Thought you guys might like to see my findings I posted on these over at FM forums.![]()
Here
Here
7k bandwidth... nice
You run any SuperPI yet?
Edit.. Welcome to XS!![]()
Team Rufio
Not to bad there.
Dragon
http://smbach.com/mad.gif
Opty 175 Rig
Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
AM3 Rig
Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
DFI NF4 BIOS Guide
WOW 1T .........
which cpu are you using??
Winny 3500+. This RAM has got me amazed. Can bench as high as 305 3-3-3-10-1T or 262 2.5-2-2-10-1T. Amazing for 1GB sticksOriginally Posted by NajZ
Its only 2 sticks so all 939's can do 1T with those sticks. Impressive results!
**Georgia Tech Grad, I am an Electrical Engineer with a specialization in RF IC design and Analog circuits.**
Intel I7 3770K Delidded
Gigabyte Z77X-UD5H
2x4gb Gskill 7-8-7-16
EVGA GTX680 Signature OC
Crucial M4 256gb
Seasonic X-750
Watercooling Loop: Raystorm Acetal, EK GTX580 Full Cover, MCR420, MCR320, MCP35X2 & 7 x AP-15 Gentle Typhoons
Heatware: gte460z
Wow, that's awesome! Gig sticks usually suck at overclocking, plus they can usually never have *-2-2-* timings. Are these using the new rev micron chips that OCZ's EB used to use, cause it looks like it.
Formerly XIP, now just P.
What voltage?
yeah, im still suprised that ballistix never caught on really, they really can do some amazing things. they are like a mix of bh-5 and tccd.
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale @ 4050Mhz
2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
MSI 5850 1000Mhz/5000Mhz
Wester Digital Black 2TB
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
rofl.
will the 2x512 kits do similar clocks?
n e one willing to risk their dough?
there are plenty of results with 2x256mb kits as well as 2x512mb kits out there.Originally Posted by goatman
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
wow, nice results. I think that might be the fastest 2gb of ram (not sure though).
I would love to have 1 gig sticks that can do 260!!
Very good sticks, IMHO that average would be like that!![]()
Asus P5K Premium//Intel E6600@3,6ghz//Corsair PC6400C3@500 4-4-4-12 2,2v//8800GTS G92//Audigy 2 ZS//SeaSonic M12 700W & LianLi V2000B
Wow...
And at low volts. I run my REDLINE 4x512 at 250 3.2v...
2-3-2-6 2T...now i'm wondering if it was a good idea![]()
System
ASUS Z170-Pro
Skylake i7-6700K @ 4600 Mhz
MSI GTX 1070 Armor OC
32 GB G.Skill Ripjaws V
Samsung 850 EVO (2)
EVGA SuperNOVA 650 G2
Corsair Hydro H90
NZXT S340
amazing result there.
with 2x1gb isnt that like 4 way interleaving?? that should give a nice bandwidth boost
________
N02 VAPORIZER
4x1gb sticks :???![]()
Specs
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Audio Setup
Not sure 1T is worth a $260 price premium....$200 vs $460 UTT vs B4000?
GA-MA790GP-D4SH, 965BE, 3.8Ghz
Ultra120E, 4x2G Gskill 1066
2x 150G VRaptor raid, WD640AALS
8800GT 735/940/1685, LG-BluRay
i would guess the -5b G that the rest of the ballistix uses.. the -5g C that went into EB was kinda difficult to get down to 2-2-2, and these do it past 220mhz.Originally Posted by EnJoY
Got a fan over those memory sticks? No? Well get to it before you kill them
damn just makes me want my ballistix morestill dont have it tho
damn ebay!
Unapproved link in signature. Signature has been removed.
Please read the forums rules and guidelines. They are at the top of the forums.
Edited by IFMU
Really nice results on 1gig sticks.![]()
3500 clawhammer @ 230x11 1.7V
Foxconn geforce 6150
x800gto @ stock
2x512 mismatched sticks in dual channel
Black case of godliness
hehe... Just played with my 2x 512 BallistiX today- LARGE fan + 3,8v - got it stable, but no pic of superpi while the score was sucky cause of 2600 mhz @ CPU...
http://bigup.peecee.lir.dk/view.php?id=9124
260 T1 2,5-2-2-5 ;D
Got 267 T1 3-4-4-8, couldnt get it stable at any higher, end didnt dare use 3,9v or 4,0v...
Ran 01SE at 346x8 divider 150- got 33000 marks... Didnt clock gfx to its max nor use A64 tweaker
Competition ranking;
2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
Spectating;
2010; GOOC 2010 Many thanks to Gigabyte!
Did you try lower volts? I know most people could get 250-260 3-2-2 with around 3.0volts with the EB.
from everything I have seen bout ballistix, you dont need near that voltage. I have seen 2.9 260 2.5-2-2Originally Posted by 1_2_know
Edited by IFMU
4x512MB PC4000VX
