" Model numbers 3800+, 3500+, 3200+ and 3000+ in socket 939 only will be affected by the new revision change from E3 to E6.
The E6 revision is pin to pin compatible with the current E3 revision, and will function in existing platforms based on 939 pin AMD Athlon(tm) 64 processors, but a new BIOS will be required to recognize the new CPU ID (Current CPU ID will change from 00020FC0h to 00020FC2h).
This new revision is expected to start shipping from July 15th 2005 and the marking of the affected model numbers will change as shown below:
MODEL NUMBER PREVIOUS PIB REF NEW PIB REF
3800+ ADA3800BPBOX ADA3800BWBOX
3500+ ADA3500BPBOX ADA3500BWBOX
3200+ ADA3200BPBOX ADA3200BWBOX
3000+ ADA3000BPBOX ADA3000BWBOX
Source: AMD email.
There will be new E6 revisions in socket754 models too.
The mail doesn't says about changes in this E6 revision.
