Results 1 to 6 of 6
Thread: Re-Test the greatest nF4-DFI LanParty SLI-D Spring
Threaded View
    Nov 2004
    Since last time I post ULTRA-D in February, the click rate is too high, make me upload the photos several times.
    There are still many PMs asking me to patch up the DFI testing photos.
    This time I re-test the board again, but changed to SLI-D.
    However, the features are similar.
    Look at the packing first
    Accessories 1, more than ULTRA-D is the SLI bridge
    Accessories 2, cables and Karajan audio module
    The full face
    Left-Down side
    Right-Down side
    MB upper side. The right hand side JUMP17 is for RAM using 3.3~4V. Remind you again, when you use this function, please be aware of the cooling around JUMP17
    Close to DRAM
    IO
    SLI Chipset
    ULTRA-D Chipset
    Below is the testing configuration, some use the same as last time and some is new.
    Congiguraion
    0448SPAW 3000+.FX57
    nF4-DFI LanPrtyUT SLI-D
    GSkill 1GBFF.1GBGH
    Leadtek 6600GTX2.6200
    CWT550W.TOPOWER520W
    Check out the new in BIOS which changed many times
    CPU Part, mostly the same
    CPU/DRAM voltage range is huge
    Add any new items
    Like DRAM add 0.03V
    Can use Dual 6600GT Chipset VGA card
    Built in MEMTEST 1.55 revision
    DRAM Part
    This is DFI’s best part, also the most confused one.
    Trrd.Twr.Twtr.Trwt setting in 2-2-1-2 is the tightest
    Suggesting you to use 2-2-2-3
    DRAM Drive Strength range in LEVEL1~8, every CPU and RAM combination will make the stability be different. I suggest to use LEVEL5 or LEVEL7 test in advance.
    BIOS Temperature Detecting Screen
    Running PI 1M in basic performance.
    Using GSkill 1GBGH in Windbond UTT
    High Voltage in best parameters
    DDR500 2 2-2-5 3.12V
    DDR550 1.5 2-2-2 3.7V
    Using GSkill 1GBFF in Samsung TCCD
    DDR600 CL2.5 3-3-5 2.6V Reached
    Next part is 3D performance in SLI mode
    Using Lreadtek 6600GTX2
    Default 500/1000
    OC to 580/1150
    Latest 510 BIOS
    As I know, the BIOS supports Dual Core CPU, FX57, and add some DRAM parameters
    510-1
    510-2
    510-3
    There is no doubt the DFI nF4 is the best MB for OC.
    BIOS Voltage Range is so wide, and DRAM features are so wild…
    It’s far over other MBs in 2 or 3 times.
    The BIOS update frequency is also awesome.
    The layout and components are great as well.
    In such a great MB, DRAM OC can co-operate with many memory chips or CPUs.
    When you tweak your PC, parameter is not only CL2.5 4-4-8 can be.
    You still need others to tie in to reach the limits.
