base that contacts the GPU-core
-using a Thermaltake Sonic Tower heatsink instead of the Asetek
I know your setup is already outstanding. The above stated improvements are not meant as disrespect. I only would like to help you make it even better.
No, I dont see your tips as disrespectOriginally Posted by celemine1Gig
I agree on the heatbridge beeing a litle weak, but I didnt have thicker copper at the time beeing when I made the bridge. Will replace it when I find som thicker.
But your tip on the sonic tower I would not follow, the Asetek Micro beats the sonic fairly easy.![]()
The GPU will get a new cooler, the thermalright V1 in a ducting system. (More to come)
Really? I haven't heard this, is there a review your could direct me to.Originally Posted by ArcticOC
Edit: BTW your cooling system is really impressive.![]()
Yeah, I honestly don't know for sure which one is better, but what I know is that once using it actvely cooled, the Sonic Tower beats the Vapochill Micro. Anyway, who cares. 55°C full load temp is very good already considering it's passively cooled.Originally Posted by ArcticOC
As I already said, really impressive stuff there.Great results. I would only be a bit worried about the mobo temp of 74°C, or is this reading incorrect?
The PWM area is actually fine at that temperature. It won't facilitate a mega-OC, but they'll certainly work at those temps.
Originally Posted by Vapor
The PWM area is always warmer than than the rest of the moterboard, 74 is a bit high I agree, but I have most recently made some modifications that dropped this temp. about 5-6deg.C
I`m aiming to get the temperature down to 65deg.C @full load, this is a 24/7 safe solution![]()
Man, you are insane! You did a fantastic job in there. Congratulations!
*update* I see your location now. Its the advantage of living near the north pole....
Testing Rig
Lian Li PC-S80
Enermax Liberty 620W
Asus P5K
Conroe E6600
2Gb OCZ PC8500 - @650 Club
BFG 8800GTS 320Mb
2xSamsung 80Gb SATA II Raid 0
1xSeagate 320Gb SATA II 16Mb
Pioneer DVR 110-D
Water Cooled (MCP655-Storm-Maze4gpu-BIX-1/2tubing)
Yea, really nice results. Something I'm wondering is did u put the mosfets chips on with AS ceramique or the thermal tape. If u wanna get really into this, try cutting a 120mm hole into the bottom of the PSU, and getting a different fan and duct. May make it a little quieter and cool a little better.
The small sinks at various places on the mainboard is mounted with regular super glue. Works wondersOriginally Posted by moddolicous
The PSU is alredy modded with a Pabst 120mm 16db fan!
Ductet some air to the PWM area, and now the mainboard temp. is about 58deg C @ full load
The system is almost non-audible
Please show/tell more about that chipset heatsink. I'm in love.
ebay under aws983s, heatware under Mr. Tinker.
very nice, excellent job - ill chuck in my 2 cents tho...
gpu is a lil hot - fit a heatsink to the rear of gpu. check the link out - its the standard sink that came with my 5200, and i put a cpu sink on the front. if u cut the rear ramsink a little, so you can fit a sink on the rear of your gpu it would help.
http://www.alphalink.com.au/~vincenzo/other/FX52002.JPG
i used two fibre washers in the corners to stop heatsink shorting everything out and heaps of silicon paste to fill the gap. im using an old intel cpu heatsink on the back of my cpu also. the socket temperature stays near ambient, and the cpu gets lowered a few degrees because you aren't cooling the cpu's pins directly. i should try filling my socket with silicon paste.
Very nice, ArcticOC.
But there is a fan in the PSU, so it's not completely passive.
Mine is completely passive and diskless.
This is for SETI@home only.
So, its OS is FreeBSD without X.
I have an i-RAM, but I can't use it until LANPARTY UT NF4 SLI-DR Expert comes![]()
DFI LANPARTY UT P35-T2R (2007/11/07 BIOS)
Intel Core2 Quad Q6600 L724A786
2x Team Xtreem DDR2 667MHz CL 3-3-3-8 1GB
SILVERSTONE ST56ZF 560W Fan Removed
ATI XPERT 98 PCI
GIGABYTE i-RAM
where the fark did u get that heatsink??? what does it weigh 10, 15 kg?? i had to make my subwoofer's 5kg sink which is less than half as big as your cpu sink because i couldnt find any bigger than 1 kg!! where's that ps from aswell???
