Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 108
Thread: Got 4000+ San Diego , how about Cold Bug?
    Banned
    Jan 2004
    Land of Buckeye
    hi guys, I got this 4000+ San Diego this morning.
    Looks not bad at all.
    After the some test results below, I try to get it under PCICE's cascade.
    Too bad I can 100% confirm that San Diego still got COLD BUG
    and even worse than venice does.
    How, becuase it won't boot below -40 evap reading
    . I did observe
    the temp at it get into windows, it's about -30 evap reading. Higher than that,
    it just locked up and reboot itself.
    Too bad, I don't have single change to try that. so I only do some serious Air cooling.[/color]
    here is the -115c again...
    Default Test:
    CPU itself:
    ** I feel Bachus is right about not to only run the pi 1m, so I run the 3d 05 instead of it.**
    all the default tests:
    some little bit OC actions:
    I am really in bad mood now. so did not get any further, but I will get some water cooling results
    to see how it goes.
    Dec 2004
    Czech Rep.
    That's a real pain. A new cascade and you can't use it. I feel sad for you.
    "Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
    XS News
    Dec 2003
    North Carolina
    Man OPB that sucks.
    RIP Dad. I will miss you always.
    Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    well that sucks...
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    This brings in some REAL dark clouds to the FX57 crowd... I may just go and buy DUMO's FX-55!!!!!!!!!!
    C
    Nov 2002
    North America
    OPB, I can boot at -45 evapo but I have some bugs
    You have the same stepping than me
    2.91GHz benchable stock cooling at 1.55v
    I love XS
    Road to CompTIA A+ (601, 602) and Network+ (N10-003) Certifications
    I want a Penryn 3.33G 12MB & quad sli Nvidia G92
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by charlie
    C
    you right, I am like ..AMD you deserve---->
    But OPB is OPB,
    I got Sik's fx55 here tomorrow. So I now verified that Jedi master's point about " hold your fx55" is the da0n right choice. Absolutely NO WONDER.
    Cpulovecolock, yes!
    it's about that.
    Oct 2002
    Field of Battle
    DUMO,
    YHPM !!
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    OPB that is sad to hear if you try with peltier and wc???? maybe you can OC higher
    Incoming new computer after 5 long years
    YOU want to FIGHT CANCER OR AIDS join us at WCG and help to have a better FUTURE
    Oct 2004
    Athens,Hellas
    that sucks, AMD really needs to solve this
    if this is your first night in xtremesystems,
    you have to overclock.
    Oct 2002
    Field of Battle
    Quote Originally Posted by Onepagebook
    But OPB is OPB,
    Cpulovecolock, yes!
    it's about that.
    yeah, I did say that, didn't I????
    http://www.xtremesystems.org/forums/...ight=guys+hold
    Jan 2004
    Manchester (UK)
    So they dont work that well on Single Phase Change then cpulloverclock.
    I still have no doubt that I wouldnt have a problem with my Venice even with Dry Ice. can go all the way as PC ICE as show. Just need it in my hands
    Banned
    Jan 2004
    Land of Buckeye
    So it never be too late to hunt your fx55 back, but make sure don't get the new one especially after 0515.
    Xtreme X.I.P.
    Dec 2003
    Man... That looks to me like ~$1700 just went down the drain
    I hope I will swallow that the day FX-57 comes out, but I think it won't be cascade benchers first choice anymore
    I'm telling you Kevin, there must be a way to get it to work... Like with my Winnie @ -47C evap. It will NOT boot WHATSOEVER at this temperature.
    I always turn on the cooler and start my system. System does not boot but I let it running, to get hot. Then I turn off the cooler and wait until temp goes -10C on evap. Then I RESET and system boots to Windows. Once I'm there, I turn on the cooler and see how temperature drops to -44C on evap and -23C on CPU. I can do whatever I want at that point.
    Problem is, that in 9 out of 10 cases, when I Restart the system it will not boot up again... BUT! Sometimes it does, when just before I RESTART it, I run just some of "Memtest for Windows" or "Prime95" to get it under load. Then I quickly restart it and it boots
    Try those tricks if you haven't already. Or try to boot at different multis (like me, I can boot @ x10 but not @ x9... It freezes in Windows when I do that). Also, try to boot with divider on your memory...
    Whatever it takes, Kevin
    Oct 2002
    Field of Battle
    I smell a real nice combo:
    VapoChill XE and an FX57!!!!
    Or one of Chilly1 or PCICE's fancy new single stager's!!
    C
    Jan 2004
    Manchester (UK)
    Ive got the same smell coming over here
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by bachus_anonym
    Ya Good idea. BUT think about my cooling is -115c...
  18. #18
    Oct 2002
    Field of Battle
    The ONLY good thing about a cold bug, is that it put's benching back into the old days when everyone had approx the same CPU power, give or take a little from CPU luck...
    For 3DMark racing, it's a leveling factor! EXCEPT that now FX55 130nM/cascade will rule for a while to come!!
  19. #19
    Banned
    Jan 2004
    Land of Buckeye
    You 're right master.
    And now..s7e9h3n said :"Jesus, that would be a very good reason to be pissed. I'll get on the phone with my amd guy in a sec and see what's goin on....."
  20. #20
    Mar 2005
    In that thread above it says to weaken the drive strength.
    did your try that opb?
  21. #21
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by prc8
    I don't quite get it, would you please explain more?
    OPB
  22. #22
    Nov 2002
    North America
    weird, it's doesnt boot at -40C evapo??
    set the vcore at 1.7v and after try again
    I love XS
  23. #23
    Mar 2004
    Oh man that sux. Wonder if the 90nm semprons got a cold bug? Mind trying it out OPB
    Intel FTW!
    Beanna
  24. #24
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by cpulloverclock
    nope..tried it already..
  25. #25
    Nov 2002
    North America
    at 1.4v I have -50 evapo and it boots
    not normal
    I love XS
