Page 1 of 10 1234 ... LastLast
Results 1 to 25 of 247
Thread: Having fun with Dothan, Socket478 and AGP card
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    Thumbs up Having fun with Dothan, Socket478 and AGP card
    Thanks to the great CT-479 adapter the Great S478 i875/i865 boards are more than alive again! We have seen how those dominate SuperPi and PiFast but how about 3D?
    Well, Here goes
    main parts:
    Intel Pentium M 730 1.6GHz 533FSB (~200€)
    old, nearly dead ASUS P4C800 ('kyosen' Vdimm mod required to run stable) (~80€)
    ATI X800XTPE ES (one of the first X800XTPE cards made)
    good old BH5
    The thing with these Dothan chips and ASUS s478 mobos is that the system needs to be booted up at 200FSB or higher. Otherwise the max FSB will be very low.
    So lets start with everything at 'stock'.
    Dothan at 2.4GHz (12x200, 1:1 TURBO), X800XTPE default clocks
    3DMark2001SE => 32120
    Pretty good as this matches a stock FX55 @2.6GHz with fully tweaked Win2000
    Overclocking with aircooling:
    Copper heatsink + CT-479 default fan on CPU and Alpha PAL8942+80mm fan on ATI GPU.
    The 1.6GHz chip appers to be a pretty good overclocker and was able to reach over 2.8GHz aircooled for SuperPi 1M run - Vcore 1.55V. Higher Vcore is still to be tested (OVP kicks in at this point when VID is at default 1.308V). So it may hit higher too w/ air.
    3DMark2001SE @ 2812MHz (233x12), ATI 660/660:
    37757
    That was ran just for fun, low 233FSB and poor car low, will do easily over 38k aircooled once really pushed
    Next Step, good old Water+peltier cooling!
    First run @ 2944MHz (245x12), 640/640, nature 650/660:
    39045
    Not bad for sub 3Ghz and aircooled video
    No windows tweaking done for this run either. I'll need to test if 'ricky tweak' works w/ Dothan.
    Still limited to 1.55V Vcore and it seems that this particular chip likes high voltage - so after VID mods even higher clocks should be available.
    I'll try with icy water later this evening / tomorrow and see if she'll do 3GHz
    I've had it thru SPi1M at 2970MHz so far.
    40k might be just possible w/ aircooled card and water+pelt on CPU.
    Jan 2004
    Israel
    verrrrry niiiiice score you got there !
    nice work macci and happy to see ya starting to hit the orb again ... !
    Member
    Dec 2002
    Leics UK
    Thats very impressive for such a cheap setup.
    I didnt realise those CPU were quite good value.
    Ive never even thought about going intel, but this looks very good.
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    Well actually it appears to be the WR for Sub-3GHz setups
    Just enough to beat my old record of 39004 w/ FX55 @2964 (269x11) and ATI @ 792/698..
    Xtreme Mentor
    Oct 2004
    Amazing work, macci. Do you think the Dothan has the potential to take down the top spot in 01?
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    Well these are clearly faster than FX55 clock-to-clock..and we have seen these go as high as over 3.6GHz
    Should be possible to take #1 in MArk03 single card too.
    Nov 2003
    Denmark
    Just when everybody was screaming "DFI! 939! UTT! Cascade!", Macci comes along with an olld 478 AGP rig, and a card up his sleeve
    39k is AWESOME! I think the combination of a Pentium-M reaching Japanese clocks and a really good X800XT would devastate the ORB!
    | Pentium-M 730 SL86G 1.60@2.81GHz | ASUS P4P800SE w/ CT-479 | 2x512MB BH-5 | 1M @ 26s | Windows XP SP2 |
    | Athlon64 3000+ E6 LBBWE 0544EPHW | ASRock 939Dual-SATA2 | WinXP and various Linux distros | Currently enjoying:
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    that's sooooo ironic, the old tech stuff squashing the ORB, lol...
    It just goes to show that IF Intel wanted to make a great desktop combo, they COULD!! But they're tied down into the 915/925/955 P4 thing.
    C
    Jan 2004
    Israel
    hey macci , btw - u could of pulled some points easily ...
    use a 2X512mb sticks of VX ... they will do easily 245@2-2-2-5 , and 1gb scores more then 512mb at 01 ....
