Like the K8N-DL thread, this new Tyan board runs with nVidia's Nforce Pro chipsets. I like the K8N DL, but chose this one because it actually has two nForce chipsets 2200 and 2050 along with the 3rd AMD chipset onboard.
Overclocking out of the box is easy with nTune software. It seems others I compared notes with are limited to 217 MHz on the HyperTransport at stock voltages which brings my Opteron 252's to 2.82 GHz. It is a nice little 8.5% gain. I have clocked it to 2.9+ GHz, but always crashes during the 3DMark05 CPU test at the end.
I also found that by running a clock utility like RM clock I can leverage the AMD PowerNow voltage and increase my stock voltage from 1.40 to 1.45, that brings me to fully stable 2.87 GHz, and near 3.0 GHz unstable... but unfortunately I cannot push the volts higher without a hardware mod. The Tyan BIOS is still in beta and early versions actually showed locked voltage settings within nTune. They were grayed out, but it looks like they tried to allow BIOS voltage mods, so there may be some hope for the future.
Anyone playing with K8WE voltages yet?
Also, side question, has anyone played with the Zalman VF700-Cu VGA coolers with SLI? I have an NV silencer on GPU 2, but the stock fan on GPU 1 is bugging me with it's noise. Thinking to keep the NV Silencer and install a Zalman VF700 on GPU 1. Looks like enough space, but not sure the Zalman can hack it with 1cm for air intake on the back of another 6800 ultra.
-edited image links-
