Results 1 to 16 of 16
Thread: When a new BIOS for DFI Nf4 ultra ??
    Apr 2005
    Thumbs down When a new BIOS for DFI Nf4 ultra ??
    Hi All ,
    I want to know when Oscar will release a new final bios for VN and SD cpu ,
    414-1 and 414-3 aren't , stable
    Jan 2003
    Ayia Napa, Cyprus
    Im hoping tht a new bios is released soon, im finding some strange results with my venice as i push past 323HTT. Another forum member has exact same CPU (Venice 3000+ CBBLE 0512DPBW) as myself and a similar setup and they have reeached exact same wall as me.
    After 323HTT the predictabilty of the overclock is lost. Sometimes superpi is possible with 3ghx sometimes it will crash instantly at 2940mhz.
    This CPU is prime95 stable for over 9hrs at 322x9=2898mhz. The divider im running is 9:10, so mem is running at 290mhz. Ive tried alot of settings but the results are consistant. Anything over 323HTT and predictions are not possible
    Seasonic Prime TX-850 Platinum | MSI X570 MEG Unify | Ryzen 5 5800X 2048SUS, TechN AM4 1/2" ID
    32GB Viper Steel 4400, EK Monarch @3733/1866, 1.64v - 13-14-14-14-28-42-224-16-1T-56-0-0
    WD SN850 1TB | Zotac Twin Edge 3070 @2055/1905, Alphacool Eisblock
    2 x Aquacomputer D5 | Eisbecher Helix 250
    EK-CoolStream XE 360 | Thermochill PA120.3 | 6 x Arctic P12
    Xtreme X.I.P.
    Nov 2002
    Shipai
    what makes you think its the board and not the cpu?
    do other people on different boards have better results/stability?
    Xtreme Mentor
    Jul 2004
    Ontario
    Bios 509 and 510 is in beta right now. Hopefully we will see it soon.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
    Mar 2004
    you can download the 509 and 510 beta in 10 minutees at http://www.techpowerup.com/articles/other/114
    Dec 2004
    Atlanta
    Sweet just downloaded 510-3. Will try it in a bit and report back!
    Mar 2004
    runnin' fine here (510-3)... with tccd @305 2,5-3-3-5-7 @ 2,8v
    Banned
    Mar 2004
    Huntington Beach, Ca
    Any increase in overclocks?
    Jan 2003
    Ayia Napa, Cyprus
    Quote Originally Posted by saaya
    Well i wish their were more results with other brds, running HTT of above 323 and having the same CPU as the ones ive mentioned
    But this isnt the case, wht i said is just a hunch, which i hope is correct because it would mean their is more headroom in the Venice I got. Im able to run a superPi 32M at 3ghz (HTT of 330) but it is impossible to boot at this HTT speed, cant even get into memtest at anything over 325HTT with any consistancy.
    Ive just downloaded the bios's, wont be able to test till Monday, has anyone got any info on the differences between the bios's??
    Jan 2004
    Saskatoon, SK
    Very nice to see 510 up for download, my Ultra-D and 3000+ will be here on wednesday, and I can't wait to give 'er a go. Gonna push my mem controller and GSkill as far past 300HTT as I can, dunno if 334x9 will be possible on h2O, but I'm sure as hell gonna try.
    • Intel Core i7 875K @ 3.86GHz 1.35v /w Intel Extreme Tower Heatsink
    • Intel Extreme DP55KG
    • 2x2GB Kingston HyperX PC3-10666
    • ATI HD5970 2GB @ 850/1,200
    • Lian-Li PC-7B
    • Corsair TX750 PSU
    Apr 2005
    Quote Originally Posted by Cornelious0_0
    You better use the offical Bios first to see everting is Ok. Then, you can try the Beta Bios. This is to counter check should anything goes wrong, Bios is not the issue. Currently, my comp die on me due to Bios. Anyway, have fun. Cheers.
    Apr 2005
    oki thx
    Xtreme Mentor
    Jul 2004
    Ontario
    hey kamui... I am in your twin star...
    Asus P8P67
    Gigabyte GTX 460 1G
    Apr 2005
    Quote Originally Posted by cantankerous
    Xtreme Mentor
    Jul 2004
    Ontario
    LOL if only I spelt it right.. what the hell was I thinking putting that "in" into the sentence. sigh.
    Asus P8P67
    Gigabyte GTX 460 1G
    Memory Addict
    Aug 2002
    Brisbane, Australia
    doesn't matter so far everytime i try a new bios for DFI NF4, i eventually go back to 310 official which seems to be the best heh
