How many are using a 20 pin power supply? Have any of you had damage and what were your setting if you have had damage? How many are running just fine?
Asus rampage III
i7 950
corsiar dominators 3x2Gb
Evga 280 gtx
silverstone 800 watt power
ssd 6Gb/s
Water cooling
BASS ALE COOLENT FOR ME!
heat
Ultra-D here... I've been using two 20-pin PSUs with it so far: Fortron 530W and PC P&C 510W Deluxe... No stability issues whatsoever, running Winnie 2900MHz @ 1.85vcore/3.6-3.8vdimm
But I need to add, that I do not have any PCIe video card since I got it, about 2 months nowI don't think it would matter that much in non-SLi configuration.
you really should not be using a 20pin DFI adamently suggests that you do not use adapters...
Gigabyte GA-EX58-UD5
Intel i7 930 @4ghz
EVGA GTX 480
3x2GB OCZ DDR3-1600
PCP&C Turbo Cool 860 watt
Win. 7
5.5ghz Presler Validation
Originally Posted by wolfgang
I was using an antec 380w before switching to the fortron. Ran 3.4v-3.5v vdimm with it also. Never really had any problems. I did see some voltage fluctuation under load, so that's why I got the fortron. No fluctuation now, but it didn't help me overclock any higher either.
Main Rig
i7 2600k l Asus P8P67 l 2x2gb Gskill l GTS450 l Venomous X l XClio 680
Tested pcp&c 510w , Chieftec 360W and Enermax 550W, all 20pins..
No stability problems..
running 4000+ @ 2700MHz 1.64v and 3.6+vdimm
Please keep them comming. The reason is there has been a post on DFIstreet about running a 20 pin and damage done to memory. I have not seen this and would like to get as much feedback as possible. I am runing a 20 pin 600watt Enermax 36 amps on all rails. very stable and no problems. Have not realy started to heavy OC but running very stable at 2750 MHz.
Asus rampage III
i7 950
Evga 280 gtx
ssd 6Gb/s
Water cooling
heat
Sounds like BS, or some fluke accident.
I run an old Enermax 365 350W PSU (18A@+12V), 20 pin (+ separate 4 pin) just fine. 1.5V CPU, 3.1V RAM.
Opteron 165 CCBWE 0550UPMW@2.5 GHz 1.3 V 1GB / A64 3500+ 512M / A64 3500+ 512M / AXP 2500+@400FSB 1GB / AXP 2500+@400FSB 512M / AXP 1700+@333FSB 256M / AXP 1700+@300FSB 256M / Athlon 1150 384M / Ferrari 3000 AXP 2500+ laptop
Will it does not make that much sence to me other than a cheap 20 pin. I mean my 600 watt Enermax has more amps and power on any line than most if not all 24 pin power supplies do! I would like to use the 5v jumper to use more vdimm but this got me a tad nervous yet I dont know why??
Asus rampage III
i7 950
Evga 280 gtx
ssd 6Gb/s
Water cooling
heat
Not sure about the damage claim...that doesn't sound logical at all.
But, when it comes to stability at the high end, especially with SLI, a quality 24 pin PSU will get you further. That's already been proven countless times.
9900k @ 5.1Ghz
Asus Maximus Hero XI
32GB (8 x 4) Gskill @4000
Strix 2080 Ti OC
OS & Apps: Samsung 970 Pro 512GB
Games: Samsung 970 Pro 1TB
Storage: Crucial M500 2TB
Seasonic Platinum 1000W
Phanteks Evolv X
u dont need an adapter, a 20 pin plugs are backwards compatible with 24pin. I really dont get why the extra 4 pins are so important if one already has a nice powersupply. For ex if someone has a pcpower and cooling 510 deluxe why wouldnt it work even if it didnt have the extra 4 pinsOriginally Posted by sluflyer06
if u plug in all the extra connectors dfi has on the mobo wouldnt that make up for the loss of the 4 pins if the 4 pins are necessary?
