http://anandtech.com/tradeshows/showdoc.aspx?i=2431&p=7Originally Posted by Anandtech
I'm interested in the performance of AMR,Crossfire,MVP, whatever you want to call it, against Nvidia's SLi technology, looks promising.
when is it coming out!!?
Mobo: MSI P35 platinum
CPU:e8400
Mem: 4x512mb Patriot fatbody
Vid Card: 8800gts 512mb
Cooling: Thermalright 120 ultra
HD's: 80x2 raid and 320gb
Case: cooler master cm690
yes!
awesome layout!
I am so excited!!!!!
You know its almost the same as the SLI-DR...
Still, it is an interesting layout. It seems very well done. Typical of DFI.![]()
odd having the dimms on the other side, wonder what thats about
"each driver release plays whack-a-mole with a few more annoyances" -inq
I'm *really* not liking that layout, seems like the cpu/ram is out of the way of direct airflow. Also, with the ram sticks being above the normal spot for exhaust fans, that heat is going to go up instead of out.... Just doesn't seem like they put much thought into air-flow on this board.
Of course, it IS DFI, so they probably know there's gonna be a fan on every hotspot anyway once we get our hands on them anyway. I just have my worries on this one.
looks nice, the ram and cpu placing is a little worrysome but if i get this is will be watercooled so ill only have to worry about putting a 120mm fan over the ram. I also like the fact that the picexpress 1x slot wont be covered even by large vga cooling setups.
Edit- is that 8 sata ports i see,![]()
This is a little weird, considering on EOCF the thread posted stated that most boards with 2x pci-e 16x slots for sli will work for amr with just a bios update and the purchase of a master-card.
If you have a cooling question or concern feel free to contact me.
i thought crossfire needed the ATI chipset to work, maybe im wrong.
AFAIK it does require the ati chipset. I'm pretty much positive NVidia will block ATi's cross-fire from working thru the NF4.
www.ati.com its launched.
Perkam
http://www.ati.com/products/crossfire/faq.html
LoL ATI is just saying that in the nforce question because they dont wanna support their competitor. If it works on intel chipsets then it will work on other things as well. Also it says PHYSICAL x16 slots, the inquirer(http://www.theinquirer.net/?article=23569) was at computex and confirmed the intel part and the x8/x8 part for non believers still.Originally Posted by ATI
holy crap, no wonder their "crossfire" will be cheaper than SLI!!, well hopefully ATI will give us some good reasons to go with their chipsets vs. nvidia. hmm, sense sli wont be needed(only need 2 pci-e x16 slots), the dfi nf4 ultra would be perfect! well ATI definately out did NVIDIA, no wonder they where in such a hurry to go intel
edit:hmm, i wrote no wonder way to many times
Originally Posted by R.Rabbit
u still have to mod ur nf4 to sli and set the jumpers to 8x/8xOriginally Posted by Anandtech
well atleast you wont need a sli bridge
sli bridges are easy to get :P
Ready:
AMD Athlon 64 San Diego 3700+
DFI LanParty NF4 SLI-DR
1Gb Mushkin Redline XP4000
Hitachi 250Gb SATA II
Built by ATI Radeon x800XL
Antec NeoPower 480W
