Page 1 of 8 1234 ... LastLast
Results 1 to 25 of 185
Thread: Calculating the key OC points on the 7800
Hybrid View
    Feb 2005
    Minnesota, USA
    After some testing, the best points on the core clock of the nVidia 7800 series cards are whole multiples of the core frequency oscillation of 27 MHz. That calculates to the following root core clocks:
    (17 x 27) - 40 = 419
    (18 x 27) - 40 = 446
    (19 x 27) - 40 = 473
    (20 x 27) - 40 = 500
    (21 x 27) - 40 = 527
    (22 x 27) - 40 = 554
    (23 x 27) - 40 = 581
    And, here is how a single MHz below the whole number threshold affects 3Dmark05 scores:
    445 8052
    446 8222
    472 8404
    473 8508
    499 8669
    500 8753
    Now, what about the other two cores. How are those controlled?
    Well, when you adjust the root clock, you actually adjust all three clocks.
    The root clock gets bumped by 40 MHz to represent the real geometry or vertex core clock. So, lets pick 450 core, which so many vendors use. 486 is the best vertex clock value (18*27), which translates to 446 root (486-40). So, we would actually have 490 using a 450 root clock, a 4 Mhz pad on the required frequency.
    But, the shader and ROP cores start at 415 (really 418.5) in low power, and jump in whole frequency values (ie, 17 x 27 = 459) to a value that is less than 13.5 MHz over or equal to the root frequency. In this case the root frequency is 450 which is 18 MHz over 432 (16 x 27) and 9 MHz shy of 459 (17x 27), so 459 is the ROP/Shader clock.
    So, a little confusing, but you do have some control over the other two clocks.
    So, here is a list of primary - vertex based (red) and secondary - ROP and shader based (blue) root clock OC targets. The red will yield the larger gain, and you will see a second, albeit smaller gain on the blue clocks where the optimal memory frequency matches the root clock.
    419
    432 - the nVidia spec root clock
    446 - so many vendors use 450
    459 - why BFG uses 460
    473
    486 - why eVGA, XFX, and BFG use 490 on limited cards
    500
    513
    527
    540 - How I got 9539 on 3DMark05 with a lowly 3200+ and one 7800 GTX
    554
    567
    581
    594
    608
    621
    Dec 2003
    Nice work. Just like the GTX, it has the "stepping" type of o/c.
    The Blue Dolphin
    Nov 2004
    The Netherlands
    At 447 the score will be lower then at 446?
    Blue Dolphin Reviews & Guides
    Blue Reviews:
    Gigabyte G-Power PRO CPU cooler
    Vantec Nexstar 3.5" external HDD enclosure
    Gigabyte Poseidon 310 case
    Blue Guides:
    Fixing a GFX BIOS checksum yourself
    98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
    Feb 2005
    Minnesota, USA
    Quote Originally Posted by alexio
    No, you will actually gain a little, but is it pretty flat. You get marginal gains as you bump the clocks, but, when you hit the integer value of the 27 MHz oscillation, you get a significant step in performance. That is what I was trying to illustrate with the single MHz bump.
    Quote Originally Posted by Ackbar
    Looking at my clocks... I can't seem to actually reach 473+ unless I hit 475 on the clocks, then it hits 473+ on RivaTuner monitoring. Something to keep in mind. I think this is why Anandtech and others have seen a jump at "475" which is erroneously reported and is actually 473.
    Yes, Coolbits is always been off a MHz or two. RivaTuner is more accurate. And, you can also use the newer version of ATI Tool for nVidia cards (0.25 beta 2 and up). That is also more accurate, and, you can get a temp monitor for your video temps in Motherboard monitor. It is kind of cool.
    Quote Originally Posted by Kunaak
    I can confirm for a fact this worked for me.
    great method for finding the absolute best OC Speeds.
    Thanks, I thought is was a very handy discovery. It finally explains the strange jumps people had been referring to. And, as an FYI, Rivatuner 15.7 will address the multiple core frequency detection. So, you get to see all three cores in action.
    Sep 2004
    Brazil
    Asus Extreme is clocked at 486Mhz .....now i know where these number came from
    E6600@3.3Ghz
    P5B-Dlx ( 0711 bios )
    BBA X1900XTX
    4x512 Corsair 5400UL
    "They couldn't hit an elephant at
    this distance" (last words of Gen.
