WELCOME TO MY GALLERY![]()
This thread is an extention of the "Water Cooling Questions" thread I made before.
This thread shows images of the PC that was under construction in the "Water Cooling Questions" thread.
There are a total of 47 images
The project sarted with a month of reserch in January (2005) and 4 months of building and buying from Feguary to May (2005)
This is my first time using a WC solution. Im planning on upgrading to a better pump or dual pumps and a WB for the GBU and maybe
the chipset if I find a good 1/2 OD block
Please, dont rush through the picks.
Scroll sideways on sections with 3 pics in a row, and enjoy your visit![]()
Time Line
Before it all started
These images are sketches I made on Photoshop where I try to replicate what could be my future PC.
I didnt have any parts at that time, I just had a vision![]()
My main objective was to make a WC solution where I dont have to mod my case and can peform really well.
Scroll sideways, TWO images in a row
First Progress
Here I get my Lian-Li PC-65B and start putting the Xoxide red Aluminum fans.
I made a sketch too to see how it would look like when its done (crappy sketch tho)
Now we are getting somewhere
Here I start to get the rest of the pieces, so i start to build my PC
You can see that I sleeved everything, even the chipset fan![]()
"No UV, no fun"![]()
I also put the fan with DFI aligned with LanParty on the user manual![]()
Check out Halo 2 on my PC in S-Video and Digital Audio.
I may put the PS3 there in the future![]()
Scroll sideways, THREE images in a row
The next group of images is the finished product
Front
I made it so you can see the difference when the lights are on and off
Back
In the back part, you can see that I have a black thing where external mobo connections go.
What it is is a piece of cardboard wraped in black duck tape and I just made it to the size and opened some holes. Everything I dont need is blocked and the only thing open is the Ethernet plug with the 2x USB below it and a hole above it where the tubes exit. Simple solutions to prevent modding my case![]()
Inside
I took pics of the side pannel window with the following light mods
1) When all CC lights are off
2) When only CC UV is on
3) When only CC Red is on
I usually leave the UV on and I have the red in CC mod so my subwoofer can flash it when there is a beat
Cables and Stuff
Here you can see all my messy cables and some other stuff.
The stuff are a power isolator that protects my stuff from strong surges (like thinder) and it filters my power (jsut a extra bonus there), I also show my MX 518, Deck Fire keyboard, Xtrac Ripper XL mouse pad, Xbox controller, Speaker controller, water supply :P:, Modem, and Xbox connection of Digital audio and S-video.
PC Screenshot
Here is a screenshot of the screen shown in the pics where the PC is done
If you ever wonder why my desktop is in spanish, its because its a Win XP Pro (spanish version)
Scroll sideways, ONE large image in a row
If you like a image and would like to see it in a higher resolution, just tell me.
Turok
