you might want to consider changing your rules alittle.
see prime 95 is one of the easiest things you can possibly cheat on.
I would suggest showing Cheat Free 32M shots atleast, with the Prime95 shots.
theres always someone that wants the recognition for something they never did.
heres a screen shot I just did.
took me about 10 seconds to do this.
obviously my prime95 was just opend, and theres no way possible to have 144 hours of stability when I just opend the program, but its easy to fool someone with it.
just let it run for a half hour or so, then fake the rest.
(don't ask how to cheat on Prime, cause I don't give out info, also, if you know how you can do it, don't go around telling people how to do it)
you need something more then prime 95 to prove stability, cause it's just so dang easy to cheat on.
I would suggest the Cheat Free version Mod 1.4 or newer, 32M, and 3dmark2001SE Links.
Those 2 things should help bring alot of credit to a claimed 24 stable shot.
