Results 1 to 13 of 13
Thread: 2 separate loops in ex-Koolance case
    Sep 2004
    This project is finally complete, I hope. I have been redoing it for over two years now, just can't give it up / leave it alone. There's always room for improvement, right guys/gals?
    Brief description of innards:
    Loop #1 for XP2500+ @2500MHz: Laing D4 + Proteus flowswitch + DD Maze 4 + Black Ice Pro II + Dual 3 1/2" reservoir
    Loop #2 for GF5700U + northbridge: Hydor L25 II + DD Maze 3 GPU + DD Maze 3 northbridge + ThermoChill HE120.1 + custom reservoir from Home Depot
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Hey, wait I think I see room for one more thing !!!........Nope, no more room ! hehe
    Looks great m8, good work !!
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
    Apr 2005
    Windsor, Canada
    One word; COOOOOOOL!
    Usama aka Ferrari Freak
    Quote Originally Posted by jimmyz View Post
    A DFI board is like a divorce, expensive, but well worth it.
    Quote Originally Posted by virtualrain View Post
    I dunno... I think a DFI board is more like marriage... demanding, time consuming, and a PITA but rewarding in it's own twisted way.
    Mar 2005
    Nice work. How long does it take you to swap out the CPU or HD?
    Sep 2004
    Swapping parts is not permitted! Haha, you guys probably have a good idea of the computer / cooling parts density per cubing inch!
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    ok now that is just scary.. how u compacted that all in there i will never know...
    but hey it looks cool. Im curious by how much that flow meter in there drops the flow rates. You got any numbers on it?
    Feb 2004
    Tucson, Az, USA
    Damn thats my case and setup! (Though I just did one rad and stuck the pump under the bottom drive bay).
    Nice work!
    Sep 2004
    Regarding flow rates, I just reorganized the tubing and used several 45-degree angled 1/2" ID fittings to eliminate a lot of extra loops and possible kinks, and the flow rate did not increase at all, as measured by the flow switch. So, that leads me to conclude that even with an inefficient supply of water to pump's inlet, it was still doing all that it could, since now the path to pump's inlet is a slightly upward-sloped 3" long piece of tubing that should be less restrictive than an entire loop 5" in diameter with a 90-degree bent in the middle! Following the same reasoning, introducing the flow meter into the loop did not significantly drop the flow rate.
    Aug 2004
    Los Angeles, Ca USA
    interesting....
    Jun 2004
    USA, Vermont
    NICE SETUP THERE MY FREIND!!!
    What are ur temps?
    Dragon
    http://smbach.com/mad.gif
    Opty 175 Rig
    Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
    AM3 Rig
    Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
    DFI NF4 BIOS Guide
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    i dont think i would want pumps so close to my cpu. me thinks there could be EMI problems???
    looks good though. very cramped.
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
    Sep 2004
    Since the rad for the CPU loop is cooled by 3 measly 80mm fans working at 40% power, the temps vary dramatically depending on the ambient room temperature. Idling at 2500MHz, 1.75Vcore, they can vary 38-45C.
    Regarding EMI from the pump, I'd think the big slab of copper would absorb most of them.
    Thank you all for the compliments / comments.
    Xtreme Recruit
    Dec 2004
    Looks stuffed, but still good
