Page 1 of 4 1234 LastLast
Results 1 to 25 of 79
Thread: Xtreme Grand Prix racetrack 2 discussion
    Xtreme X.I.P.
    Nov 2002
    Shipai
    please use this thread to ask for help and/or share your results and expiriences and how to get your system to full speed on this underwater track of the Xtreme Grand Prix
    Feb 2005
    Iowa City
    Whatever driver works best for you, I think would be fairest. I dont think there are "hidden drivers" that only a select few have access to.
    AMD 6400+ BE
    DFI Lanparty UT 790FX-M2R
    2gb Crucial Ballistix DDR2 800
    ATI Radeon X1900XT 512mb
    PCP&C 750W
    Water cooled:
    Swiftech Storm CPU
    Maze 4 GPU
    MCP655
    Modded Heater Core
    Xtreme X.I.P.
    Nov 2002
    Shipai
    all drivers are fine for aq3
    the drivers that work best for 3dmark dont always score better in aq3 as well, there are some driver reviews out there comparing different forceware versions, could be worth to check out those reviews
    does aq3 also score best at the first run or does it score higher after the first run?
    Mar 2005
    NJ
    Quote Originally Posted by saaya
    From what I have seen on AM3 you can run rerun and keep running without a real change.
    Admin
    Feb 2005
    Ann Arbor, MI
    One thing I have noted in AM3 with my 9800XT is that at a high enough speed, the score will actually lessen.
    Jun 2005
    Bancroft, ON, Canada
    Quote Originally Posted by Vapor
    That's nasty, any idea why?
    I think I can totally take the class for x700's (I know big whoop de doo)
    "Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
    BOYCOTT MIR's
    Quote Originally Posted by Monkeywoman View Post
    aww an OC virgin! lose it tonight with Xtremesystems!!!
    Admin
    Feb 2005
    Ann Arbor, MI
    IDK why, but it also artifacts noticably less than other benchmarks...no clue why.
    I think my 7800GTX also has this problem. I ran one at 2.4GHz 496/1420 and got 90k while I ran another at 2.65 525/1460 LOD +15 and only got 94k....something's up.
    beefin' it up!
    Dec 2004
    WPI
    throttling? same thing happens to my 6800, it just suddenly starts slowing down, giving scores lower than stock...
    Admin
    Feb 2005
    Ann Arbor, MI
    IDK how AM3 can throttle a 9800XT though...w/e. My 7800GTX runs are weird, still playing with those.
    Admin
    Feb 2005
    Ann Arbor, MI
    Alright, those scores are as good as it'll get for now....not sure how I got 90k on the slower speeds though....turned down LOD to +3 on these settings and got 91k.
    My GPU needs more volts too....even on aircooling. Artifacting at 530 MHz a lil too much and the card is still only warmish....
    Dec 2004
    Denmark
    LOD = Level Of Detail ?
    Anyways, 5.6's gave me good scores.
    Aug 2003
    first time with this benchmark...
    i get 80,250 with a winchester at 2570mhz, 512MB BH-5 @ 257mhz 2-2-2-11 and x800xt at 500/500 and 80,800 with the x800xt at 563/567....
    that doesn't seem right to me... also when i get back into windows i notice that atitool now shows 500/500 again i had this bug with 3dmark 03 as well and it seemed to affect my score, any ideas anyone!? i'm stumped.
    Mar 2005
    NJ
    Def. need the vmods. Couldn't break 540 on cool water at 1.5v which is higher than stock.
    Shineymod: Might be going too high on core I think and it is resetting itself try backing down and see what it does. Also make sure to check off vgpu recover I think that caused problems when I ran it w/ the x850xt.
    Aug 2003
    yeah i have vpu recover turned off, i'll try with a lower core speed, thanks
    EDIT: 550/550 no reset 83K+ if only i'd known that for '03 now to work out how to stop it resetting so that i can run with decent clocks...
    Admin
    Feb 2005
    Ann Arbor, MI
    Hmmmm, I think I figured out something very interesting for the 7800GTXs....let me test a lil more and maybe I'll have 100k in the bag when I get back.
    Mar 2005
    NJ
    Definately curious. I figure 100K should be cake w/ the card. I am actually hopin on hittin 110-115.
    Admin
    Feb 2005
    Ann Arbor, MI
    With water and an FX 100k is cake. With aircooling and an X2...not so much...will update later with my findings, kinda busy.
  18. #18
    Jan 2005
    NJ
    Ok mine keeps crashing after MAssive overdraw part? I'm on stock clocks all around...
    CPU Z:2700 2k1:27952 2k3:12282 2k5:5763 PCM05 AQ3
    Opteron 165 s939_____OCZ RAM/PSU_____BBATI X800xl
  19. #19
    Jan 2005
    NJ
    aye
  20. #20
    Jun 2005
    Dulles, VA
    I was wondering about the driver issue also. It states in your rules post that only FM approved drivers may be used for this competition.
    Rule#12
    Q. "Can we use any driver we want?"
    A. "sorry, no. please only use futuremark approved drivers."
    So has that rule now been changed after the start of the Comp?
    2600K @ 4.8 w/H70
    ASUS Sabertooth P67
    16GB G.Skill DDR3 1600
    ATI 5870 2GB
    Thermaltake 750w
    OCZ Vertex 2 120GB
    2x2TB WD Greens
    Thermaltake Level 10GT
  21. #21
    Jan 2005
    NJ
    May have applied only to that first benchmark
  22. #22
    Xtreme 3DTeam Member
    Dec 2004
    UK
    thing was, i had to run un-approved drivers to get my 9800se to 8 pipes so i'll have to see whats done about it
    Opty 144 0546FPMW @ 2.8ghz
    MSI K8N Neo 2
    2 x 512mb OCZ Platinum Rev. 2 TCCD
    ATI X800 Pro @ 570/1200
    Plus some other metal fings...
    Will do me till Conroe
    Heat
  23. #23
    Jun 2005
    I think it was said somewhere that you can use whatever driver you want for AM3. I know it is FM approved drivers only for the 3D0X benches though.
    Gryph
  24. #24
    Admin
    Feb 2005
    Ann Arbor, MI
    Interesting findings here....I got 96538 with my 4400+ @ 275x10 and my 7800GTX at 525/1450 (highest I can run with zero artifacts....seems to help in AM3) yet I get 913xx at 460/1300, so AM3 definitely seems to be much more CPU intensive (where my X2 is gonna stuggle). A 15%/11% graphics OC shouldn't yield only a 5% increase in score, should it? It also seems that AM3 is much more CPU OC sensitive than 01 is...I can run 01 at 2830 but my best score in AM3 is at 2750 (I can run it at 2810ish, but it gets a lower score).
    I scaled my GPU and MEM speed up slowly and it's definitely the highest score I get with my stock cooling. Any faster or slower and I get a lower score...
  25. #25
    Jun 2005
    Amazing gpu clocks Harleybro. Is that still just chilled water? And what kind of volts are ya pushing through there?
    Gryph
