Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Yet another UTT Death
    Aug 2004
    Well Im now absolutly convinced this issue is NOTthe Board.
    I have had a VX die on a DFI 3 board. Now 1 my 3 week old xp4000 redline has passed away.
    Never biosed flashed with these sticks.
    Never cold booted computer other than the first boot up.
    Never ran without Xflow Fan (stacker)
    Never ran without 90 mm Fan over the top
    Never ran more than 3.4 volts
    Never removed ram
    Never used 4v jp17, only jumper trick
    Woke up this morning and screen wasnt waking up, computer had frozen. rebooted, nothing!!!! removed the offending stick and here I am typing.
    I for one have had enough of UTT looks like I will go back to Ballistix, good mix between UTT and TCCD
    DFI Ultra-D
    X2 3800 Toledo 290x10 (1.39v) (not tweaked yet)
    2x 1GB Ballistix
    Sapphire X1950 256
    Seagate Barracuda 7200.9
    OCZPowerstream 520
    Custom water cooled
    version 2.0
    Feb 2005
    Flanders
    just let the 'bad' stick rest for a couple of days.
    then try it again , it might work again. I have seen posts here of bad UTT sticks come alive again.
    Feb 2005
    Denmark
    Why not go for BH5, or mushkin redline? (dunno if they are UTT thoug)..
    Playing station: DFI UT X48 T3R @ EK NB // Q6600 @ 3,2GhZ @ True (soon Dtek V1) // 280gtx (soon EK 280gtx) // 2*2GB Gskill 12800 CL7 // Corsair HX1000 // 250GB ES.2 - 160GB T166 - 2*160WD RE // Lian Li V2000B // Swiftech 240+360 - 2*DDC 1
    Servers: ASUS Crosshair // X2 3800+ // 2*1GB Gskill PC6400 HZ // R3650 // IBM workstation
    Laptop: Znote 4200, running on 5th year now
    Aug 2004
    Quote Originally Posted by teko
    look at sig
    DFI Ultra-D
    2x 1GB Ballistix
    Sapphire X1950 256
    OCZPowerstream 520
    Custom water cooled
    Jun 2005
    Netherlands
    redline is what died on him, and yes Redline does use UTT
    Mar 2005
    Imladris
    I'm quite sure Muskin will replace it free of charge since you've run the memory below 3.5v. People do get bad sticks...... don't give up just yet. The Redline stuff is pretty durable should you get a non-faulty stick.
    The little air system that could.
    Sep 2002
    Sydney, Australia
    are you still using the 5v rail for vdimm?
    May 2005
    may be warrentied up to 3.5 +- 5% but its still hard on the memory, 3.4v can kill it, but yea... let it sit and there is a good chance for it to come back to life
    Aug 2004
    Quote Originally Posted by ArcTan
    Forgot that
    I have Never Ran 4v j17, I used bigtoe jumper trick from day one
    DFI Ultra-D
    2x 1GB Ballistix
    Sapphire X1950 256
    OCZPowerstream 520
    Custom water cooled
    Aug 2004
    Quote Originally Posted by HousERaT
    Tis rather early to be saying that, if you look at the mushkin threads there is more and more ppl saying they have dieing sticks. Remember the VX took awhile before we started seeing deaths.
    DFI Ultra-D
    2x 1GB Ballistix
    Sapphire X1950 256
    OCZPowerstream 520
    Custom water cooled
    Aug 2004
    Quote Originally Posted by 13oost
    Well I ran 3.6 through my old BH5 24/7 for years, wish I never soldem
    DFI Ultra-D
    2x 1GB Ballistix
    Sapphire X1950 256
    OCZPowerstream 520
    Custom water cooled
    Feb 2005
    Denmark
    Quote Originally Posted by jiff
    look at sig
    My bad But then why not BH5?
    May 2005
    yea seems that bh-5 hasnt had these problems, but exactly how many bh-5 deaths have there been with these boards, on the "new" and old bh-5
    Aug 2004
    Well theres no way that this death or my VX can be the board,
    VX on DFI 3
    I didnt use 4v jp17 on this Ram, I never cold booted, this ram died failed while PC was on.
    I will wait and see how many deaths we see using jumper trick, I bet we see just as many. Ppl are killing UTT with boosters on other boards.
    DFI Ultra-D
    2x 1GB Ballistix
    Sapphire X1950 256
    OCZPowerstream 520
    Custom water cooled
    May 2005
    some/alot of the reason that they kill the UTT on other boards with a booster is b/c they dont calibrate the booster before they use it, so theyre craming way more voltage than they think they are...
    j/w how many "deaths" have occured on bh-5
    Feb 2005
    USA
    at 3.4v these memory still can be smoking hot, I was running 265 @3.5v the other night and I have a Thermaltake 4800rpm (75cfm!) fan blasting on my redline at full speed but after an hour of 3dmark loop the heatspreader were still kinda hot..especially dimm 4 right next to the cpu, make sure you have sufficient cooling on these ram but if they still died atleast we would know heat didn't causes it.
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
    Aug 2004
    Quote Originally Posted by ben805
    Well if you have ever seen/used a stacker with xflow flan on full blast and a 90mm Fan sitting on top you would know heat was never an issue
    I have indeed ran S&M memory test, touched heat speaders which were cool after 4 hours. The machine was on idle at the time of failure.
