Results 1 to 8 of 8
Thread: Ati silencer 4, Vs Zalman VF700 cooler
    Apr 2005
    NH
    hmm, anybody know which produces the best temps out of these two?
    Xtreme Mentor
    Oct 2004
    Cleveland OH USA Bored?: You Know It
    use the forum search button, there is a thread identical to this one in the air cooling section.
    Apr 2005
    NH
    i do! i typed in ati silencer 4 and it gave me nothing.
    Xtreme Mentor
    Oct 2004
    then look around its even on the front page of the air cooled section. Link is at the bottem if you still cant find it, it may not be the rev 4 but coupled with their respectivley compatible video cards, all AC GPU units perform very similar.
    http://www.xtremesystems.org/forums/...ad.php?t=63366
    Dec 2004
    NY
    The Zalman.
    Xtreme Enthusiast Celcius's Avatar
    Dec 2004
    Texas
    I would also recommend the zalman vf700. I have one and and it allowed me to OC great (looks great too). The only reason I don't use mine now is because I modded my zalman cnps7000 to fit my gfx card.
    Xtreme Guru
    Apr 2005
    Finland
    Zalman VF700 and it's also very beautiful thx to that flowerthing design, I love it. And it's so cheap as well. Will get one for my next card unless it will be an Leadtek card that is.
    Feb 2004
    Zalman is the best air solution right now. Very quite and only one slot. I have the copper version
    Mobo: MSI P35 platinum
    CPU:e8400
    Mem: 4x512mb Patriot fatbody
    Vid Card: 8800gts 512mb
    Cooling: Thermalright 120 ultra
    HD's: 80x2 raid and 320gb
    Case: cooler master cm690
