08-12-2005, 06:31 AM
#1
Xtreme Workhorse
Article: 7800GT OCing peculiarities and unlocking
As it was reported earlier the G70 core has two frequencies - the ROPs frequency is higher than core`s for 30 MHz. But how will it scale during OCing ? Guys from Hardware.fr have made some investigation. And this is what they got :
The first column shows the core speed as you can see it in any hardware utility like RivaTuner. the second is the Pixel pipelines frequency. And the third - vertex processor units frequency. As you see the numbers differs. This leads to some sort of usefull OCing steps which can be ilustrated by this graph (for GTX version)
Unlocking the missing quad of pipelines is another story. Overclockers.ru reports that HKEPC (and IMO other lucky guys) could unlock their`s GTs cos it was engeneering samples, which won`t come to market. So only the actual owners of 7800GT will proove (or dispel) this.
08-12-2005, 11:42 AM
#2
The two frequencies part doesn't seem much different than the 7800GTX.
If they cards DO unlock, then they'll be the where everyone goes.
__________________
Currently building my i7 920 rig
i7 920 - Gigabyte x58-UD3R - 6GB Corsair DDR 1600
GTX285 - Intel X25-M + 1.2TB - Watercooled
08-12-2005, 12:22 PM
#3
Xtreme Workhorse
It`s common for all G70 cards
08-12-2005, 12:40 PM
#4
what's an average overclock on air then?
I'll be getting one of these cards, just waiting for a slight price drop.
__________________
Conroe E6300 ES
2x1gb Ballistix PC8000
Asus P5W DH Deluxe (1705)
Manli Geforce 7950GT 512mb
Hiper Type-R 480w
Samsung SP250
"What did the quantam duck say?" "Quark Quark"
08-12-2005, 04:15 PM
#5
Really is fairly confusing. Can't wait til the new version of RivaTuner comes out with support for the additional clocks.
__________________
DFI LANParty DK 790FX-B
Phenom II X4 940 BE (0849APMW) @ 3.6GHz (18x200) w/1.48v
-cooling: Scythe Mugen 2 + AC MX-2
BFG GeForce 8800GTX OC2
8GB PC2-6400 G.Skill @ 800MHz (1:2) 5-5-5-15 w/1.8v
Seagate 1TB 7200.11 Barracuda
Corsair HX620W
Support PC gaming. Don't pirate games.
08-13-2005, 01:49 AM
#6
There are actually more than two clocks inside G70 - there are many clocks and at least three clock derivatives, and you will not be able to unlock these cards AFAIK.
G70 is much the same as NV43 A4 revision and NV41 silicon - there's some sort of protection (either in the drivers, or in the silicon) that cannot be bypassed by NVStrap or a BIOS modification.
__________________
Tim Smalley @ bit-tech
08-13-2005, 02:00 AM
#7
Interesting... has anyone looked into it specifically to figure out what the actual cause of the protection might be?
The pipes don't seem to matter very much, just the clocks. There are some articles with engineering sample cards that were unlocked and producing similar numbers. Only clocking to GTX speeds seems to have a dramatic effect.
__________________
DFI nF4 Ultra-D
1 GB of OCZ PC3700EL Platinum TCCD
AMD 3500+ Clawhammer (XP-120)
eVGA 6200 -> 6600 softmod
08-13-2005, 07:53 PM
#8
Tried unlocking with the current RivaTuner, altough it said 24x1,8x1 under the NVStrap, it seems like it didn't apply it. Maybe later version will be able to do it.
__________________
Main: i7 920 D0 @ 4.20GHz, GIGABYTE EX58-UD5
3x2GB OCZ Reaper 1866, Sapphire 4870x2 2GB
3x30GB OCZ Vertex RAID-0, Corsair CMPSU-850TX
Swiftech Apogee GTZ, MCP355, MCR220
Server: Phenom II X4 940BE @ 3.60GHz, GIGABYTE MA790X-UD4P
2X2GB OCZ Platinum 1066, HIS HD2600XT 256MB
1TB WD Caviar Black, 2x1.5TB Seagate Barracuda, SilverStone ST50EF
Media: Phenom II X4 940BE @ 3.50GHz, Biostar TA790GX XE
2X2GB Kingston HyperX T1 1066, VisionTek HD4850 512MB
1TB WD Caviar Black, SilverStone ST400
08-13-2005, 11:17 PM
#9
unwinder (the rivatuner maker) said that it doesn't apear unlockable, as yet.
__________________
Conroe E6300 ES
Hiper Type-R 480w
Samsung SP250
08-14-2005, 01:34 AM
#10
What do you mean it seems like it didn't apply? I didn't think that anyone else could even get it to work under the NVStrap.
__________________
DFI nF4 Ultra-D
08-14-2005, 02:31 AM
#11
I mean I installed NVStrap, goto the pixel/vertex units configuration and select custom, then change the disabled units to enable. After that's done, it showed under NVStrap that I selected the 24x1 and 8x1 configuration, but after reboot, it still shows 20x1 7x1 under main menu of RivaTuner and benchmark shows the same performance results.
__________________
08-14-2005, 02:40 AM
#12
Ahh... that's the same as what others say. Do you have to reboot to get it to work?
__________________
DFI nF4 Ultra-D
08-16-2005, 09:28 PM
#13
Yes, it asks you to reboot after making the change to the masks.
__________________
08-26-2005, 06:42 AM
#14
Thanks for the great info Cooper.
I have a new PNY 7800GT that clocked fine on standard volts from 400 to 504 at the core (so I'm guessing the other pixel clock speeds were much higher as your chart indicates.)
I'm very pleased with a 104Mhz overclock, but my temp probe shows that highest GPU temps are only 111F/43.8C.
This leads me to believe I've plenty of headroom for overclocking yet, and just need to get more volts to the GPU.
Anyone here know of a volt mod for the 7800GT GPU? I've asked this on a couple other threads, no answers yet....
__________________
Latest: Asus K8n4-e Delux, Mobile 3400 with 1 Mg cache, 754 PCI-E goodness, 7800GT. Four other AMD rigs and a Dell notebook.
08-26-2005, 08:14 AM
#15
Xtreme Workhorse
zippyc maybe you could overvolt the core with nibitor - softvoltmod ?
I`m trying to overvolt mine 6800 for 0.1 V. It`s actually very easy. Just remeber to save your curent BIOS if something goes wrong.
08-26-2005, 09:28 AM
#16
Holy... that's a really nice overclock for a 7800GT! I can only get to ~475/1200. I noticed that the memory bandwidth is really key though. I think I was lucky to get a card that does both pretty well and not just one or the other. NiBiTor will not work, the voltage tables are already maxed out on there cards (7800GT/GTX).
__________________
DFI nF4 Ultra-D
08-26-2005, 02:55 PM
#17
Xtreme Workhorse
Acbar. Well i think you just have to encrese the voltages yourself by tweaking the VGA `s BIOS. Or just to try real voltmod.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
