Page 1 of 4 1234 LastLast
Results 1 to 25 of 90
Thread: CAS 1.5 is doubt to work on A64 based systems......
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Exclamation CAS 1.5 is doubt to work on A64 based systems......
    According to this thread post #87 I feel shocked:
    http://www.xtremesystems.org/forums/...t=66721&page=4
    CAS 1.5 is not working on a64 based systems ?
    Can't believe it - if it is a fake each CAS2 RAM would run 1.5......
    So guys what do You think about it?
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Mar 2005
    Imladris
    Well technically AMD themself says their cpus don't support CAS 1.5. All I can say is supported or not, CAS 1.5 seems to work fine on my system. Some people claim that they get better system performance & stability with CAS 1.5. I will neither confirm nor deny this statement.
    The little air system that could.
    Jan 2005
    AMD factory
    Quote Originally Posted by HousERaT
    Nice statement - let's see what other experts have to say........
    Previous system:
    Aug 2002
    Pearland, TX
    It comes from a good source
    In a way it shows that a64tweaker just reads what the bios sets.
    I guess what the memory controller intrepets is cas2.
    You also notice it knocks out a bunch of values for other timings
    CAS# Latency (Tcl)—Bits 2–0. Specifies the CAS#-to-read-data-valid.
    000b = reserved
    001b = CL=2
    010b = CL=3
    011b = reserved
    100b = reserved
    101b = CL=2.5
    110b = reserved
    111b = reserved
    Row Cycle Time (Trc)—Bits 7–4. RAS#-active to RAS#-active or auto refresh of the same bank.
    Typically ~70 ns. These bits are encoded as follows (only 7–13 are valid; all others are
    reserved):
    0000b = 7 bus clocks
    0001b = 8 bus clocks
    1110b = 21 bus clocks
    1111b = 22 bus clocks
    Row Refresh Cycle Time (Trfc)—Bits 11–8. Auto-refresh-active to RAS#-active or RAS# autorefresh.
    0000b = 9 bus clocks
    0001b = 10 bus clocks
    1110b = 23 bus clocks
    1111b = 24 bus clocks
    RAS#-active to CAS#-read/write Delay (Trcd)—Bits 14–12. Specifies the RAS#-active to CAS#-
    read/write delay to the same bank.
    000b = reserved
    001b = reserved
    010b = 2 bus clocks
    011b = 3 bus clocks
    100b = 4 bus clocks
    101b = 5 bus clocks
    110b = 6 bus clocks
    111b = reserved
    wolfdale e8400
    Corsair Dominator 6400c4 4x 1gig
    rampage formula
    evga 88000gtx
    x-fi platinum
    ocz powerstream 520
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    cas 1.5 is a placebo.
    it doesn't work, but you think it does.
    truth is, A64's don't support latencies below 2.
    its just creative bios tricks on Oskars part, that can give a sense of what to expect from cas 1.5 or so... kinda like a "simulated 1.5" haha...
    I've known this for sometime from a friend online, however, this is the first time I really looked at actual data to support that. interesting.
    X.I.P
    Mar 2005
    i hate to tell you guys about this
    but in my taiwanese forums, we already found out that CL1.5 is slower than CL2
    and even CL1.5 works find, doesn't mean CL2 work in same speed
    Jan 2005
    AMD factory
    Quote Originally Posted by guess2098
    Do You have any screenies for compario ?
    Previous system:
    Aug 2002
    Pearland, TX
    If this is true and the memory controller on the chip does have to convert values from the bios to the "supported" memory timings this should be a sticky of what memory timings to set in the bios.
    Could even edit the bios before loading to to only allow these values
    wolfdale e8400
    rampage formula
    evga 88000gtx
    x-fi platinum
    ocz powerstream 520
    X.I.P
    Mar 2005
    Quote Originally Posted by HARDCORECLOCKER
    cuz i am not the one who post the pic, i can't just copy and post in here
    but i can give you the URL of that thread
    http://www.coolaler.com/ipb/index.php?showtopic=55053
    Jan 2005
    AMD factory
    O.K. - this is gettin' hot - can someone make it a sticky ?
    Previous system:
    Xtreme Mentor
    Nov 2004
    Elma, NY
    I tried Cas 1.5 and found while it was Memtest stable, I had issues with games - CTD, reboots... and Cas 1.5 in Sandra wasn't any faster.
