Helo
I have problem with modding my p4p800, pcb looks a little bit different.
and my pcb
any ideas?
Helo
and my pcb
any ideas?
btw, here are specifications of this chip
http://www.analog.com/UploadedFiles/...1ADP3180_a.pdf
pdf says that max output voltage is 1,6v (i cant set over 1,6 in bios)![]()
My mobo have 3 mosfets on each phase.
Follow through this thread, it has the instructions. I have the same as you and followed this and all is well.
http://www.xtremesystems.org/forums/...e+deluxe+droop
-=j0nnyr0773n=-
Maximus IV Extreme-Z | 2600k @ 4.7 (1.420 vcore) | 8gb G.Skill RipjawsX 2133mhz | Noctua NH-D14 | GTX 460 | Corsair TX750 | Rocketfish Case (highly modded) | Samsung SyncMaster P2770
Here. 28kohms between the points.
wat is the Vdimm read point on this mobo??Originally Posted by Malves
many thanks in advance, shigs
The fet I circled on the far left side of this picture. Grab the voltage off the leg on the top left of the fet.wat is the Vdimm read point on this mobo??
-=j0nnyr0773n=-
Here you go, bro.Originally Posted by shigs
See top right side of pic.
nice 1! thanks malves and also thank u j0nnyr0773n![]()
shigs
is that the same spot to measure the vdimm on a p4p800-se? the vdimm mod seems to be the same. also what about connecting the 3.3v line straight to the corresponding pin on the rear of the board? good, bad or fugly?Originally Posted by Malves
thanks
sky / s!p - we are oldskool, dammit.
Yes, should be the same for the SE. I don't like 3.3v to vdimm line mod.
thanks!
i don't like the 3.3v direct thing as well, it's just easier to do. spent a good amount of time trying to solder to the lm358 .. i guess i'll move to grabbers before getting a hotair soldering station.
THX to Malves and j0nnyr0773n, mod works good.
before mod:
1,296-1,392v = 0,096v difference
after mod:
1,408-1,440v = 0,032v difference
I'm happy with these results.
is there a vcore mod for this mobo?
this is a pic of the p4c800-e deluxe vcore mod...
does this mod apply 2 the p4p800-e also as im tryin2 get higher than 1.6v on my dothan 730![]()
Yes, it's the same mod. 50k from pin 8 of ADP3180 to ground.
n1 thanks mateOriginally Posted by Malves
last bit of info i need on this mobo, where can i take a readin for my vcore? ive done the vcore mod and asus mobo does not report over 1.6v in bios so i need 2 take a vcore readin from the mobo its self
any1 kno....... malves![]()
shigs
