Well, bought a set of 1GB TMSP PC-3500 BH-5 to prepare for my SD...
1st set keep freezing memtest #8 before 10% @ 200Mhz CL2-2-2-5
up vdimm to 3.2 + 0.03 also same....
setting is 2-2-1-2 from trp to trtw
left it to loop memtest #5 till 90 loops and thousands of error pop out...
reboot and ram seems spoil as can't even pass #2..........
rma it......
got another pair...this time i loosen the timing from trp to trtw ( 2-2-2-3 ) but can only manage to pass #8 once only.......
went into windows and use windows memtest for 3 hours and still ok...
flash to 0510-1 from 0510-2 still same and on yellow slot..
It don't seems to stable under CL2, not even on 200Mhz...but didn't try orange slot yet as I know orange slot drive strength would be different from it is now...and yellow slot seems to suit bh-5 more as some recommendation..preivously trial out also same for both slot for another pair of BH-5 that is actually spoil upon purchase....
anyone had same problem as me ? it can't seem to run with tightest timing yet as #8 is freezing no matter wat i do to it...even up to 3.3v
[edit] tried many settings that i could find here but still freeze on memtest #8
any advice is greatly appreciated...
