Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Problems with Venice 3000+ >:(
    Jul 2004
    Maringá - Paraná - Brasil !
    Just other deception
    I had a CBBID Winchester and it was a really in' $hit, and it's happening with my Venice, too
    300x8 = 2.4GHz 1.4v in Bios SIMPLY IS NOT STABLE! (It's not common, isn't it?)
    Then I was angry, put 1.55v and looks fine, but, in my opinion, it's a $HIT.
    What do you think it is? Really a TERRIBLE CPU or the bios of my mainboard?
    Venice 3000+ cooled by Zalman CNPS7000A-Cu
    DFI LanParty UT nF4 Ultra-D (310P)
    G.Skill PC4800LA (100% stable)
    Seventeam ST-420BKV (it's NOT the problem)
    LDT/FSB is 3x.
    []'s
    Day-to-day config:
    Venice 3000+ LBBLE 0515FPCW @ 2.7GHz 1.47v
    DFI LanParty UT nF4 Ultra-D Rev. AA0 702-2 coolermod
    1GB G.Skill PC4800LA @ DDR600 2.5 4-3-6 1T 2.72v [TCCD 440 Brainpower 0808]
    Gigabyte GeForce 6600GT PCI-Express
    SoundBlaster Audigy ES
    Seventeam 420w ST-420BKV (real power, 2× +12v [16A each], 24-pin)
    Jul 2004
    LoCkEd In ThE lAb
    maybe its ur mainboard but i will hard believe that.
    try some settings and play some bit, i know a guy who got today a 3800+ with exactly that stepping with zalman7000CU 2800mhz 1,55Vcore fully spi stable not more tested yet.
    so take some time to lpay around some bit
    seEn
    PS: 1,4V is default core voltage so give him power to get power of him
    . . . WHO put this thing together? ME !
    . . . WHO do i trust? ME !
    . . . f*** it, as****
    Jul 2004
    What settings?
    My memory is stable, I don't know what more to do.
    My mainboard is ok, because my CBBID did 2.4GHz with 1.695v and Venice is doing 2.4GHz with 1.55v (I didn't test any VCore between 1.43v and 1.55v)
    Day-to-day config:
    Feb 2005
    Southern California
    How far did you get with 9x?
    Could be your motherboard.
    May 2004
    East Bay, California
    310 bios is terrible for my San Diego, use 414-3.
    Mar 2005
    I think I've found near the top of this chip, its running 2400 stable at 1.4 volts, currently in Prime 95 12K test. Is there a prize for the lowest speed Venice on this board or am I doing something wrong? Its not stable at 2450 with 1.575 volts.......
    Apr 2005
    Brasil
    LBBLE's tend to be good AFAIK...
    Jul 2004
    Quote Originally Posted by CTKP
    I will test it.
    Thanks.
    Day-to-day config:
    Mar 2005
    I have the same problem with a 3200 Venice; however, I can't do 2400 stable! I'm thinking there is a problem with the 3.10 bios
    AMD Venice 3200 ADA3200DAA4BP
    LBBLE 0516EPGW
    250x10 @ 1.475 Volts Prime95 stable
    DFI Lanparty NF4 Ultra DR SLI
    BIOS 310
    TwinMos 3200 Speed Premium 400/512 x 2
    ATI X800XL
    2 x 160MB Seagate NCQ Raid O on SI3114
    1 x 80MB Seagate NCQ on NF4
    Lian LI 75B
    2 x Panflo 80MM H1A
    Thermalright XP-90C
    1 x Panflo 92 MM H1A
    PCP&C 510 SLI
    Feb 2004
    Kent, WA
    My buddy has a 3000+ venice with I believe the same stepping as you. He is a novice overclocker, but has only been able to get 2.3ghz stable out of his so far with 1.55v. He is using a DFI nF4 Ultra-D as well along with a Thermalright XP-90 for cooling. I hope to be able to help him with overclocking it soon to see if it can do more.
    System 1: i5-2500k (4.9 ghz), Thermalright Silver Arrow, Asus P8Z68-V, 8GB Gskill Ripjaw, Sapphire HD7950 OC (1200/1750), 1TB Samsung F3, Crucial M4 128GB & 64GB, Lepa G900-MA, X-FI Titanium, CM Storm Sniper, HP ZR30w + ZR24w
    HTPC: i5-2500k (4.2Ghz), MSI Z68MA-G45, 8GB Gskill Ripjaw, Sapphire HD7850 (1150/1425), Kingston HyperX 240GB, 1TB Samsung F3, Ceton InfiniTV 4, XFX Black 650w, Denon AVR-1910, Silverstone GD04B, Panasonic 55" ST30
    WHS: Athlon II X3 435, MSI 785GTM-E45, 4GB OCZ Gold, 2x1.5TB Samsung F2, 2TB Samsung F4, 1TB Hitachi, CoolerMaster 341Elite, Antec Neo-Eco 520w
    Jul 2004
    PEOPLE !!!
