Page 1 of 2 12 LastLast
Results 1 to 25 of 48
Thread: Can't overclock in Windows SP SP2? Try this!
    Feb 2004
    Talking Can't overclock in Windows SP SP2? Try this!
    OK, I am posting this at various forums so apologies if you've already seen it, but it could be the key for AMD64 users to get higher clocks in XP SP2. (It may be a Venice issue, it may be a DFI NF4 issue, or it may be all AMD64s).
    Originally in this thread:
    http://www.dfi-street.com/forum/show...3&page=1&pp=15
    Solution here:
    http://www.dfi-street.com/forum/show...098#post121098
    Story:
    Basically, no matter what I did, I could not get the same clock in XP SP2 as I could in Win2k or WinXP SP1a. It (SP2) was OK in Safe Mode, just not normal mode.
    In 2k and XP SP1 I could clock up to 9 x 324 (2.9 Ghz)
    In XP SP2, I could barely hit 9 x 300 (2.7 Ghz) and that was with a different HAL.
    Turning off DEP solved this for me:
    Edit the Boot.ini and change the switch:
    /noexecute=OptIn
    to
    /noexecute=AlwaysOff
    (watch capitilzation).
    Many thanks to the people in that DFI Street thread!!! (I named them in my post over there).
    HTH others
    Jimbo
    :: 3DMark01=66,732 :: 03=71,879 :: 05=26,413 :: 06=18,772 ::
    Dec 2004
    Atlanta
    I also noticed a lower max OC in SP2. Thanks a lot for this I'm going to try it now!
    Nov 2003
    Thanks for sharing the info!
    I'll be sure to give it a try if I find any problems O/C'ing my A64 system.
    Any idea on what DEP does to get in the way of the O/C?
    P4C800E DL,P4 2.4c @ 3.4(droop mod),1G Mushkin 3500 II 2,2,2,8 @ 3.1v,AIW 9800 Pro (450/370 @ 1.9v core),Audiology Platinum,2xDiamonds 8mb Raid0,Lian-Li Pc70,PC P & Cooling 510D,Plextor 708A,Plextor 52x32x52...water cooled...
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thanks for sharing .. will try
    Mar 2005
    UK
    Looks interesting, will give it a try! Anyone else tried it yet and got an improved OC?
    My Athlon64 System:
    A64 3200+ (0517 GPBW) - 270x10 @ 1.52v
    Stock HSF - Idle: 33/28 & Load: 48/33
    MSI K8N Neo2 - 0506 Taiwan, 1.B Mod bios
    Patriot 1GB PC3200 - 270mhz @ 2.5-3-3-8 @ 2.70v
    Inno3D 128mb 6200- 500/640mhz (3d'01 - 20.3k & 3d'03 - 7.7k)
    120Gb HDD 7200rpm, 8mb cache
    Colors-IT 550w PSU - 3.3v @ 3.34v / 5v @ 5.02v / 12v @ 11.80v
    Optical: Ltd-166s / NEC-3520A / Ltr-48125w / Px-R820Ti
    My Site - you might even learn something!
    Memory Addict
    Aug 2002
    Brisbane, Australia
    so you did all 12 steps
    Disabling DEP system-wide using boot.ini
    1. Click Start, and then click ControlPanel.
    2. Under Pickacategory, click PerformanceandMaintenance.
    3. Under or Pick a Control Panel icon, click System.
    4. Click the Advanced tab, and in the Startup and Recovery area, click Settings.
    5. In the SystemStartup area, click Edit.
    6. In Notepad, click Edit and then click Find.
    7. In the Findwhat field, type /noexecute and then click FindNext.
    8. In the Find dialog box click Cancel.
    9. Replace the policy_level (for example, "OptIn" default) with "AlwaysOff” (without the quotes).
    WARNING: Be sure to enter the text carefully.
    Note: Your boot.ini file switch should now read:
    10. In Notepad, click File and then click Save.
    11. Click OK to close StartupandRecovery.
    12. Click OK to close SystemProperties and then restart your computer.
    Aug 2003
    FunLand
    I think the 12 steps actually do exactly the same as changing the boot.ini file manually.
    PTK
    Intel Core 2 Duo E6000 @ 3.6Ghz
    Asus P5W DH
    4x1GB PC6400 Rhino 4-4-3-9 1:1
    2x74.3GB Raptors + 300GB Maxtor 16MB
    Sapphire Radeon X1900XT 512MB
    Oct 2004
    Melbourne, Australia
    Isn't that a reasonably important sercurity feature?
    Feb 2004
    Quote Originally Posted by jlccarv
    No.
    I wouldn't say so. It's not in 2kPro or SP1.
    When have you seen DEP asking you whether you want to run something or not?
    I'd rather have a 2.9 Ghz CPU and DEP disabled than a 2.6 - 2.7 Ghz CPU with it on.
    Anyway, is this XtremeSystems or what?
    Feb 2004
    No.
    Quote Originally Posted by eva2000
    PTK is correct.
