Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 125
Thread: Crucial Ballistix Tracer 2GB ROCKS !! check it out inside
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Thumbs up Crucial Ballistix Tracer 2GB ROCKS !! check it out inside
    Got my Ballistix today, been playing with them for the last 9 hours ! hehe
    See sig for rig (server)
    Using 704-3 Bios
    Everything left at default setting for ram (everything) I have not started tweaking settings yet.
    2.7v + .03v
    X2 @ 280x10 1.7v water cooled with Exos2
    Here are screen shots of BIOS and Memtest86
    sorry but I had the shakes with the camera ! lol
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Here are some screenies of sandra, A64 tweaker, and CPUZ
    I'll have some PI in a few minutes
    May 2005
    Martinez,ca
    Nice. I wish I had the money for those right now. 1 gig just doesnt cut it for gaming anymore. I might end up going the 4x512 of the ballistix 4000 even tho I lose 1t.
    -C2D Q6600 currently at 3840 mhz 1.47
    -Swiftech GTX Extreme water block
    -2x2gig G.Skill pc6400 485 fsb 5-5-5-15
    -Asus P5K-E Wifi-AP
    -Phillips Blu-Ray 2x Burner
    -OCZ Power stream 620W
    -HIS HD 4870 Stock cooler No OC yet
    -Vista Ultimatex64-Xp Pro
    XP-Single 3870-14194
    Vistax64-Xfire 3870s-17878
    Vistax64-4870 Stock-17054
    May 2005
    Fayetteville, North Carolina.
    OMG Slow down!!!! I don't wanna lose the lead
    Gigabyte Z68X UD7
    Intel Core i7 2600K (testing)
    16GB Mushkin Redline 17000 2133 1.65v
    EK, 3x120 Rad 2xMCP655
    Acer 1200w PSU
    2-128GB Samsung SSD RAID 0
    2-1TB Seagete 32mb RAID 0
    1-1TB Western Digital
    1- Plextor PX-B320SA Blue Ray
    1- Plextor PX-880SA 24x DVD/RW
    2- EVGA Nvidia GTX-480 SLI
    LG 30", Hanns G 28"
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Ok here is a 2x Pi 4meg
    some notes on this memory:
    Very picky about voltages, doesn't like high volts. Mine went all the way to 270mhz with only 2.6v and then bumped to 2.7 up to 290mhz and too much will cause instablity.
    Altho its memtest stable all the way to 290mhz I can only get 280mhz stable so far in windows. I'm open to suggestions ! lol
    704-3 bios seems to be a good fit, I tried 704-2 and 704-1 also.
    Be sure to put your strongest stick in the dimm furthest from the cpu, with only 2 sticks just run the HTT up and test with memtest until you get errors then switch the sticks in the dimm and test to see if you got improvement.
    This is for any memory
    I have no idea what drive strenght I'm using since its on auto, if anyone has played around with the drive strengths I'd love to here your results.
    I'm about out of play time tonight so not sure I'll get to tweak the settings anymore. But I'm open for ideas about timmings and tweaks.
    Major
    Edit: My wife is calling me upstairs ! I'm going to leave Pi 32 running and should be back to post in....oh......30mins !
    May 2005
    Isn't there a voltage bug with that bios? i heard bad things.
    Great Numbers btw!
    Gigabyte Z68X UD7
    Acer 1200w PSU
    LG 30", Hanns G 28"
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Quote Originally Posted by nugzo
    Great Numbers btw!
    Yes but only using 123% and above special vid control
    May 2005
    Have you ran a 32m Super Pi yet?
    Gigabyte Z68X UD7
    Acer 1200w PSU
    LG 30", Hanns G 28"
    May 2005
    Quote Originally Posted by Major
    Roger That.. Maybe a lil burn in time will help. My max is 277 32m and prime stable. Havent found drive strength to make much difference. Try 2048 tref.
    Whats the actual prob with the 704 bios?