    John Sedgwick, Spotsylvania 1864) "
    I am Xtreme
    Jan 2005
    well I have to say, impressive.
    How long did it take you to find this out
    silver wall jumper X
    Apr 2005
    Las Vegas
    no - not unless the actual core clock remains the same
    Jan 2005
    DFI nF4 Ultra-D
    1 GB of OCZ PC3700EL Platinum TCCD
    AMD 3500+ Clawhammer (XP-120)
    eVGA 6200 -> 6600 softmod
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    excellent work there.
    I'll make it a sticky so others can use this for sometime
    Sep 2004
    Fantasia
    Anandtech found that the "plateaus" occur at different speeds on the GTX than on the GT.
    http://www.anandtech.com/video/showdoc.aspx?i=2519&p=3
    May 2004
    Above and Beyond The Call of Duty-----Thanks!!
    Feb 2005
    Minnesota, USA
    Quote Originally Posted by Mr. Tinker
    I am glad to see it help people out. I have e-mailed the Anandtech video review folks the findings as well. Have to figure out the GT anomally, however.
    The Anandtech findings are interesting. I saw some strange things with the reported clocks on some GT RivaTuner reports. Assuming 27 Mhz is the same oscillation value for the GT. The true base clock of the GT would be 405, not the reported 400. So, when you overclock the card to 478, which is 78 MHz above the reported clock, you are possibly off by 5 Mhz, and actually at 473 (478 is 73 MHz above the REAL clock). Maybe the BIOS games the reported clock. That is why the OC GT's are at 425 and 445 versus 430 and 450 in the GTX world.
    Here is a RivaTuner output:
    This is for a BFG GT OC. The stock clock is 425, and the geometric delta clock is supposed to be 40 MHz. So, why does it appear to bump 47 MHz? The real clock of the GT may be 432, not 425. That could explain the jump to 472 from 425. A 47 MHz bump instead of the expected 40.
    So, it is possible all GT reported clocks are under by 5 MHz less than what you see in CoolBits. I will verify all this info on a follow up.
    QX6700 @ 4.0 Ghz - EVGA 680i - 4 GB DDR2-1066 (4-4-4-10) - 8800 GTX SLI - 2 x 150 GB RaptorX RAID 0 - Seagate 500 GB - DVD-RW-DL - Realpower Pro 1000W - Vapochill LS - Dell 3007
    Q6600 G0 @ 3.6 GHz - EVGA 680i - 2 GB DDR2-1000 - 8800 GTX - Seagate 500 GB - DVD-RW-DL - Enermax 1000W - Swiftech Loop - Dell 3007
    E6850 G0 @ 3.6 GHz - EVGA 680i - 2 GB DDR2-800 - 8600 GTS - Seagate 250 GB - DVD-RW-DL - 700 W - ThermalRight SI 128 - Dell 2007
    Jan 2005
    Oxford, UK
    i got a big jump at 474 mhz over 472...so something seemed to be happening there.
    And this is great work, thanks a lot. very good indeed.
    Conroe E6300 ES
    2x1gb Ballistix PC8000
    Asus P5W DH Deluxe (1705)
    Manli Geforce 7950GT 512mb
    Hiper Type-R 480w
    Samsung SP250
    "What did the quantam duck say?" "Quark Quark"
    Apr 2004
    Estonia, Mafia land.
    What i dont seem to understand is how noone is getting the mem higher then me on air .... i got my memory to run at 1750MHz... core was 633 but i had a ovp on at 1.6v
    Follow me @ www.youtube.com/user/HousedanceTanL
    • Intelฎ Core i7 920 2,66GHz "SLBEJ 3912B351" D0 - OC 5.11GHz 1.525v
    • ATI Radeon HD5970 XFX Black Edition 2Gb GDDR5 (Max OC ..\..)