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    I've tested with 2x512 and it seems to give excatly the same 3Dmark numbers as 2x256. If the mobo could handle 2x512 w/ max chipset settings (aka ASUS TURBO @200FSB) it would be a bit faster yes
    2x512 seems to be a little bit faster for SuperPi thou. I have my good old KHX3000 2x512MB BH5 pair here that does 249 @3.28V Vdimm on this platform - also some new BH5 twinmos but its not quite as good.
    w/ A64 2x512 would be clearly the better choice.
    Nov 2003
    Denmark
    Quote Originally Posted by S&M
    I think that Macci's neither done benching nor unaware of that fact. After all, he IS the overclocking guru/legend guy
    According to the first post i think it was to prove that all these xtreme 939 systems could be taken down easily AND inexpensively by a well tamed Dothan
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    Quick Mark03 run I did this morning => 16177
    all aircooled and only 2.7GHz / 630/630 clocks. The bench drive only had some old MArk03 version so no ORB link for that. Will try that again too soon w/ some higher clocks
    Feb 2003
    Denmark
    Quote Originally Posted by macci
    Oh my!
    If i suddenly tear down my 6month old laptop bought with extra warranty just to rip out the 2Ghz dothan inside!
    I know who to blame
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    btw, I saw a peak FPS of 916FPS during that 39k run in Lobby Low
    makes you wonder if the test will show higher than 999FPS - I guess that at 3.2G and high FSB we know the answer
    Aug 2004
    Milan,Italy
    macci is this a FSB400 chip??? it is really going hight in FSB!!!
    Jan 2004
    Israel
    dothan is 533fsb ...
    Xtreme Legend
    Jun 2002
    Helsinki, Finland
    The Mark03 screenshot w/ CPU-Z 1.27 incorrectly reports the CPU as 725/1.6GHz/400FSB. ITs really a 533FSB part 730 - like shown in this pic.
  18. #18
    Aug 2004
    Milan,Italy
    ahn ok, how much fsb i can expect from a 400FSB cpu???
  19. #19
    Ebay Hater
    Aug 2004
    Denmark / UK
    This would be hilarious
    Go grab a x850xt pe AGP card off ebay if you want, millions of cards are there going for abour eur300
    In short, both AMD and NVIDIA discovered that their next-generation graphics cards are superior to each others' last-generation graphics cards.
  20. #20
    Nov 2003
    Impressive to say the least. Damn that thing is fast.
  21. #21
    Jan 2004
    Manchester (UK)
    Great work macci
    This REALLY makes me wonder... do I go from A64 to Dothan power
    This means I would have to sell 'new' tech (Venice, DFI SLI-DR & X850 XT PE) to buy 'old' tech (2.0GHz Dothan, P4C800-E & X800 XT PE)
    Very intresting. For me to keep up with a Dothan @ 2800mhz means buying an FX55 which is way more in the way of £££.
    *starts to think*
  22. #22
    Xtreme X.I.P.
    Dec 2003
    That is some serious power You just partially answered my "quiet question" if those Dothans are any good besides 1M runs.
    Are you gonna try some DI on it anytime soon, macci? That should give at least Top5 score in 3DM01
    With that 2.7GHz on air, your +16k in 3DM03 is very impressive That's whole 1k more than what my A64 90nm does @ 2.76GHz with similar vc clocks
    Very nice to see you back in action
  23. #23
    Mar 2005
    [AMDfanboymode]I'd say it's probably the extra mb of cache that does it[/AMDfanboymode] but still, that's an amazing chip. throw a few more clocks on that X800XTPE, and see what you can do. maybe take the 01 crown back form OPP and his SLI setup?
    Microsoft's homepage can be found at: thesource-dot-ofallevil-dot-com - interesting, no?
    Think of something witty and imagine it here.
  24. #24
    Xtreme 3DTeam Member
    Jan 2004
    Cascadia
    Hmmmmm, seems to be very little price difference between 725 and 730 models.
    Official ORB bottom feeder.
  25. #25
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    in my cheat testing, I have maxed out the FPS on 3dmark2001se many times.
    it tops out at 999 no matter what.
    eventually, you guys are gonna take this program to the point where you just physically cannot get a higher score, with 999 being the limit.
    well... you'd have to max everything out at 999, so I am sure thats still gonna be a long ways away.
    man, these dothans still just amaze me.
    I miss the P4C800's...
    still one of the best boards ever made.