    Bios 414-3 really helped, and VERY MUCH!!!
    My CPU (310P) with 1.45v didn't pass 5% of OCCT.
    Now with 414-3 it's 100% stable, passed OCCT while I was using ICQ and IExplorer with NO problems.
    Suggestion: If you are using VENICE and got problems with overclocking, try 414-3 BIOS!
    Screen
    Day-to-day config:
    Charcoal or propane?
    Jan 2005
    Kansas City
    good lord. I'm really hoping that these problems are just BIOS issues that need to be ironed out with various Mobos. I mean 2.3-2.4 max is worse than even a lot of the CBBID Winnies.
    I can only assume for now that its due to BIOS problems, and hopefully this will all be cleared up soon.
    DFI UT X58-T3eH8 (being replaced with Giga UD5)
    Core i7 920 D0 mostly stable @ 4Ghz
    TRUE 120
    6GB OCZ Platinum 7-7-7 (still in testing
    XFX 4890 1GB @ 1050/1190
    Corsair HX850W
    CM Cosmos S
    Still testing...
    Apr 2005
    Brasil
    Nice.
    Now run some Marks overnight just to make sure it's rock solid.
    Jul 2004
    Crazy system?
    I tested OCCT again two times with the EXACTLY SAME config (I didn't reboot) and I got errors.
    The only way to know if it's stable is playing...
    Day-to-day config:
    Live Long And Overclock
    Sep 2004
    Quote Originally Posted by higherøx
    Crazy system?
    You have one hell of a system there. It should do 2.6+ on air quite easily...why not try it?
    Perkam
    Apr 2005
    Brasil
    Just give it some time.
    Try different settings also.
    Mar 2005
    Quote Originally Posted by ReelMonza
    what different settings would you recommend?
    LBBLE 0516EPGW
    BIOS 310
    ATI X800XL
    Lian LI 75B
    2 x Panflo 80MM H1A
    Thermalright XP-90C
    PCP&C 510 SLI
  18. #18
    Xtreme Mentor
    Nov 2004
    Elma, NY
    Give it some vcore - to expect 2.7 @ 1.424 is expecting alot, try 1.5 or 1.55.
    i7-2600k @ 4.8Ghz 1.38v L044A892
    ASUS P8P67 LGA
    16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
    1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
    Cooler Master UCP 1100 Watt PSU
    GTX 680 1300/7000
    Lian Li PC V-2000
  19. #19
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by dnottis
    agreed, even my cpu that can suicide screen on air at 3.1ghz needs 1.45v to get 2.7ghz stable
    Got a fan over those memory sticks? No? Well get to it before you kill them
  20. #20
    Jul 2004
    Quote Originally Posted by perkam
    Perkam
    I'll try it surely! But I'd like to use my GSkill between 600 and 610MHz
    And it's not possible with 2.6GHz... is it?
    Thanks.
    _______________________
    Just ran some 3DMarks.
    3DMark01 once, 3DMark03 once.
    Later use ICQ, IExplorer, I didn't reboot the PC and ran this benchmarks without any tweak.
    3DMark01 gave me ~21.xxx
    3DMark03
    Venice 2400MHz, DDR600 2.5 4-3-5 1T, Gigabyte 6600GT stock.
    Day-to-day config:
  21. #21
    Jul 2004
    2.7GHz and 1.69v my system get BSOD when loading Windows.
    Do you think that high VCore was the problem or my CPU is not good?
    Day-to-day config:
  22. #22
    Love and Peace!
    Dec 2004
    hiding somewhere!
    at 2.6ghz, you have the option of fiddling with the memory ratio to get the 8x ram divider for 325mhz, 9x for 289mhz, or 10x for 260mhz.
  23. #23
    Mar 2005
    I'm down to 2350 testing my 3200 CPU overclock
    LBBLE 0516EPGW
    BIOS 310
    ATI X800XL
    Lian LI 75B
    2 x Panflo 80MM H1A
    Thermalright XP-90C
    PCP&C 510 SLI
  24. #24
    May 2004
    Is there anyone else who's having terribly OCing with the 310 and Sandy? Please offer your input if indeed there is anyone.
    Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
    Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
    Asus MA378-T with AMD Athlon 64 X2 7850
    ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
    BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
    Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
  25. #25
    Xtreme 3DMark Addict
    Sep 2003
    I dont see any problem, does it run at 1.8GHz? Good its not broken then. You have taken for granted all those lucky clocks and get disapointed when you are handed an average clocker. Mine wont do 2.4GHz either at 1.4v and it shouldnt, its binned as a 3000+
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