    Waiting for mushkin to come back to me on this, I would prefer a refund I have no confidence in UTT chips, my guess is UTT products wont be around that much longer.
    DFI Ultra-D
    2x 1GB Ballistix
    Sapphire X1950 256
    OCZPowerstream 520
    Custom water cooled
  18. #18
    Feb 2005
    Please check my thread about UTT chip ... http://www.xtremesystems.org/forums/...d=1#post912487
    It's quite possible that not all the UTT chip will fail that quickly , but apparently those
    quickly failure chip are not sorting out before they put onto the module ...
    And what we see now is a typical UTT module failure syndrome , that's why
    the UTT chip is cheap ... All the failure case will be treated as RMA issue ...
  19. #19
    Aug 2002
    London,Uk
    utt describes not one chip but several. thats the first thing to mention, you have untested CH-5 mem afaik, thats whats in vx and redline. UTT is not a product, old bh-5 was supposedly rated to 3.6v, the chips, not the pcb's or resistors or anything else. the chips in some circumstances were rated like that, i never heard ch-5, on a smaller die process, was rated as such. its completely up to the companies to decide to charge more, make a profit even with any multiple rma's they have to deal with. you've still bought a product that will run as advertised, and they will replace it, that hasn't changed. if rma rates get too high they'll change price or stop offering it.
    very much more than likely the reason vx and redline are on ch and not bh dies is this, the idea behind these chips are cheap as possibly with decent yeilds, on same sized waifers you'll get far more chips on a smaller process.
    Mail Me | 3500+ , dfi sli-dr, g-skill la, 2x6800gt, 600w pcz, stacker case, air cooled
  20. #20
    Feb 2005
    Quote Originally Posted by drunkenmaster
    If the root cause of the whole thing is UTT , not what kind of UTT ... That explain the situation we see now perfectly ...
  21. #21
    XS_THE_MACHINE
    Nov 2004
    Long Island
    did u have a fan over them???
    "Victory is always possible for the person who refuses to stop fighting"
    clicks to save kids
  22. #22
    Jun 2003
    hmmm
    The chips in question are UTT-CH..... new CH production using some changes from Infineon that yeilded a VAST improvement over OLD CH5 chips.
    The "UTT" part refers to noone bothers speed sorting the chips. The BH or CH refers to what the chip actually IS. There is a world of difference between UTT-CH and UTT-BH even though both are "winbond" chips.
    The new UTT-BH chips are better than the old BH, and the new UTT-CH chips are even better'r
    But we have seen alot of UTT-CH dying.... partly because they need high Vdimm to shine, and get it, and croak. Partly because the are UTT... un sorted and the weak chips dont get ferrett'd out of the bunch before use.
    One hopes something like 4000VX and Redline 4000 would get the extra effort of UN-UTT'ing the chips before use. After all, what exactly are oyu paying EXTRA for if not sorting out the best of the best in chips before hand.
    But we apparently wont have UTT-CH to kick around anymore as its supply has dried up.
    The 8Gigs of it I fielded are all working flawlessly....except my 2 sticks with "high voltage" lockup problem. Im still hoping its the SPD rom that is the actual culprit. The other sticks are happyily running on 3.25-3.45Vdimm systems from NF7-S to DFI Infinity to DFI NF4 SLI-DR.
    As for CH, they have the same ABS MAX rating in the data sheet as the BH chips... 3.6V.
    GA-MA790GP-D4SH, 965BE, 3.8Ghz
    Ultra120E, 4x2G Gskill 1066
    2x 150G VRaptor raid, WD640AALS
    8800GT 735/940/1685, LG-BluRay
  23. #23
    Feb 2005
    Put your UTT in the freezer, im not kidding. Leave it in there for a few weeks and it should be back to normal.
    Ballistix seems pretty sweet though. 285 at near UTT timings, sounds good to me.
    How have BH6 been holding up with high voltages? Friend of mine will loan me his Mushkin Black BH6 and he says it will do 260 no problem. Any reports of those dying?
    AMD Athlon 64 3000+ NewCastle @ 2450mhz (245x10)
    OCZ PC3200 Platinum (2x256) @ 225mhz 2-3-2-5 [retired]
    Corsair PC3200 TwinX (2x512) @ 245mhz 2-3-3-10
    Seagate 250GB 7200.8 SATA
    Soltek SL-K8AN2E-GR - nF3 250
    Antec Neopower 500W
    ATI Radeon 9800Pro
  24. #24
    May 2005
    bh is on a 150nm process and the ch is a 130 if i remember correctly.... smaller process pretty much equals less tolerance to higher voltages and heat
    ive also hear that the CH chips are thinner and circuits are closer to the surface, but i just remember seeing it mentioned... im not swearing on it
    why dont they try putting CH on a larger process like on the BH? it might not be CH then, but if its the same construction then it should preform better and have better tollerances
  25. #25
    Aug 2004
    Quote Originally Posted by uscfan
    I would do if it wasnt under warranty, mushkin have just ok a RMA with faulty stick. I guess I will stay with the Redline until it fails then RMA AGAIN and AGAIN
    DFI Ultra-D
    2x 1GB Ballistix
    Sapphire X1950 256
    OCZPowerstream 520
    Custom water cooled
