Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Dual PSU
Hybrid View
    Feb 2005
    Dual PSU
    Anyone tried this?
    http://www.benchmark.co.yu/forum/att...achmentid=7558
    1. Any problems with overvolting?
    2. Can you connect 2 different types of PSUs (both ATX)?
    3. If both PSUs have switches do you use then only master PSU's switch (and on slave's it is always ON)?
    Thanx!
    EDIT: Forgot to add the link.
    Just 'cause you feel it, doesn't mean it's there
    May 2004
    try this should have the answers for you
    DFI ULTRA-D
    opteron 146 @ 3.0g 1.52v watercooled
    X1800 XT 512MB 700/800
    03 13105 01 34118
    Feb 2005
    I finally added the right link.
    Just want to know if anybody has already tried this and if it's 100% safe.
    Jun 2005
    wtf?
    i didnt even know that was possible
    Feb 2005
    Thanx pancake for the link. I had only the pic from that link though.
    Yeah, it's possible... just will have to see how it works in a week or two.
    XS - Extra Strong
    Aug 2003
    Toronto, Canada
    You can do this trick with a molex connector as well, you just take the green wire from the slave psu's atx connector and hook it to a ground on one of the primary psu's molexs.
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
    Feb 2005
    @lalPOOO: I think that would be the easiest way to do it. Thanx!
    Jul 2004
    Moscow
    well, if you want to get 2 PSUs working in dual mode all the time, I think it would be wiser to connect the PS-ON wires teogether!
    I have tried connecting a Codegen (absolute PoS) 350W (the chinese type of 350W) and a great AOpen 300W (which is a lot better than that Codegen BS) and I had no problems whatsoever! It actually increased my overclock
    Now I have a 420W Thermaltake PSU which is enough for my sig system.
    I have read an article about combining two PSUs in one case, and divinding +12V and +5V lines (they are on the same line, that's why +12/+5 Volts are never both good, it's either +12 higher and +5 lower or vice versa). They are in Russian and I can't seem to find the links, not that anyone of you (except for aca maybe) would understand
    Main rig
    A64 X2 4200+ | 2*1024 Corsair XMS TWINX-2048 3200C2PT | DFI LanParty NF4 Ultra-D | ASUS N7800GTX | all at stock | powered by a ThermalTake PurePower 680W PSU
    PATA: 80GB system PATA HDD | SONY DWU-18A
    SATA: 2*300GB Seagate 7200.8 | 320GB Seagate 7200.10
    Audigy Platinum eX | Samsung 204B monitor | Logitech G15 gaming keyboard | Logitech G5 Laser Mouse
    Assembling a Linux server
    Athlon XP 1600+ | 512/1024MB RAM | 300+320 Seagate SATA | PCI video card
    Feb 2005
    Saskatchewan, Canada, EH?
    I've heard that that is not the healtiest thing to do to your PSU, as there is no load on the 5v and 3.3v lines for PSU #2, and switching ATX PSU's are designed to operate with a load on all rails. cooler master included a dual PSU harness with my CM stacker, all it does is connect the "power on"(green wire) and a ground wire to the second PSU in order to give it a simultanious power on signal.
    Feb 2005
    The only problem I heard about all this is something about overvolting. Nothing else. But noone has confirmed this. I would like to see what somebody (who has tried this) has to say. I want to be sure before I connect the 2 PSUs.
    I would use the better PSU (master) to power the MoBo and graphics card, and the slave PSU for avarything else (2 pumps, hdd, dvd, few fan controllers, fans and other gadgets).
    @Bergo: You are saying that this is only bad for the slave psu, right?
    Jun 2005
    Stockholm, Sweden
    The problem using two PSU's is that they have to be 100 % matched.
    Otherwise one will try to either lower or increase the voltage, while the other one will try to do the opposite.
    And as previous stated, using the PSU without load should only be done for 2-3 seconds.
    Jun 2005
    Dulles, VA
    I use two power supplies on my bench/gaming rig. One powers the motherboard and all drives and graphics card. My second one powers my watercooling systems. This allows me to shut down the computer and continue to circulate water through the waterblocks to cool the system down much quicker. I have a jumper in the correct pins to power the second supply whenever I turn the switch on the back ON. Works fine. I've even used the second to power the video card on occassion. I don't know where all these Electronic Engineers get their info but you do not need a load on a power supply and running two is really no different than running one. Just make sure its set up correctly. I have mine different than some so don't go by what I do but its very simple.To say this though, one Power Supply should only be used to power the motherboard. DO NOT splice wires together to "Combine" them. That is a big NO NO. You will likely fry everything. But using one to power extra drives, fans, video card is ok, just make sure the secondary PS starts with the primary. There are a two wires to connect between the PS's if you do it that way.
    2600K @ 4.8 w/H70
    ASUS Sabertooth P67
    16GB G.Skill DDR3 1600
    ATI 5870 2GB
    Thermaltake 750w
    OCZ Vertex 2 120GB
    2x2TB WD Greens
    Thermaltake Level 10GT
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by D4nnyOcean
    The "slave" PSU may need a load depending on its make/model. Not all need a load, but some do.. and not all rails need loads, just some. When running multiple PSU's as shown in this thread they should not be electrically joined other than the startup wire.
    Some work is required to run PSU's in parallel..
    All along the watchtower the watchmen watch the eternal return.
    Jul 2005
    Ive done this. Not so clean, but i used a 650watt to power my dual CPU rig, fans, and system drives, then a 430watt PSU to power just the RAID 0.
    The second PSU was simply turned on by a radio shack switch, with 2 wires running to the green and black ground.
    No problems at all. Had to do it because 1 PSU would blow if i powered the rig with it
    Nov 2004
    New Jersey
    I have done this for about 2 weeks, when i upgraded and the 400w wasn't pulling it, it was running till I got a new one. I just did the always on way and unplugged it to turn off. I used the master to power mother board and the slave to power drives, fans and the molex connecters of vid card.
    Jun 2005
    Stockholm, Sweden
    The PSU unit is both simple an complicated at the same time.
    Simple because users thinks it is simple, to transform voltage.
    Complicated because they are.
    Testing it without load is not recommended, and will / could give false voltage readings.
    With so many PSU brands, they all differs from one another.
    Finding a good professional test report is difficult.
    And I mean, not this - "I tested it and it worked flawless".
    Instead of talking about max Watt, we should discuss how much current the PSU can deliver on the vital voltage rails.
    And the correlation between the +3.3V, +5V and +12V.
    Thoughts on 650W Silverstone ST65ZF-GM SLi before I buy it.
    Edit, Minor update.
    (English is not my native language but I m doing as good as I can.)
    Member
    Dec 2002
    Leics UK
    This is generally pointless and dangerous.
    Connecting two PSU in paralell even if they are the same model will create a more unstable voltage in most cases.
    This is because as the load fluctuates the PSU's will try and compensate to keep the voltage stable.. but they will do this differently and if there is any PD between the PSU then you might get them "shorting" against each other a bit, especially if they cannot equalise the lines (if 12v and 5v are combined on bother PSU this is likely)
    This might just mean a less clean voltage, but it might blow up one of the PSU.
    If your PSU blows up you might kill other components.
    The same is true for using a second PSU to power hard disks or graphics cards, except in this case you may get current flowing through IDE cables or the motherboard between the PSU where only small amperage is permitted... this might kill the HDD, graphics card or motherboard.
    The only safe way to run two PSU is to use one for all components that connect to the motherboard and just use the second PSU for fans and watercooling... generally thats not worth the bother.
    Or if your powering peltiers, but even then I recomend a dedicated unit.
    If your PSU is not doing the job just buy a newer better one.
    Messing about with dual PSU probably wont help you... and might kill your stuff so dont bother.
  18. #18
    Dec 2005
    The links shown at the top are safe.. its not running the PSUs in parrellel.
    I did this wehn I lost a 300 W PSU a couple years ago
    I used a 110W to power the board and a 90W for fans and 2 drives.
    I actually found this thread looking on ways to use caps or resistors to run 2 different PSUs in parrellel or at the minimum combine the dual rails on a crappy PSU
    I took a 36" wire cut it in half stripped about 1/8th inch off each end . I jammed one the wire into the top of the ATX connector on each PSU (14 to 14 15 to 15) super glued it in place and ran that for 18 months or so with no problems.
    I will let you guys know how my 400w and 450W mod goes (Doing a little more then just he wire though)
  19. #19
    Xtreme Enthusiast k0nsl's Avatar
    Feb 2005
    Scandinavia
    I simply connected my two power supplies (Tagan 580 EasyCon and OCZ Modstream 520W) by using the cable which came with my Stacker; it is used to add a second PSU to the system by starting it at the same time you hit the power button, (Green and Black cable).
    So I use the Modstream for my X1800XT, 2 HDDs, pump and soon also a couple of fans. The Tagan power supply is dedicated to the rest of the system (basically Motherboard/CPU/DVD).
    -k0nsl
    When you were born, you were crying and everyone around you was smiling. Live your life so that when you die, you're smiling and everyone around you is crying.
  20. #20
    Xtreme Cruncher
    Dec 2005
    St. Paul, MN ,USA
    i think they have a thing that combines the atx connectors [too sick&dizzy to post link] i can barly type strei ght
  21. #21
    Feb 2006
    PR, USA
    Wow that's easy... I knew it was possible but I never thought it would be that simple. Thanks pancake.
    Intel i7 3770K @4.7GHz (1.224v) | Gigabyte Z77X-UD5H | 8GB Samsung DDR3-1866 | EVGA GTX 780 Classified
    Corsair HX850 | X-Fi Titanium HD | ATCS 840 Black
    Apogee XT | DDC-2 w/ XSPC Top | XSPC RX360
  22. #22
    Mar 2006
    York, England
    Here is a dual psu guide if your interested..
  23. #23
    Jun 2005
    Quote Originally Posted by Freebo
    thanx, I´m looking 4 a guide like this ...
  24. #24
    Jun 2006
    As has been pointed out, this is not about running PSUs in serial, butr a simple guide on how to make multiple PSUs start up and shut down automaticly. Very very useful for extremist systems that often use way more amperage than a single PSU can handle (atleast if you dont wanna spend 250$ on a PSU)...
    -Stigma
  25. #25
    Xtreme Cruncher
    Dec 2005
    St. Paul, MN ,USA
    oh, then use a relay on the green wire to ground and set the 1st psu [the one connected to the motherboard] to the electromagnet in the relay,
