Here it is the very first with 2 Gigabyte in SLI - stock cooler of course and still using my good old FX-55 (0.13WR) at around 3.3500Mhz ..Redline using only 3.2.v ..cooling: silent 404a Mach 2..
1st - Driver instalation if you have one card already installed you have to boot on VGA mode - uninstall drivers - reinstall - than enable SLI
2nd - Even with 2 card in SLI the stocker is very silent - almost inaudible..
3rd - OC, a plesant surprise - I discover the SLI is the best of the 2 card if you forced OC with coolbits or RivaTuner..
The first card gives me 526-1390 on single, the 2nd 512-1360 - SLI OC = 526-1380 - well done Nvidiaand improvement from 6800 Series (SLI OC gives you the worst of 2)
Here is a photo:
3DMark 2005 :
Top 8 on Hall on Fame on the very first run - not bad at all
3DMark 2003 :
But I can not publish this score![]()
Is there any bug with 30.000+ scores tha dont let publish??
And finally 3DMark2001
This score is nothing special, because I'm using a non-tweaked WindowsXP..
I have to work on WindowsXP tweaks (do a testing of some tweak it may boost 3dmark scores), before cards go to Ricky's cascade ..
This is just to share with you my first 1/2 hour bench session with 7800GTX .. I can say I'm really impressed with performance of this cards at stocks..![]()
This is Pedro Rocha over and out![]()
is the remedy
