E6 Step
Socket754
0.09
Voltage 1.4
add X86-64
E6 Step
Socket754
0.09
Voltage 1.4
add X86-64
sweet, i have seen these on sale around the UK, here is one instance : http://uk.insight.com/apps/productpr...04BF7&src=FRO1
could this be it out already? or are they soon to release. And also, how much will that 128k cache kill performance?
P.S. im placing a bet that these can o/c to 2.7G+ or air![]()
Great news for our budget overclockers
128K?! sheesh! thats going to kill performance enormously!
Opteron 170 @ 3.0Ghz on air, Opteron 144 @ 3.1Ghz on air
suprisingly it doesnt, i was playing with a 128k semp the other day and was very suprised by what it could do, its certainly a celeron beater even at 128k
Opty 144 0546FPMW @ 2.8ghz
MSI K8N Neo 2
2 x 512mb OCZ Platinum Rev. 2 TCCD
ATI X800 Pro @ 570/1200
Plus some other metal fings...
Will do me till Conroe
Heat
I wonder if running in 64bit mode takes up more space in the cache? 128KB could be more of a limitation with 64bit than running 32bit?
The same problem would affect the new 64bit Celerons, of course.
I think L2 cache doesn't really have a great deal of impact on performance, this is a smart move by AMD. Would those be available in 939?
It is indeed. Some of the tests on overclockers.ru prooved it.Originally Posted by CNCL
p.s. 128kb cache processor has an increase over 256 kb, cos it`s based on DO(90nm) stepping. Others are on CG (130nm).
As you see only WinRAR performance is very dependent on cache size.
P.P.S. It surely is Sempron 64. CPU-Z couldn`t show it`s revision, cos CPUID changed (00020FC0h -> 00020FC2h)
Hmm that's a very interesting chart, Cooper! Maybe that will give me new insight as to whether sandiego's extra 512kb cache is really worth its price tag.
not certain, but i am fairly sure your fear is correct.Originally Posted by Rave
also, cache may not do much for benches, but i'm convinced it helps responsiveness and multitasking a lot
Got a fan over those memory sticks? No? Well get to it before you kill them
Hey sxs112, try this version of GCPUIDOriginally Posted by sxs112
http://www.thecoolest.zerobrains.com/apps/GCPUID64.zip
Member of Overclockers.com Folding @ Home team
"<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
Main rig:
AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
Secondary rigs:
Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
lol check ur sig, it's got 128k l2 cache to begin with lol, anyways yes this chip WILL stomp a celeron, not to[:banana::banana::banana::banana:yness] brag but, i'm sure i could hand it to the best of the celeron d's @2350 mhz quite easily....[/:banana::banana::banana::banana:yness] i've seen celly's @ 4000+mhz doin' pi in 40+ secondsOriginally Posted by Jamo
mobo: strix b350f
gpu: rx580 1366/2000
cpu: ryzen 1700 @ 3.8ghz
ram: 32 gb gskill 2400 @ 3000
psu: coarsair 1kw
hdd's: samsung 500gb ssd 1tb & 3tb hdd
128k is understandable. Seems to be the tradeoff for the 64-bit featureset. Ideally the 0.09k should mean it overclocks well. Though the only thing that's certain with these is that Celeron P4s are gonna get a proper kick in the pants in the official reviews --- which would be a pretty big issue, if this was "ValueSystems.org"LOL j/k.
EDIT: And ofcourse, LETS NOT FORGET TO THANK SXS112KEEP UP THE GOOD WORK
Perkam
don't insult my value system, lol
mobo: strix b350f
psu: coarsair 1kw
Too Bad! I just got my 939 3 months ago. If I know there will be a 64bit Sempron, I am sure that I will wait for the release.
OK, I have a try ofOriginally Posted by The Coolest
thanx sxs i knew it was comni' but thought it was 3rd quarter????
mobo: strix b350f
psu: coarsair 1kw
intel forced them to do it earlier.Originally Posted by i found nemo
Seem at present, come on stage in mid-July soon, come on stage there will be 2600+, 2800+, 3000+, 3100+ and 3300+,etc..Originally Posted by i found nemo
how about a screenshot of GCPUID?
Main rig:
Secondary rigs:
actually its a 512k newcastleOriginally Posted by i found nemo
not a sempron, a quick clicky on my 3d marks would have told you more
i think these are going to be quite nice chips, hope they oc well to blow intel even more out the water
MSI K8N Neo 2
Heat
Updated the public setup file to the latest build, 1.9.0220:
Main rig:
Secondary rigs:
Good God...its a venice omglol
That's some bang for the buck.
Perkam
haha, L1 and L2 caches are the same size. for some reason i find that funny.
Those graphs of differences by cache size are very interresting. doubling cache seems to provide linear increases in some places, but not everywhere (like 01se)
Rev E A64 are either a Venice or San Diego.
There are two revisions of Venice now, the E3 and E6, the E6 is just a new revision.
It also has a really odd BrandID number, I wonder why is that.
This chip has a higher Version mask, the "Version: 4.2" part. In AthlonXPs it usually represented a better clocking chip.
Give it a try, see how far you can push this thing!
Main rig:
Secondary rigs:
