Page 1 of 19 123411 ... LastLast
Results 1 to 25 of 465
Thread: 2 stage cascade
    May 2005
    Nova Scotia,Canada
    2 stage cascade
    This will be the beast behind my 2 stage cascade system im beginning soon. R22 or Propane for stage 1 and CO2,R404,or R502 for stage 2.
ID:	30347   Click image for larger version.
ID:	30348   Click image for larger version.
ID:	30349   Click image for larger version.
    My Rig:
    Q6600 2.4Ghz@2.9Ghz Custom Liquid Cooling
    ATI X1950XTX 512mb DDR4
    MSI 975X Platinum PowerUp Edition
    2gb Kingston Hyper-X DDR2 667
    Sound Blaster Audigy2
    2 IDE HDD, 2 SATA HDD
    LG DL16XDVD Writer,52X CDROM
    OCZ 520Watt PSU 33Amp +12v
    Thermaltake Xaser III case
    Logitech Z560 4.1 400watt Surround Sound
    3Dmark03-21112
    3Dmark05-12154
    3Dmark06-8054
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    I think she's a little too big...
    Jun 2003
    Norway
    The picture of that compressor made by back hurt
    You couldn“t find a larger one?
    Its a beast alright.
    Admin
    Mar 2003
    North Texas
    Could you point out the suction port and discharge port for us?
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    Mar 2005
    somewhere where the 2nd compressor isn't needed
    pc ice do you mind telling me what L.R.A. means? is 71 too much ? Btw you compressor seems a bit BIG lol! that must make an insane ammount of noise but hell, I think it's gonna give you some nice results
    Edit: I just saw that you compresor weight 72 LBS!!!!!!! hahaha don't drop it on the ground Suction is 1/2 and discharge 3/8.
    I am Xtreme
    Aug 2003
    God that thing is HUGE! Just use 1HPs and safe some room/noise/electricity...
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Sep 2003
    Austin, Texas
    Quote Originally Posted by Cr@sh_D1n3r
    LRA = Locked Rotor Amps. That is how much current the motor will draw whne the motor is seized up (broken). Doesn't mean much of anything, actually.
    The nomencalture of the model number should indicate horsepower.
    ****-0075-***. The numbers in the middle indicate horsepower.
    0033 = 1/3 hp
    I am Xtreme
    Mar 2005
    Quote Originally Posted by herefishy
    0033 = 1/3 hp
    correct on what LRA ,stands for. but its meaning is very important that why they reserve a space for it on every motor. the circuit breaker must always be lower than this number, by a safe margin. lets look at this compressor. RLA 5.4 and LRA 31. That tells me that under max charge/load the manufacture recommends the unit not draw more than 5.4 amps. the LRA 31 tells you that is the maxium number of amps the windings can draw if the rotor locks.So the circuit breaker on this circuit needs to carry the 5.4 amps without tripping and should not be over 31 amps. a 30 amp breaker is too close to the LRA and should not be used,A good choice for this compressor is a 15 amp breaker using 14 gauge wire or a 20 amp breaker using 12 gauge wire. a 10 amp breaker on a long wire run might also trip prematurly(too light). Notice that the higher the circuit breaker ,the larger wire size must be used(smaller number).This is to be certian that the wire does not melt before the breaker trips. Each breaker/fuse size has a minium wire size requirement that corasponds with it. Walt
    edit this is for primary circuit protection,if it is a branch circuit the wire size must be able too carry 115% of the LRA.
    I want to expand on this a little, you must look at the application to determine if the fuseing is to protect the device or to soley protect the wiring circuit.each application needs to be looked at in its entiry. take this application ,if this comressor was on a 20 amp circuit that would protect the motor ,now lets say he adds a fan to this circuit that draws .5 amps and has a Lra of 4 amps, if this circuit is not seperatly fused or thermally protected, the wire should be able to carry 115% of the LRA so the wire will not melt if the fan becomes locked,the motor would be ruined in this example but the wireto it would not melt.
    Admin
    Mar 2003
    North Texas
    Good explanation walt.
    So the Locked Rotor Amps is basically on the compressor to tell us what size breaker and wiring to use and nothing more?
    UNDER THE ICE .com
    is the remedy
    I am Xtreme
    Mar 2005
    Yes, along with the run load amps(RLA). A margin must be left above the RLA for the added resistance of the wire run plus since all motor draw many times their RLA for a split second during start-up(iductive load) to close to the RLA will cause circuit to trip at start-up. All circuit breakes have a AIC rating (amps interupt circuit) that allow it to draw many times its rated trip load for short periods so that motors can start with out tripping breaker. the RLA and LRA can be thought of as a minium and maximium circuit limits plus a margin for safty on the upper limit. I would use no less than 20% ,so for a LRA of 31 a 25 amp breaker would be acceptable but no more. Walt
    May 2005
    Nova Scotia,Canada
    Quote Originally Posted by runmc
    Here you go.
