while last weeks race was more of a cpu battle this week will be pretty much the counterpart with videocards standing out mostly.
so its time to give your vpu the spikes and get the last bit of performence out of it!
Good luck one and all... I think with this test I can finally pull away from the 9800's with my pukey x700pro....
"Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
BOYCOTT MIR's
well my previous best is 3113, so i think a reasonable target for me is 3250![]()
Opty 144 0546FPMW @ 2.8ghz
MSI K8N Neo 2
2 x 512mb OCZ Platinum Rev. 2 TCCD
ATI X800 Pro @ 570/1200
Plus some other metal fings...
Will do me till Conroe
Heat
dun duh dah..... I want to break the top ten with my sucky x700....I'm vmodding as we speak...the RAM is biting the dust big time...Originally Posted by HousERaT
BOYCOTT MIR's
Well, I burned a MOSFET on my Abit IS7-E (dam Prescott) and have bought a IC7-MAX3 to replace it. If I need to bow out, then I will accept my punishment. However, the only real difference between the boards is the 875P vs the 865PE chipset. I have read that the 865PE started out as a 875P anyway and the IS7-E had the PAT hacked already. I've run a few benches and have seen no improvement over my IS7-E. Makes me wish I hadn't spent so much for the board, oh well. I'll submit results but if they are not allowed I'm ok with it.
2600K @ 4.8 w/H70
ASUS Sabertooth P67
16GB G.Skill DDR3 1600
ATI 5870 2GB
Thermaltake 750w
OCZ Vertex 2 120GB
2x2TB WD Greens
Thermaltake Level 10GT
naw, just keep at it, that's a fair swap in my opinion, final decision is the mods however....
BOYCOTT MIR's
hehehhe yeah
and the 865 to 875 swap is fine with me...![]()
I wrecked a coffee pot does that count? Seriously I lost a mobo but I buy everything in pairs, I always like to keep a new one on the shelf of anything I am currently using, makes life easy when you have a lot of systems going...like for like swaps are easiest. And I'm fat and lazy....
BOYCOTT MIR's
Yeah, it didn't like 1.625vcore on the motherboard I guess, even though CPU-z only had it at 1.55v. It only ran a few times at that voltage before the smoke got out. I even had the MOSFETS sinked and a fan right on them.
2600K @ 4.8 w/H70
ASUS Sabertooth P67
ATI 5870 2GB
Thermaltake 750w
OCZ Vertex 2 120GB
2x2TB WD Greens
I like doing that too....I just can't afford it. I have backups of what I think will die the soonest...which is one reason why I have so much RAM for just one system (it's my only DDR system too). CPU is next (buying an Opty 144 S939), then graphics card (either 7600vanilla or R520 if it's good enough), then motherboard (DFI CF-DR). Eventually I'll have two systems....I'll call one my backup parts bin.Originally Posted by Ugly n Grey
OK I'm a very happy camper, my x700 pro is sitting number 3 on the orb unmodded in this test already.
http://service.futuremark.com/compare?3dm05=1107956
BOYCOTT MIR's
still can get the pci-e to run without 2k05 crashing any sugestions power strip wont work to cure the problem so i dont know what to try next?
Normal that my 6600GT reported GPU temp is around 73C-83C while running 3DMarks![]()
That's on water btw with AS3 and Dangerden Maze4GPU
No wonder why the temp threshold in the nvidia panel is 125C
AMD Athlon64 3200+ (Venice)0515 @3Ghz;1.63V
DFI Lanparty UT nF4 Ultra-D
Msi NX6600GT-TD128E
1 GB Dual Channel OCZ EL DDR PC-4000 Gold VX @3.3V 2-2-2-5- etc.etc.etc.etc
Enermax Server/Workstation 550Watts 24 Pins PSU
2x SATA WD Raptor 40GB @10k rpm in RAID 0
1 Maxtor DiamondMax10 SATA 200GB 7200rpm (16MB cache)
Chieftec Dragon Server DA01BD Full Tower case
Watercooled with CSP-Mag pump, Dangerden TDX64 (#4 nozzle), Maze4 GPUacetal, Heatercore 2-199, 2x S.Denki San Ace 120mmx38mm ~103CFM, Primochill ½" ID tubing
3DMark01: 26219 3DMark03: 10912 3DMark05: 4888 Aquamark3: 74636 SuperPi: 27.985s PCMark05: 4921![]()
Intel C2 Quad6600 "Go" @3600Mhz ; 1.5050V
Abit IP35-Pro
EVGA Geforce8 8800GT Superclocked @700Mhz/1000Mhz
2 GB Crucial Ballistix DDR2 PC8500 @1080Mhz 5-5-5-15-...2T
OCZ Powerstream Adj. 600Watts 24 Pins PSU
1x SATA WD Raptor 150GB @10k rpm
1x Western Digital SATA2 500GB 7200rpm (16MB cache)
Watercooled with Swiftech MCP-655pump,Dtek CPU Fuzion, DangerDen Maze5, Heatercore 2-199, 2x S.Denki San Ace 120mmx38mm ~103CFM, Ehein 12mm I.D. tubing
no thats not normal, sounds like bad contact? i got those temps with the stock heatsink on my 6600gt! did you vmod it? higher vgpu bios or anything?
and yerah, very sweet ugly!
what exactly is the problem slinky? it crashes right at the start?
tried patching it again to fix any issues? try to uninstall and reinstall it? same for dx9 maybe?
Originally Posted by saaya
Hmmmm, I temporary raised the GPU voltage to about 1.75V during 3D overclocked @640Mhz only. It seems to be the max it can do.
My temps as we speak:
I will run a 3D bench and update this thread with GPU max temp after it with no vmod. A 40C rise during 3D is kinda "unexpected" considering the cpu is only 9C hotter.Room temp : 25C
CPU: 33C load : <42C
PWMIC:36C
Chipset: 37C
HDD: 34C
GPU: 37C (No vmod atm) MaxT @500Mhz/1Ghz: 60cMaxT @587Mhz/1.17Ghz: 64C
GPU Ambient: 37C
PS: Is Arctic Silver 3 degrading overtime in the tube? It was a leftover tube that I had since about 2 years maybe
I think I will re-mount the waterblock with AS Céramique instead :/
Is it only 2k05 or any 3D? which drivers/bios on motherboard and videocard drivers?Originally Posted by Mr_Slinky
Msi NX6600GT-TD128E
Abit IP35-Pro
looks like the orb is down...
my x800 TEC bit the dust last week... broken wire... now i don't have time to replace it before this weeks results deadlinemaybe i'll rip off the insulation and give it a run on water, but at the moment it looks like i'm out - sorry guys
yep, got some results to submit tooOriginally Posted by Der_KHAN
MSI K8N Neo 2
Heat
damn, sorry to hearOriginally Posted by shinymod
cmon Stryg! gimme some dothan power! :P: heres a nice little score for you to play with
3306
http://service.futuremark.com/compare?3dm05=1114994
MSI K8N Neo 2
Heat
