Hello
My Venice hit easly 2700 mhz (9x300 )with 1.45v ( bios ) , temp are around 50o - load prime, with cooler from my sig.
Problem is that this cpu doesent want to work with anything higher. Like 9x305 , and prime fails instatly. Im rising vcore eaven to 1.6v and it doesent help, temps are abnormal ( 60o ). Ive tried box cooling but it was same.
I was thinking that i mabe have problem with my ihs so ive cut it off, and still same + temp lovered only 3-4o at load.
All testings im doing with ram speed at 220-240 mhz wich i know is stable ( 255 3.4 v is 100% tested and stable ).
I was thinking thats is issue with htt, so ive switched multiplier to 8, 8x325 - 2600 mhz same v, and prime fails, ive started digging with timings, switched max async latency to 8 and its stable now at this setting. However 9x305 still no good.
Bios ive tried are 510-2 and 414-2.
Im going nuts, this chip supposly to hit 2.8 without problems ( my 2 friends have same stepping from same shop and both hit 2850 with 1.5v ).
