This evap I have been setting on for some time at the request of my parteners, we have decided to publish it now as we will begin testing in a few weeks. It should give us a few degrees less Delta and more capacity as well as a little more effciency.
THE chilly1 evap has been a work in progress for a while. Last october I was discussing a few principes of evaporator design with acompany interested in using it for a specific application. In the conversation we discussed the evaporation process and the heat flows within the evaporator.
I drew a few designs and got the copywrite completed on this design.
well here it is.. Teh small holes in red are there to help prevent liquid slugging and the bottom suction hole is .25 above the base for bottom down operation so the block will flood. The capillary tube is inserted into the top. As soon as I get the final load testers ( software driven load and monitoring device) I should be able to determing the best configeration. I will publish the results at that time.