Nope. I gained a significant level of stable overclockability when I moved from the PCP&C 510 to the PCP&C 510 SLI. Pretty much the same PSU except for the 4 pins. I picked up not only max CPU OC, but GPU OC as well. I discussed these results with Vivian at DFI and who concurred that a solid 24 pin PSU would yield the best overclocks.Originally Posted by P_1
Now, to qualify this, this was on my rig that had 2 6800U in SLI and an FX55 at 3.3Ghz that topped the ORB in February. So max clean power was key. Systems with less demand can get away with less PSU.
All this aside, DFI themselves STRONGLY recommend the 24 pin PSU. So, although its not a must, users who are maxmizing a high end rig may be leaving performance on the table.
9900k @ 5.1Ghz
Strix 2080 Ti OC
Phanteks Evolv X
Like I said in previous post, I ran 3.4v and 3.5v for over 2weeks 24/7 without any trouble. You have a much better psu than I was using, I would switch that jumper nowOriginally Posted by thesaucier
Main Rig
I have SLI-D and Antec TC550 20pin, no Problem happened ^^
Headshot ! those who can, do, those who can't, complain.
How are you guys powering the PCI-E slots? Directly to the card? My card doesnt have a power connector ... I guess that means I need a 24PIN psu to power it?
~~My Spoon is too Big!!!~~
DFI Lanparty Ultra-D
AMD San Diego 3700+
2x 512mb Mushkin Lvl2 Black! - The original BH-5
2x SATA Raptor (10k RPM) 36 gig HD's in RAID 0
BFG 6600GT
All snug in a Lian-Li PC-7 Case =)
Will this is good to hear and what I suspected as well. How many are running with the 5v jumper?
Asus rampage III
i7 950
Evga 280 gtx
ssd 6Gb/s
Water cooling
heat
See my setup in the sig. Using a 20 pin with the 24 pin adapter. Will be getting a 2nd GT as soon as I can find where to buy a bridge. Guessing I'll have to upgrade my PS when I do, but I'll try to make my SilenX work.
Bloodrage || 920 @ 3.2Ghz || TRUE Black
3x 2GB HyperX 2000 || @ 2000Mhz 7.7.7
2x 300GB WD VR Raid 0 || 2x 2TB Samsung F3 Raid 0
LG 10x BD-R || LG 22x DVD/RW
MSI GE 470 || LG 246WP
Sonar X-Fi || Klipsch 5.1
Lycosa || Mamba || Exact Mat
CM ATCS 840 || Seasonic M12D
Server 2008 R2 x64
Will this is very strange.Seems the post that was warning about using a 20 pin and damage to the memory that was a sticky on the DFIstreet forum was removed?
Not sure why but seems strange. I did ask as several others did to give more detail and we got no further responce plus they pulled the sticky off. So I dont know. The more info here the better however!
Asus rampage III
i7 950
Evga 280 gtx
ssd 6Gb/s
Water cooling
heat
Ok so I had the OCZ 600w coming for my DFI Ultra-D...now was that a bad idea?
System
ASUS Z170-Pro
Skylake i7-6700K @ 4600 Mhz
MSI GTX 1070 Armor OC
32 GB G.Skill Ripjaws V
Samsung 850 EVO (2)
EVGA SuperNOVA 650 G2
Corsair Hydro H90
NZXT S340
There are some solution, a convertial cable, some modding or another 24 pin cheapy PSU just for the vga ^^Originally Posted by GoodOmens
I use my old trusty Antec 480 on the DFI ULRA D
The OCZ PowerStream 600W is a 24-pin PSU. You'll be fine.Originally Posted by Soulburner
http://forums.anandtech.com/messagev...&enterthread=y
Hope that helps =)
Intel Core i7 930 @ 4ghz | Gigabyte X58A-UD5 | 6GB G.Skill Ripjaws DDR3 | Radeon 4850 | Crucial m4 128GB SSD
Intel Core i5-2400 | Asus P8H67-M EVO (Waiting to change to Z68) | 8GB G.Skill Sniper DDR3 | 8x2TB Samsung F4-HD204 | OpenIndiana | ZFS raidz2
Ahh cool...I was under the impression it was a 20-pin but never bothered to look into it.Originally Posted by conrad.maranan
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
It's both: BTX 24-Pin and ATX 20-Pin. The extra 4-Pin cable snaps/slides onto the 20-Pin cable.Technically, it's still a 20-Pin PSU. You should still be fine, though.