    Gigabyte Z68X UD7
    Acer 1200w PSU
    LG 30", Hanns G 28"
    Apr 2005
    Atlanta, GA
    290 stable @ 3-3-3-8
    i was looking at getting a gig of Tracer, but i'm still not sure. i think i'll still go with the Redline. the Tracer's black heatspreaders with the blue ground lights and LEDs look so sweet!
    Intel C2D E6600 (L630B015)
    TT BigTyphoon || Zalman VF900 Fatal1ty
    Abit QuadGT
    2GB Corsair Dominator PC2-8500
    HIS X1900XT --> XTX
    Creative X-Fi Elite Pro
    OCZ GameXStream 700w
    Feedback:
    HEAT --- eBAY
    Mar 2004
    New York
    Nice results..
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Get me that super_pi!
    Formerly XIP, now just P.
    May 2005
    Quote Originally Posted by EnJoY
    Shhhh
    Gigabyte Z68X UD7
    Acer 1200w PSU
    LG 30", Hanns G 28"
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Well I'm having problems getting 2 instances of Pi32 to pass, One core runs fine the other craps out pretty quick. I've tried several different settings but one core just doesn't want to work. IMO with 2 gig the processor may not OC as high.
    I'm running Pi32 right now and should be finished in another 10mins (one isntance)
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    If you change the special voltage vid % and the voltage at the same time the bios will apply the old voltge with the new % control. Thats what I understand according to bigtoe.
    for example if you using 1.4v special vid with 1.23% and change to 1.3v and 1.26% it will actually apply 1.4v and 1.26%. I hope that makes sense. It's safe using the lower special vid % like 1.13% and 1.10%.
    I wouldn't recondmend using it IF you have to use the higher vid %
    May 2005
    ok thanks....32m yet?
    Gigabyte Z68X UD7
    Acer 1200w PSU
    LG 30", Hanns G 28"
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Not yet man ! lol
    I've changed some setting trying to get both cores to work at 2.8ghz, I'll post some stuff up in a few
  18. #18
    Nov 2004
    Nice!!! I'm not feeling so guilty anymore about ordering these same sticks from NewEgg earlier today... c'mon FedEx get here for the weekend!
    Thanks for all the work/testing Major and nugzo!
    DFI nF4 SLI-DR
    AMD 3500 (Newcastle) CAA2C 0505DPMW (11*220)
    512x2 XMS3200 (2-2-2-5 @ 2.9)
    BFG 7800GTX
    PCP&C 510 SLI
    Audigy 2ZS
  19. #19
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Most of the testing and work credit goes to nugzo !
    I just read his posts !
    I've given up for tonight on getting Pi32 to pass I tried every thing I could and I just don't think its going to happen at 280mhz. I'm thinking it may be the limit of the memory controller and not the memory. I'm going to wait and see what happens with DriveEuro and his sticks. he's testing them right now with an SD.
    I've changed gears for tonight and have gone back to OCing my X2.
    Running for the moment at 10x286 with 183 divider giving me 260 on the memory.
    I'll try to play with getting 280mhz+ going tomorrow. It's pretty close, just not quite there.
  20. #20
    May 2005
    Dont be to concerned about high HTT. Ive found that 260*11 (2860) and 286*10 (2860) perform the same. The 11 multi i could get 100% stable. The 10 i could not.
    Gigabyte Z68X UD7
    Acer 1200w PSU
    LG 30", Hanns G 28"
  21. #21
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Just give us a 32m at 9x multi lol...you should always test ram at a 7/8x multi anyhow.
  22. #22
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    I will get ya a 32m tomorrow, just burned out on OCing the WHOLE day ! lol
  23. #23
    Nov 2003
    Midwest
    A64 tweaker can tell what what all your auto timings/settings are major.
    ALIENS are bringing my next kentsfield based rig in a UFO case!
  24. #24
    Aug 2004
    Austin, TX
    Damn that's nice!
    Looks like a good choice for my next upgrade
    oh man
  25. #25
    May 2005
    Here's 285 stable
    Gigabyte Z68X UD7
    Acer 1200w PSU
    LG 30", Hanns G 28"
