Results 1 to 4 of 4
Thread: MSI K8N Neo2 OC advice
    Apr 2005
    Michigan
    Well, here's my specs and my settings. I'm fairly happy with the results, but it seems like other people here are doing much better. Please feel free to offer any advice!
    Board: MSI K8N Neo2
    CPU: A64 3500+
    Memory: XMS-PC3500C2 Rev1.1 (2-3-3-7-1T) --chip--> Winbond BH-5 2x512 in slot 3&4
    Video Card: Ati Radeon 9700 Pro
    HDD: WD Raptor 36Gb on SATA port 1
    Sound Card: Soundblaster Audigy 2
    Power Supply: Antec Truepower 430
    BIOS VERSION = 1.50
    Cell Menu-->
    Memory Submenu --> 200Mhz, 1T, 2, 3, 8, 3
    Cell Menu-> shift+F2 then Alt+F3 -->
    Hiperf = manual
    agp drive = disabled
    speedup = disable
    Dram Strength = normal
    spread-spec = disabled
    HTT = 4x
    Mult = 11x
    FSB = 228
    agp = 67
    vcore = 1.425
    vid = 0%
    vdimm = 2.85
    agp =1.65
    Notes: Increasing the CPU voltage seems to make thing more unstable for me. As far as dropping down the multiplier to 10.5x or 10x, that doesn't allow me to reach as high of CPU MHz at a 1:1 memory ratio, but I can get the FSB up to around 238 (again at a 1:1 memory ratio.)
    Mar 2005
    UK
    First thing, you must use SATA ports 3 & 4 (nearest the CPU socket). This will allow you to reach higher HTTs since ports 3 & 4 are locked, whereas ports 1 & 2 are not!
    Also, memory slots 1 & 2 are usually recommended for overclocking, so i'd switch your memory to those slots (nearest the CPU socket again).
    Then drop your HTT multiplier to 3x and see how far you can raise the HTT, using a low CPU multiplier such as 7x. Remember to use memory dividers if you want to see how far you can get HTT.
    Once you've found your max CPU overclock on stock volts, try upping the Vcore to get more speed out of it. You can then play with further with memory timings / voltages / dividers.
    Your main problem should be due to using the unlocked SATA ports, which can corrupt your data as well as hugely hindering your overclock. Most Neo2 boards can hit 300HTT+ using 1.5 bios.
    My Athlon64 System:
    A64 3200+ (0517 GPBW) - 270x10 @ 1.52v
    Stock HSF - Idle: 33/28 & Load: 48/33
    MSI K8N Neo2 - 0506 Taiwan, 1.B Mod bios
    Patriot 1GB PC3200 - 270mhz @ 2.5-3-3-8 @ 2.70v
    Inno3D 128mb 6200- 500/640mhz (3d'01 - 20.3k & 3d'03 - 7.7k)
    120Gb HDD 7200rpm, 8mb cache
    Colors-IT 550w PSU - 3.3v @ 3.34v / 5v @ 5.02v / 12v @ 11.80v
    Optical: Ltd-166s / NEC-3520A / Ltr-48125w / Px-R820Ti
    My Site - you might even learn something!
    Apr 2005
    Michigan
    Many thanks CD 1986! I'll give it a go as soon as I'm able.
    Oct 2004
    I had stability issues on A64 using 430w truepower, that went away when I changed to a Hiper type-r 480w.
