http://valid.x86-secret.com/show_oc?id=26641
http://valid.x86-secret.com/show_oc?id=26781
To after with the explanations
Air cooling![]()
Air cooling![]()
And for the third time... some photography of the cooling...![]()
[IMG][/IMG]
so...this is my freezer in dayuse...![]()
this is the freezer in a special occasion
Some aluminum sheets in order to avoid the effect glue
the hardware
Abit nf7-s rev 2.0
Slk947U+tornado 92mm@13volt
Ocz 520watt PowerStream
2*256mb a-data 3200 bh-5
Amd thunderbird900mhz and duron 1600
watches the neoprene under the mainboard in order to isolate the mainboard and to avoid circuits short
so...last test...after to have closed the freezer... to modify the hardware it is difficult![]()
here as I have isolated the cell...adhesive tape and hygienic paper
hygienic paper rulez![]()
adhesive tape rulez...![]()
lol
Level 80 UD Death Knight on Murmur (Beta)
Originally Posted by bh2k
I detach termostato... therefore the compressor works continually
plums rulez![]()
and septum all to the maximum...
the heat of the cpu comes dissipated here...
with the PC approached after little minuteren he becomes much warmth![]()
frosted water and fanin order to cool the coil
After I have moved the freezer in an other room.There is the conditioned air...![]()
temperatures
the bios after the zero it does not mark the temperature![]()
ROFL man that is great.. absolutely great.. you dont have condensation problems?
ThxOriginally Posted by MaxxxRacer
so...if I had not isolated the cell the condensation it would have been a problem...in the freezer it is like benchs in winter
if warm air from the outside enters then form condensation it
with the thunderbird downclocked...
Nice. What speeds are benchmark stable?
thunderbird...buhOriginally Posted by sr4470
...duron1600@2375mhz
Not bad, might try this myself.....just got a cheap duron 1800
And now...duron rulez...
idle@2volt![]()
And...-14° with a boot a 2,300volt...then I have lowered v-Core from windows
Bizarre!! but wonderful!!!
Jymba!
Semprom2200+@2173mhz<ninguém quiz eu queimei!!![]()
Powered By Athlom Tbird & Pcchips M825g![]()
My site about GM Chevette / Opel Kadett C