    Just edit the boot.ini file
    Mar 2005
    Houston, TX
    What does it do?
    If the command change just decreases the security of Windows Firewall, then ts worth it
    You can just get a better one from Zone Alarm, but you have to pay tho
    Turok
    Banned
    Mar 2005
    If it is somehow getting a lower OC with it on, doesn't that mean that it may be unstable at other things at the higher OC?
    Jan 2003
    Leicester UK
    I just disabled it on Win XP 64 bit, see if it helps me at all
    Feb 2005
    Palm Beach, FL
    No results with this yet I see. Well, I've always considered myself a beta tester to the
    most extreme degree...I'll see if my CPU walls at the same speed, with DEP disabled.
    CPU AMD Athlon64 Venice 3000+ @ 2.7GHz
    MTB DFI Lanparty nF4 UT @ 300MHz/900HTT
    RAM 1x512MB Corsair TwinX PC4400 @ DDR600
    HDD 2x36GB WD Raptor R-1 // 3x80GB WD S.E.
    VPU ATi Radeon X850XT Platinum Edition @ 602/618
    DVD NEC 3520A 16x DVD-RW
    PSU OCZ PowerStream 520w
    AUD Creative Audigy II
    NFO 9x300 ]|[ 1.55vCore - 2.9vDIMM ]|[ 2.5-4-3-7 ]|[ 1:1 1T
    3DM 01: 30208 03: 14449 05: 6918
    Rig revision in da workz: Opty 148, 1GB PC5000(Need 2GB but none are fast enough.), Another X850 to go crossfire, and W/C from the den.
    Feb 2005
    Palm Beach, FL
    I'll be damned. It worked. I'm no longer walled. Best PI ever, so far.
    This is by no means the limit, I'm still pushing it.
    Jan 2003
    Leicester UK
    hmm, I guess I better get pushing then :P
    Nov 2004
    DK
    What is DEP anyways? Anyone care to explain?
  18. #18
    Feb 2005
    Palm Beach, FL
    Max prime/gaming/pi/bench stable so far: 9x311 (2799MHz)
    Quote Originally Posted by stryg
    Data Execution Prevention. It's a piece of code in Windows that takes advantage of DEP enabled hardware such as A64 processors to provide the system (Windows) with the ability to prevent known malicious code from being executed. This protection also blocks against many older and more primitive viruses.
  19. #19
    May 2005
    Sweden
    Quote Originally Posted by TekXoID
    I think a good antivirus will do the same trick
  20. #20
    Feb 2005
    Palm Beach, FL
    Quote Originally Posted by ettis
    Yeah, but it's more like a resident malicious code execution prevention that was intended to have no effect on the processor,
    but obviously it taxes something inside the CPU if we are all pulling out an additional 50-150MHz by disabling it.
  21. #21
    XSDCMF
    Nov 2002
    Las Vegas Nevada
    After googling, I found this info on DEP...
    http://www.microsoft.com/technet/pro.../sp2mempr.mspx
    and
    http://www.microsoft.com/technet/sec.../depcnfxp.mspx
    In this latter section MS says "The default configuration of DEP is designed to protect your computer with minimal impact to application compatibility. However, depending on your DEP configuration, it is possible that some programs might not run correctly. You can use the tasks described in this document to configure DEP on your computer:
    • Enable DEP for all programs on your computer
    • Add programs to the DEP exception list
    • Disable DEP for your entire computer"
    When they refer to some programs not running properly ( possibly ); I'm wondering if that same hindrance gets in the way of an OC.
    Also, where the article speaks of hardware NX or data execution prevention, is it desirable and/or even possible to turn that off in the processor?
    edit - also here:
    http://msdn.microsoft.com/library/de...prevention.asp
    another site's info on DEP - http://antionline.com/showthread.php?s=&threadid=266741
    and the google search results for "DEP":
    http://www.google.com/search?hl=en&l...f&q=DEP+%2B+XP /edit
    Crunching to Crush Cancer
    Somebody, Stop Me!
  22. #22
    Feb 2004
    Yay!
    You too have a 3000+ venice and DFI NF4......
    Hmm, I wonder if it's a Venice or DFI thing then........
  23. #23
    Feb 2005
    Maine, USA
    I turned it off and saw no o/c improvement. Still stuck @ 2.9GHz.
    FYI, to confirm DEP has been turned off:
    • right click My Computer and select Properties
    • under the Advanced tab select the Performance Settings button
    • under the Data Execution Prevention tab the options will be grayed out
  24. #24
    Aug 2004
    Did nothing for me 2.9ghz still my chip max, cancel that Im now NOT stable @ 2.9ghz. turning that back on
    DFI Ultra-D
    X2 3800 Toledo 290x10 (1.39v) (not tweaked yet)
    2x 1GB Ballistix
    Sapphire X1950 256
    Seagate Barracuda 7200.9
    OCZPowerstream 520
    Custom water cooled
  25. #25
    May 2004
    Wellington, Kansas USA
    Sticky!
