Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: 64 Bit Version of Cinebench released
    Jan 2004
    As the title says.
    Homepage
    Results.
    32 Bit Version
    Rendering (Single CPU): 368 CB-CPU (Higher is better)
    Render time - 71.6 seconds
    64 Bit Version
    Rendering (Single CPU): 480 CB-CPU (Higher is better)
    Render time - 54.8 seconds.
ID:	30931   Click image for larger version.
ID:	30932   Click image for larger version.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    thats a 30% boost right? not bad at all!
    Xtreme 3DTeam Member
    Jan 2004
    Dresden
    was the 32bit version run under the old winxp or winxp-x64 ?
    Feb 2005
    Waterloo, Ontario
    If it really makes that much of a performance difference, then I might have a reason to install winxp x86-64.
    3500 clawhammer @ 230x11 1.7V
    Foxconn geforce 6150
    x800gto @ stock
    2x512 mismatched sticks in dual channel
    Black case of godliness
    DČOL 4 Life
    Feb 2005
    New Jersey
    nice im getting 64bit windows when i get my venice
    D2OL will be on and off this summer due to heat
    man, i thought i was wierd, and then i started hanging out here at Xtreme Systems-Disposibleteen
    Rig1-Sempron2800+,ABIT NF7-S REV 2.0,Radeon9200se,No-Name350watt PSU,
    Maxtor80gigs harddrive,K-Byte 256mb pc2100 & Ultra 256 pc2100 Ram, No-Name CD-Rw Drive
    Xtreme X.I.P.
    Dec 2003
    I have just run both, 32-bit and 64-bit on Server2003 64-bit Edition
    289x10=2890MHZ DDR554 5-2-2-2.0-1T (just for kicks as memory speed and L2 cache size don't really matter much here)
    64.2s (32-bit) vs 48.6s (64-bit)
    Nice, 24% boost !!! It's time for software developers to switch to 64-bit, don't ya think ?
    Live Long And Overclock
    Sep 2004
    Hmmm...would love to see and AMD vs Intel on this software considering A64 SHOULD give it some leeway against Intel's Encoding and Multi-tasking prowess.
    Perkam
    Xtreme X.I.P.
    Dec 2003
    Quote Originally Posted by perkam
    Perkam
    P4 HT eats alive single core A64 in that benchmark!!!
    Sep 2004
    Quote Originally Posted by bachus_anonym
    Then perhaps the challenge lies in AMD X2 vs Pentium D ??
    Perkam
    Xtreme X.I.P.
    Dec 2003
    As far as we have seen, AMD X2 4800+ manages a bit better result than Pentium XE 840... At least in 32-bit version
    Xtreme X.I.P.
    Nov 2002
    Shipai
    the x2 wins, not a real challange from a performence pov, but when you look at availability and price/performence it looks good for intel, sinificantly cheaper and not much slower...
    id like to see a 840 vs 4800+ compare with the 64bit version
    Apr 2005
    My AMD64 (x2 Opteron 252) outperformed my Intel (x2 Xeon 3.6GHZ) with EMT64 on Linux 64-bit. I guess it should be the same with WINDOWS XP 64.
    ________
    Rhode Island Medical Marijuana Dispensaries
    Xtreme X.I.P.
    Nov 2002
    Shipai
    in what tests? compiling? how much faster was the opteron? did it have numa enabled?
    nice rigs you have there
    hmmm you need some decent memory though it seems... there is registered memory based on winbond ics that do 2-2-2 and there is other stuff based on micron ics that do 2.5-2-2
    with that much memory and interleaving enabled you should see a nice difference with faster memory timings i think.
    Jan 2004
    Quote Originally Posted by Der_KHAN
    32 Bit version in WinXP32
    64 Bit version in WinXP64
    Xtreme X.I.P.
    Dec 2003
    Since it's Sunday and I got some spare time , I re-run Cinebench benchmark. This time on 32-bit OS as well as 64-bit OS... For comparison
    This is @ 306x10=3065MHz DDR576 5-2-2-2.0-1T. Both OSes are on optimized in EXACTLY same way... Same services disabled, same tweaks...
    Cinebench 32-bit on Server2003 32-bit - 60.5s
    Cinebench 32-bit on Server2003 64-bit - 60.3s
    Cinebench 64-bit on Server2003 64-bit - 45.8s
    I thought, someone might find it interesting
ID:	30977   Click image for larger version.
ID:	30978   Click image for larger version.
    Oct 2004
    SC, USA
    Lets see Intel guys post result. Is this not their benchmark? Let us see how they can beat the 64-bit record. Are they shy or what?
    Core 2 Duo E6600 [L625A] 3330MHz 1.375Vcore 24/7
    Core 2 Duo E6600 [L640F] 3330MHz 1.475Vcore
    Crucial 10th Anv 2 x 1GB DDR2-667 @ 463MHz 4-4-4-12
    ASUS P5B Dlx
    FOTRON BLUE STORM 500W
    TT BT with stock Fan
    Gigabyte Nvidia 7600GSw/ Silent Pipe
    WD Cavier 250GB
    Antec P160
    Xtreme X.I.P.
    Dec 2003
    Honestly, It doesn't take much for P4 HT to wipe the floor with that 60s I just did... 4GHz is more than enough to make it happen
  18. #18
    Jan 2004
    My friends Dual 275 Opteron did this bench in 26.3 seconds (the 32 Bit version) Man can you imagine with the 64 Bit version !!! I phone him.
  19. #19
    Xtreme X.I.P.
    Nov 2002
    Shipai
    yeah give him a call!
    thx a lot michal! very interesting
  20. #20
    May 2005
    Sugar Land, TX
    I can't get XP x64 installed (the betas worked fine!). Maybe I'll try 2003 server.
    Eric
  21. #21
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    On air
    266x14 3.73Ghz
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
  22. #22
    Jun 2002
    Las Vegas
    Vapochill @ 1.45v
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  23. #23
    Xtreme X.I.P.
    Nov 2002
    Shipai
    sweet!!! thx for posting more results charles
    im curious how an amd dual core compares to this
  24. #24
    The un-extreme XIP
    Jul 2004
    14-SIXTY on that multiplier???
    i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
    HD7970@1125/1575 stock voltage
    1TB F1+2*128GB Crucial M4
    Silverstone 450w, no case
    2560*1440@120Hz overclocked catleap
    Steelseries G6v2+5600dpi modded logitech trackball
  25. #25
    Mar 2005
    Can we have a comparison between AMD 64bit and Intel 64bit? I'd like to see the speed up each one has...