    • 12Gb 2x6Gb 3x2Gb A-Data PC12800 DDR3 1882MHz CAS 7-6-6-16 1T 2.2v
    • Gigabyte X58-Expert SLI\CF with BCLK MOD! 240MHz
    • 1050W Enermax Revolution
    • 3Tb 3x1Tb RAID 0 Samsung F3 HD103SJ 7200rpm, 32Mb, Sata II
    • Monitor Samsung 52" LE-52A567P2W (2008.a) - 1920x1080p FullHD
    • Silverstone Raven II + 1x120mm fan@5v and 3x180mm fan@7v
    3DMark 2001 - 100,001p
    3DMark 2003 - 110,000p
    3DMark 2005 - 40,000p
    3DMark 2006 - 30,337p
    May 2004
    Sherbrooke, Quebec, Canada
    So, here is a list of primary - vertex based (red) and secondary - ROP and shader based (blue) root clock OC targets. The red will yield the larger gain, and you will see a second, albeit smaller gain on the blue clocks.... 554
    So that's why my card is blocked at 553Mhz
    Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
    2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
    *** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
    Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
    Sep 2004
    Fantasia
    I just want to know what the plateaus are on GT's so I know what to shoot for.
    ebay under aws983s, heatware under Mr. Tinker.
    Aug 2004
    They are the same as the 7800 GTX, but off by 5 Mhz, it appears. I suspect it has to do with losing 1/6th of the pipes. But, instead of 473, it is now 478.
    MSI K8N Diamond
    2 x 6800 Ultra PCI-E
    Innovatek NV40
    AMD 64 3200+
  18. #18
    Sep 2004
    Fantasia
    Quote Originally Posted by dwwalker14335
    so look at the gtx plateaus, and add 5 mhz. Werd. thx.
  19. #19
    May 2005
    Rye, Ny
    very nice work this will help me alot thank you
  20. #20
    pepsi fiend
    Jun 2005
    La Verne, ca
    if i saw this sooner it would have sped up my gt purchase quite a bit lol. invaluable info.
    Lanparty Ultra-D DEAD|REVIVED
    X2 3800+ LDBHE 0606 EPMW 2950 @ 1.55v DEAD|STILL DEAD
    Powercolor X1900XT 725/873
    dell 2005fpw 20.1''
    Quote Originally Posted by afireinside
    "uh yeah is this DFI RMA dpt? yeah I was setting up your ultra-d motherboard last night and the pwm shot a flame at me... can you give me a new one?"
    Quote Originally Posted by Mr. Popo
    if you wont eat all of your vegetables einCe will come and get you!
  21. #21
    Banned
    Jun 2003
    Broomfield, CO
    To me it looks like the ROP and shader run in multipliers ONLY while the geo domain is floating at whole numbers plus the delta (and easy way to get more power via BIOS mods). As long as the geo value is not more than one half of the base frequency from the ROP/shader value (0.5 x 17 = 13.5Mhz). Therefore if you get shader/ROP corruption at the next step value but you know the core can handle more geometric strain just edit the BIOS to get a larger delta (+50 like Asus? + 60? +100?). It would be interesting to see the 3DMark05 before and after scores for this....
  22. #22
    Xtreme X.I.P.
    Nov 2002
    Shipai
    so the delta can be edited in the bios?
    what about the base clockspeed of 27mhz?
    (pretty much the synonym for a cpu multiplier)
    can it be changed?
    maybe with a hardware mod?
    afaik all cards work like this but use a much lower base clockspeed than 27mhz, i wonder why nvidia went for this high base clockspeed
  23. #23
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Quote Originally Posted by saaya
    can it be changed?
    Look at the crystal on the board... ...same reason the x800xl doesn't clock worth a damn.
    Yes you can edit the delta in bios.
  24. #24
    XS News
    Aug 2004
    Sweden
    Some companys is giving out new GT bios with no delta clocks.
    Dont really know why.
    Everything extra is bad!
  25. #25
    Feb 2005
    Minnesota, USA
    Quote Originally Posted by Ubermann
    The BFG GT uses no delta, as well. eVGA brought that new BIOS out to deal with artifacts occuring on the GTs. Bit of a marketing trick, really. GTX at 460 or GT at 425 when it is really GTX at 500 or GT at 425. The quad yields are good, so the lower clocking GPU's get the laser and made into GT cards. So, many GT people are claiming clocks like 475 to compare against GTX OC results of 475, and the two are very different. Depends on the BIOS delta. Apples and oranges.
