Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: what is the best copressor +gas? to get -65/-75c'??
    Apr 2005
    Question what is the best copressor +gas? to get -65/-75c'??
    hello guys..
    i want to make phase change cooling....with one compressor.
    and i want to know what is the best compressor and gas to get -65/-75c'?
    thanks
    Skulltrail Addict - XIP
    Nov 2004
    France
    -65 in a normal single stage is not reachable (except chilly super vapo, but no clue about his under-NDA gas)
    May 2004
    berkeley CA
    Well, chillys work proves its POSSIBLE
    3800+ Manchester @ 2.5ghz on an Asus A8N-SLI, 1024mb Corsair XMS 2 3 2 6, 7800GT SLI
    Apr 2005
    ok........ so you still didnt tell me what is the best copressor and gas? and wich temp i will get?
    thanks..
    Mar 2005
    U.K
    Quote Originally Posted by Tyrou
    LOL - sorry for the question, what's NDA mean?
    * MUSIC PRODUCTION RIG - HP Pavilion ZD8290 Laptop *
    -->Intel P4 650 (3.4GHz - 2MB Cache)
    -->1024MB DDR2 533MHz DC
    -->100GB HDD
    -->ATi X600 256MB
    -->17.0" WXGA+ Widescreen Display
    "History will be kind to me for I intend to write it."
    "Success is the ability to go from one failure to another with no loss of enthusiasm"
    - Winston Churchill -
    I am Xtreme
    Mar 2005
    Quote Originally Posted by MeTsU
    no disclosure agreement
    Mar 2005
    U.K
    Quote Originally Posted by wdrzal
    Thanks!
    I always feel like a fool asking, but you will never learn if you don't ask!
    What would a 1HP and R1150/R1270 mix get you? That's if I could get those gasses (South Africa).
    -->100GB HDD
    -->ATi X600 256MB
    I am Xtreme
    Mar 2005
    have you ever built a system?
    May 2005
    Quote Originally Posted by Sheograth
    Evaporators temperautre without load isnt quite what this guy is looking for if i understood right.
    You will need one damn big compressor or to make some kind of autocascade system. One stage -60c system with one compressor would stress the compressor pretty much too. Im not familiar with autocascade system yet but it seems very brilliant.
    Mar 2005
    U.K
    You asking ye_3333?
    -->100GB HDD
    -->ATi X600 256MB
    I am Xtreme
    Mar 2005
    You asking ye_3333?
    no you, is this your first system?
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    1150 is not a first stage gas. IIRC it requires a temp of 3C to condense.
    For those of you about to post:
    Mar 2005
    U.K
    Yes. But obviously you already knew that:
    Sorry, my bad...sorry about that guys.
    -->100GB HDD
    -->ATi X600 256MB
    I am Xtreme
    Mar 2005
    I just was going to bring up what I keep saying about over reaching, first it can be dangerious,second if your not familiar with a simple loop using a single gas your chances of getting a complex rig or mixtures to work right is small.
    Mar 2005
    U.K
    Ye...I think I was just excited, as I've been wanting to get into phase for a while, and now that it finally has become an option, I went in too deep.
    I'll proably try source a 1/2HP or 1HP compressor.
    Sorry if I've hijacked your thread ye_3333!
    -->100GB HDD
    -->ATi X600 256MB
    I am Xtreme
    Mar 2005
    to big a compressor will do more harm than good, remember its a system.While everyone talks about compressors and gases,every componate must match the others to work right.
    Xtreme Gentoo User
    Mar 2004
    England
    1hp is really the largest you would need for this sort of system. 1/2 maybe.
  18. #18
    Mar 2005
    U.K
    So, you guys would reckon a 1/2HP compressor should be fine. Coupled with what gas? R402? What sort of temps unloaded would I be looking at?
    -->100GB HDD
    -->ATi X600 256MB
  19. #19
    Mar 2005
    For a first stage, R134 or R290 (propane) should be easy to get. R134 comes in cans at the auto store, under $10 for a pound. You should get around -20 to -30C, maybe lower with a mix of the two.
  20. #20
    Xtreme Mentor
    May 2004
    Don't touch R134a. For a first build R290 should be good because it's very cheap, can be vented, is legal to get without any EPA certs, and can give you -40C easy.
  21. #21
    Mar 2005
    U.K
    Quote Originally Posted by craig588
    Ok, so R290 on a 1/2HP compressor should get me -40C idle or loaded?
    -->100GB HDD
    -->ATi X600 256MB
  22. #22
    Xtreme Mentor
    May 2004
    Idle. You need to play with R507 or R402a to get those types of temps loaded. (You need an EPA certifiaction to get those, they are also more expensive than propane)
  23. #23
    Oct 2004
    Birmingham UK
    personally 1/2 hp i think is overkill.. look at the vapo chilly! did up!
  24. #24
    Feb 2004
    Tucson, Az, USA
    Yeah a good system should be effcient and powerful. Thats I wouldn't go over 1/2, and 1/3-1/4 or so would be even better (IMO).
  25. #25
    Mar 2004
    NYC
    I think he's in South Africa, so EPA cert probably doesn't apply.
