Page 1 of 4 1234 LastLast
Results 1 to 25 of 88
Thread: Sampsa & Kamu: GeForce 7800 GTX SLI with LN2
    Xtreme Legend
    Sep 2002
    Finland
    Ok, G70 cold bug is fixed with BIOS update. The problem was serious performance drop when cards were cooled below 35C. New BIOS disables temperature sensor in drivers and throttling mechanisms.
    We did some testing today with Kamu and were able to run cards in SLI when GPUs were working at 580 MHz and memory at 1420 MHz. This was with default voltages and around -25C was measured from the base of GPU copper containers.
    There was still some strange behavior when going above 580/1420. System froze immediately at 525/1425 when I pressed Rivatuner's "Test" button even though 580/1420 worked fine in 3DMark05. Same thing happened with Coolbits.
    Next we'll do some modifications and try to get our CPU even higher. Currently we are able to run 3DMark05 at 3575 MHz.
    Favourite game: 3DMark
    Work: Muropaketti.com - Finnish hardware site
    Views and opinions about IT industry: Twitter: sampsa_kurri
    Xtreme Mentor
    Oct 2002
    boston,ma
    Let the fun begin
    Abit KN9-SLI
    X2 3800+
    1gb corsair pc5400
    2 evga 7900gt
    200gb maxtor sata
    ocz 520w
    heatware:althes
    ebay althes
    Feb 2004
    York, PA
    Cant wait for the xtreme scores in the near future
    Xtreme Legend
    Sep 2002
    Finland
    Quote Originally Posted by Troman
    Thx for informing us sampsa...
    i hope you wil be able to hit the same as shamino a nice 745 on the core
    gl
    745? 3DMark05 reports GPU speed around 40 MHz higher than it really is. But 700 MHz is still very nice
    I'm pretty sure there are some insane numbers coming from Singapore
    XS_THE_MACHINE
    Nov 2004
    Long Island
    Cant wait to see some numbers. Is someone going to break 40k in 3d03? Opp got like just under 35k with his watercooled, will jumping to LN2/cascade get an extra 5k points?
    "Victory is always possible for the person who refuses to stop fighting"
    clicks to save kids
    Oct 2004
    Nice results to begin with Sampsa i have one important question for you how come the SanDiego FX55 is working with LN2 ? no cold bug i presume ? I expected a bit more from a LN2 cooled SD didn't you ?
    Xtreme Legend
    Dec 2004
    Sweden
    WTG!
    You two must have the best LN2 wrist in the world
    ln2nl
    Jun 2004
    The Netherlands
    Hope to see some crazy mhz overthere... succes guys
    *EDITed by IFMU*
    Signature Removed by XS Staff for not following XS Policies
    Forum Policies
    Xtreme Legend
    Sep 2002
    Finland
    Quote Originally Posted by Kinc
    WTG!
    I have to admit that Kamu has much better LN2 wrist than me. Although today it was a bit shaky because he had a hangover
    I am Xtreme
    Aug 2003
    Why didn't you take the GPU containes lower than -25C?
    Have you tried disabling the internal clock test with riva tuner?
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Xtreme Legend
    Sep 2002
    Finland
    Quote Originally Posted by afireinside
    "Guess" ?
    Anyway, there still is a test when you raise clock speeds with Rivatuner and have to run it before you can apply them, right?
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by Sampsa
    "Guess" ?
    You can disable that test.
    OPP
    Jan 2005
    Oxford, UK
    it's in the rivatuner poweruser settings, it's very easy to do.
    nvidia/overclocking/disableinternalclocktest , iirc. Certainly something along that line, i'd check myself if i wasn't on a mac at the moment.
    Conroe E6300 ES
    2x1gb Ballistix PC8000
    Asus P5W DH Deluxe (1705)
    Manli Geforce 7950GT 512mb
    Hiper Type-R 480w
    Samsung SP250
    "What did the quantam duck say?" "Quark Quark"
    Xtreme Legend
    Sep 2002
    Finland
    Quote Originally Posted by OPPAINTER
    OPP
    Ah, thanks. Never had any problems with 6800 Ultras
    Aug 2003
    Belgique, Belga, Belgio, Belgium, Belgica, Belgie, Belgien
    Quote Originally Posted by don_vercetti
    There is still a rivatuner test left if you disable the internal testing
    .:C2D 6600 :: Tuniq tower :: Asus P5B dlx :: 2GBHZ :: OCZ 520W :: 8800GTX :.
    Xtreme Legend
    Sep 2002
    Finland
    Quote Originally Posted by HaLDoL
    Looks like it can be disabled from Power user options: Rivatuner 2.0 RC 15.5 \ Overclocking \ Global \ and set DisableClockTest to 1
    I'll test it with voltage modifications, more LN2 already ordered
    I am Xtreme
    Aug 2003
    yes you have to disable it under overclocking \ global as well as overclocking \ nvidia I believe it is. You can also enable "enableperflevelforcing" under overclocking \ nvidia then set "force constant performance level: performance 3d" under the overclocking screen to disable the throttling Not sure if it works with cold throttling, though.
  18. #18
    Mar 2004
    yay
    i look forward to results
  19. #19
    Jul 2004
    Sweden
    Can't wait!
  20. #20
    Jun 2004
    lake forest, CA
    Good to know the cold bug is fixed!
  21. #21
    May 2003
    Zaragoza (Spain)
    Can you post a link for that bios Sampsa?
    Thx god for the dryice and the liquid nitrogen.
    HeatWare
    eBay
  22. #22
    Jan 2005
    Kansas
    I can't wait to see what you can do with these.
  23. #23
    Jul 2004
    Sweden
    Quote Originally Posted by Apocalipsis
    OPP couldn't share it, I don't think Sampsa is allowed either...
  24. #24
    Xtreme X.I.P.
    Aug 2004
    Chile
    hope you can break some wr
  25. #25
    I am Xtreme
    Jan 2005
    good luck guys