    I too feel it's probably a placebo, not working - and probably makes things unstable anyways...
    i7-2600k @ 4.8Ghz 1.38v L044A892
    ASUS P8P67 LGA
    16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
    1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
    Cooler Master UCP 1100 Watt PSU
    GTX 680 1300/7000
    Lian Li PC V-2000
    X.I.P
    Mar 2005
    Quote Originally Posted by dnottis
    some how i think 1.5 is more stable than 2 under same speed^^"
    May 2005
    I posted this when I came across Geil's upcoming Ultra-X memory on Anandtech - Rated at DDR400 1.5-2-2-5:
    "The new DFI nForce4 boards support CAS 1.5 as a BIOS choice, and possibly a few other high-end boards. CAS 1.5 sounds impressive, but AMD tells us that they do not support CAS 1.5 in their on-chip memory controller." - Anandtech
    So CAS 1.5 is not of much use , not for the time being anyway on AMD, but I can't help wondering if/when they'll support it. I sure hope Geil know what they are doing tho.
    My Specz... Pic 1, Pic 2, Pic 3, Pic 4.
    __________________________________________________ ___________________________
    Jul 2003
    Hmm from my early testing 1.5 was faster than 2. I'll have to revisit this and verify that. But yes according to the AMD .pdf, 1.5 is nothing.
    Still, I doubt that Oskar would option that into a BIOS for "simulated 1.5"
Name:	BIOS dev guide CAS A64.jpg
    X.I.P
    Mar 2005
    well~~ i am thinking that.... if K8 can;t pick up 1.5... then what value does k8 use when we place at 1.5.....
    Jan 2005
    AMD factory
    So maybe OSKAR himself knows somethin' about it.........?
    Previous system:
    Dec 2004
    Atlanta
    When I use 1.5 it's a more stable for me. So I use just 2 unless I'm really pushing my ram to the limits.
  18. #18
    Apr 2005
    Calgary, AB
    Geil uses the lower CAS values as a marketing gimmick, leading people to believe they have come up with some new tech that runs at cas1.5. Supposedly these sticks can even run at cas1.0, maybe they should read some white papers. Link
    MB Reviewer for HWC
    Team OCX Bench Team
  19. #19
    Feb 2004
    San Diego
    CAS 1.5 sure does look a lot cooler than CAS 2
    I've found 1.5 actually does nothing for me, good or bad.
    DFI SLI-DR | Opteron 170 Mach II | 2x512 G.Skill LE | x1900XTX | 2x250GB Hitachi T7K250 RAID 0 | PCP&C 510 SLI | Creative X-Fi
    My Heatware
  20. #20
    Phenom™
    Sep 2002
    HCC - Why don't you just run a test to put this issue to rest. Your Corsair can run cas 1.5, so how about a comparison of your own?
  21. #21
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    Cas1.5 is not supported, its not setting cas1.5 and its no faster than cas2. OCZ ran tests months ago to see if it was worth releasing VX at cas1.5, upon advice we decided not to as its not actually cas1.5 being set.
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
  22. #22
    Dec 2003
    Canada, BC
    Some vx-4000 I bought of opp a little while ago prefers cas 1.5 by over 10mhz, on my 3700+ sandy. So cas 1.5 is no myth in my mind.
  23. #23
    Dec 2004
    Atlanta
    Just did a little test run using SuperPI 1M and Sandra Bandwidth.
    CPU @ 2.75GHz
    Mem @ 250Mhz
    CAS 2.0
    SuperPI 1M
    1st Run - 30.922
    2nd Run - 30.965
    3rd Run - 30.797
    Sandra Bandwidth
    Int - 7218
    Float - 7142
    CAS 1.5
    SuperPI 1M
    1st Run - 30.921
    2nd Run - 30.950
    3rd Run - 30.797
    Sandra Bandwidth
    Int - 7218
    Float - 7140
    Going by these results imo they are the same as far as performance goes. I still think that in some ram 1.5 adds stability some how.
  24. #24
    Phenom™
    Sep 2002
    Quote Originally Posted by haPpydUde
    But if cas 1.5 was truly a reality, your memory should clock lower than cl2
  25. #25
    Dec 2003
    Canada, BC
    Mabye but some ram just likes low latts. And I to noticed that the preformance was the same pretty much saw some improvments in some 3d programs. Nothing major, but the fact that I can clock 10mhz highier because of it is why I like it.
