Hi all .
Last days i decided to build a small chilly for 24/7 use . Quiet Easy to use and compact , was the target .
Lets starts from the case .
4 pieces [67X27cm] and another 2 smaller [27X27] of plexiglass . Cutted 3X holes for 12cm fans [2in and one for exhaust] , and mounted whells [from my cm stacker ] .
The floor of the case dressed with 1cm silver color insulation to avoid the noises of waterpump and compressor .
another one
The main rig .
Compressor 1/6 from my old home fridge .
condeser and heatex. comes from Unseen
water pump [eheim1250] & water block [silverpro cyclone evo ] from my previous watercool setup
The system ready and tested
A quick test with laser thermometer .
