Results 1 to 12 of 12
Thread: ASUS K8N Vcore mod
    Oct 2004
    POLAND
    Red face ASUS K8N Vcore mod
    hi again
    i`m back with fresh mod for ASUS K8N, it was done as "remote control" coz one of my friends (OCMaster) start FC and still wants more and more...
    he can`t find reday solution on web so decide to ask me ...and here it is:
    On this asus mobo Vcore section has 3 phases, master divider is ADP 3166 [pdf] produced by Analog Devices, his slaves are 3 smal chips ADP 3418 [pdf] (one for phase) also by Analog
    The 3166 can take 4phase system so...
    As you can see mod depend on solder between pin 8 of ADP 3166 and GND wires with conected VR (best is 50k), (pin 8 -> FB is used for sensing and controlling the output voltage) Raising from max (50k) to min resistance geting higher Vcore voltage. For max VR value vcore should be boosted around ~0.06V
    Maybe the OCP mod will be needed, now everything works fine
    I can post only teory pic, OCM borow his dig to grandparents :p
    here can see chips and read point:
    original here: art on Hardtech.pl and here: forum of coz in polish :p
    enjoy
    offline, mail only
    Mar 2005
    france
    Hello, the component adp3166 has a security has part of 2V. I have
    reussy has to increase the vcore has 1.95V with this same chart.
    With a resistances of 25kohm
    Oct 2004
    POLAND
    you cen`t get more than 1.95V correct?
    propably the OCP mod is needed, i`ll try to find way for pass this ...but maybe tommorow.
    btw, i find now Persivore who have done this first while ago here
    offline, mail only
    Mar 2005
    france
    sorry but I am French and I does not include/understand perfectly
    what you said. My vcore is well has 1.95V by connecting pin 8 has the
    ground with a vr of 25kohm. The maximum of the component is 2V.
    After it y' has cut the motherboard. would find You here the necessary
    one : Vdimm, Vchip, Vldt, and Vcore
    3400+ @2840mhz with 1.87V
    Mar 2005
    france
    what the OCP mod?
    Oct 2004
    POLAND
    spox, im polish so... also have problems
    OCP -> OverCurrentProtection
    nice theard :] I will try to find solution for this problem
    offline, mail only
    Mar 2005
    france
    2V should not be exceeded. Is this that which you wanted?
    Oct 2004
    POLAND
    yes "should" that`s only teory.
    I can tray do it, but not test it, can work only remote for other users with this mobo
    offline, mail only
    Apr 2005
    Thanks guys
    That's what I need
    I finaly found one
    Mar 2005
    france
    hello
    has you make all the MOD?
    Apr 2005
    Not yet, I need de pots now and then it would be fine
    But one question: is de "Read point on missing + cap" the point where I can test the voltage?
    Mar 2005
    france
    hello, i'm french...
    http://www.amdhardware.com/phpBB2/viewtopic.php?t=4525
    the vcore is visible since the bios