    My Rig:
    3Dmark03-21112
    3Dmark05-12154
    3Dmark06-8054
    May 2005
    Nova Scotia,Canada
    Yep she does weigh a ton lol. I tried looking up the specs on the copeland website and i tried googling it but i can't find the specs for this compressor anywhere. any help would be appreachiated.
    My Rig:
    3Dmark03-21112
    3Dmark05-12154
    3Dmark06-8054
    Nov 2003
    Quote Originally Posted by _HL4E_HalfLife_
    Sorry this is the only thing I could find and their distributor here. Maybe you could sent them a PM or call? But didn't herefishy say it was a 1/3HP?
    P4C800E DL,P4 2.4c @ 3.4(droop mod),1G Mushkin 3500 II 2,2,2,8 @ 3.1v,AIW 9800 Pro (450/370 @ 1.9v core),Audiology Platinum,2xDiamonds 8mb Raid0,Lian-Li Pc70,PC P & Cooling 510D,Plextor 708A,Plextor 52x32x52...water cooled...
    I am Xtreme
    Mar 2005
    herefishy is right its definitly 1/3 hp ,I see if I can find the specs for this model,should have rebuild manual around too.
    May 2005
    Nova Scotia,Canada
    yea redken thats what I had found too.
    My Rig:
    3Dmark03-21112
    3Dmark05-12154
    3Dmark06-8054
    Mar 2005
    thx for answer! I really apreciate it!
    Sep 2003
    Austin, Texas
    NO! You would not want to pay for a 35Amp circuit for this compressor.
    RLA = rated load Amperage. The RLA is somewhat indicative of what you would expect the compressor current to be, at the rated voltage, in the rated application. Good greif! A 35Amp circuit for a 1/3hp compressor?
    NOT!
  18. #18
    Sep 2003
    Austin, Texas
    I couldn't find anything on the web either... but I havbe a 1995 United Refrigeration Catalogue with this compressor's information in it. The compressor is rated R-12 high/medium temperature (from +55F to 0F).
    4,900 Btu/H R-12 at 55F evaporator (at 90degF condensing temperature),
    1,150 Btu/H R-12 at 0degF evaporator (at 90degF condensing temperature)
    Cheers!
  19. #19
    Sep 2003
    Austin, Texas
    OH!
    Also, the compressor is rated low temp (0degF to -40degF) R-502, as such:
    2,400 Btu/H @ 0degF evaporator (90degF condensing temperature)
    440 Btu/H @ -40degF evaporator (90degF condensing temperature)
    So, it is a high temp R-12/Low temp R-502 little 1/3 horse compressor.
  20. #20
    Nov 2004
    Buenos Aires, Argentina
    R404 and R502 are first stage refrigerants, theres no use to have them as 2nd stage. CO2 is a problem with oil, youll have to add some propane to make oil flow.
  21. #21
    May 2005
    Nova Scotia,Canada
    OH!
    That seems a bit small for a compressor of this size and valve port openings (10mm across). Are you sure the model and serial numbers are the same? Im still looking for some technical specs such as rpm's,run cap mfd,Start cap mfd,relays,etc.
    My Rig:
    3Dmark03-21112
    3Dmark05-12154
    3Dmark06-8054
  22. #22
    I am Xtreme
    Mar 2005
    I want everyone to be aware there is a differance between protecting a circuit with the proper size wire and fuseing so it does not get hot and melt and protecting a motor or compressor from overloads.There is also a differance in wiring primary circiuts from branch circuits.There are guides for circuit protection and motor protection in the NEC(national electric code) each circumstance must be looked at induvidually.
  23. #23
    Xtreme Mentor
    Nov 2003
    New-Brunswick, Canada
    The size as absolutly nothing to do with the power...
    And the size of that beast is because of the type... a lot of displacement though...
  24. #24
    HVAC/R Engineer
    Nov 2003
    Copeland used the same body size for a number of compressors up to 1/2 hp all they do is bore it out and add bigger pistons and use a bigger motor.
  25. #25
    May 2005
    Nova Scotia,Canada
    Quote Originally Posted by skate2snow
    Yep they do these serviceable compressors have alot more displacement than sealed compressors of the same rating do thus for every revolution this compressor makes theres an increased amount of btu's.
    My Rig:
    3Dmark03-21112
    3Dmark05-12154
    3Dmark06-8054
