Results 1 to 10 of 10
Thread: I need help overclocking A64 3000+ 939
    Jul 2004
    Maringá - Paraná - Brasil !
    It's an Athlon 64 3000+ 939 90nm.
    CBBID 0508.
    It doesn't stabilize @ 2400MHz at even 1.64v.
    I don't know what more I could do.
    The memory is stable and the chipset didn't pass over 45ºC.
    With this settings there is an error at ~5~10% of OCCT test.
    PLEASE HELP ME!! I am getting crazy!
    Day-to-day config:
    Venice 3000+ LBBLE 0515FPCW @ 2.7GHz 1.47v
    DFI LanParty UT nF4 Ultra-D Rev. AA0 702-2 coolermod
    1GB G.Skill PC4800LA @ DDR600 2.5 4-3-6 1T 2.72v [TCCD 440 Brainpower 0808]
    Gigabyte GeForce 6600GT PCI-Express
    SoundBlaster Audigy ES
    Seventeam 420w ST-420BKV (real power, 2× +12v [16A each], 24-pin)
    Apr 2004
    Cornwall/Leeds UK
    Its a CBBID, cant really say much more, they aint the best of chips.
    .:. X2 @ 2.9 .:. E6600 L628 @ 4.73 .:. AB9 @ 512 FSB .:. E6300 @ 100% OC Stable
    U.K. overclockers: Represent your country, bench for EP-UK! Unite and show the world there IS a U.K. scene!
    Jul 2004
    But all I saw did 2400MHz with 1.6v max!!
    Mine can't stabilize at even 1.64v
    Day-to-day config:
    Love and Peace!
    Dec 2004
    hiding somewhere!
    that's a typical result for a 3000+ CBBID winchester
    edit: try to be helpful..
    did you lower the ht link multi?
    drop the ram divider?
    increase chipset/ldt voltage?
    100% certain that your agp/pci locks are working?
    Got a fan over those memory sticks? No? Well get to it before you kill them
    Xtreme X.I.P.
    Dec 2003
    yep, that seems to be the true for 3000+ CBBID Winnies made in 2005. I had one, too. 3000+ CBBID 0508. I only got it 16hrs+ prime95 stable at 2385MHz, 1.58v on BOX cooler.
    2400MHz was no go, no matter what I tried. It would crap out after an hour or so. Even XP-90 with 92mm did not help either
    Feb 2005
    sell it to a freind and invest in a venice, youll be extremely happy =]
    Jul 2004
    Quote Originally Posted by ozzimark
    - did you lower the ht link multi?
    - drop the ram divider?
    - increase chipset/ldt voltage?
    - 100% certain that your agp/pci locks are working?
    - yes
    - no because i have ddr600 stable memory
    - no!
    - this motherboard doesn't have agp/pci lock because it doesn't have agp slot.
    Quote Originally Posted by bachus_anonym
    oh ing $hit
    so I will try it... let's see what happens
    Quote Originally Posted by calcal
    but I live in brazil and would have to wait... but it's not a bad idea, maybe, a cbbhd steping could solve my problems, too.
    thank you all.
    I am testing OCCT now 300x8 and 1.66v.
    PS.: What the max VCore I can use daily with NO problems?
    Day-to-day config:
    Jul 2004
    Seems rock solid
    Can I use this configuration daily?
    Day-to-day config:
    Xtreme X.I.P.
    Dec 2003
    So, what did you do? It haven't even passed OCCT Quick Test before? Now it does? Did you raise vcore a bit then?
    Well, OCCT Quick Test is a good start. This app seems to stress the system quite hard, it tends to error out sooner than Prime95. Run Torture for more than few hours, then do some more demanding benches, like SuperPI 32M or some system-taxing 3D games...
    Jul 2004
    I just put 1.69 VCore at bios...
    The system seems stable, I played a little Quake3 and it was ok.
    But SuperPI is interesting, sometimes I get errors in the 1Mb test even at stock speeds.
    I got 35s in SuperPI 1mb.
    PS.: I'm learning English, you probably will see so MANY errors :x
    Day-to-day config:
