Page 1 of 8 1234 ... LastLast
Results 1 to 25 of 184
Thread: Test Report: G.SKILL PC4800 FF 1GB 2.5-4-4-8 1T
    Bandwidth Freak
    Dec 2003
    Talking Test Report: G.SKILL PC4800 FF 1GB 2.5-4-4-8 1T
    G.SKILL newest TCCD rated at DDR600 2.5-4-4-8 1T.
    Based on Samsung TCCD memory.
    Testrig
    - Athlon 64 3500+ Clawhammer / Athlon 64 3000+ Winchester
    - DFI nF4 Ultra-D (bios 414-1 Oskar Wu)
    - GeForce 6800 Ultra PCI-E
    - Tagan 480W-U22
    - Vapochill LS
    Stock test
    Doing easy at 2.6v
    DDR600 2.5-3-3-7 1T easy going
    only 2.7V
    Before use this ram, their are some important things to know:
    - Make sure you have a descent memorycontroller and motherboard.
    (DFI NF4 series is recommended)
    - When overclocking, be careful of using high voltages. This one does not like high voltages.
    - 1:1 running to get best performance of this RAM
    - Make sure you use Oskar Wu TCCD optimized BIOS for best stability and performance
    Nov 2003
    Copenhagen, Denmark
    Looks really nice! G-Skill did it again!
    Btw im looking forward to see ur next article
    MSI K8N Neo2 (Korea 0508A2) | A64 3200+ Winnie 0446SPDW @2700MHz 1.60v | A64 X2 3800+ ADBFE 0626DPMW @Still testing - cooled by Big Typhoon| 2x512 Mushkin Extreme L2 @270MHz 2.5-4-3-7 2.5v | Leadtek 6800LE 1.3v@GPU (12x1.6) 450MHz/800MHz | 120Gb Seagate Sata w. NCQ | Chill Innovation 510a PSU made in Denmark! | Lian Li PC7 Plus EU + Additional Lian Li case gear all the way | 19" Hyundai L90D+
    XIP
    Nov 2004
    NYC
    Bios 2.17 working good with my LA. Any newer bios based on 2.17?
    Xtreme Mentor
    Oct 2002
    boston,ma
    Excellent ram, tccd really is some good memory.
    ANy benches to report.
    Abit KN9-SLI
    X2 3800+
    1gb corsair pc5400
    2 evga 7900gt
    200gb maxtor sata
    ocz 520w
    heatware:althes
    ebay althes
    Xtreme X.I.P.
    Dec 2003
    What I would really love to see is at least 500% of "Memtest for Windows" @ DDR600 7-3-3-2.5-1T with those.
    If they pass it without any errors, then I will be absolutely impressed
    Xtreme X.I.P.
    Aug 2004
    Chile
    can you push them further??
    2.7v is low i know that tccd sweet spot is around 2.9v
    Feb 2005
    The Outer Limits
    Hmmm... a 32M Pi run would be interesting too, more so if the CPU was on air. And maybe a run with IdleCycle = 256.
    XS News
    Dec 2003
    North Carolina
    When is this stuff coming to the states.
    RIP Dad. I will miss you always.
    Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
    Mar 2005
    UK
    Quote Originally Posted by bachus_anonym
    Slightly off-topic, but is Windows MemTest a better test of stability than it's DOS-based counter-part? I've been using it to test the memory in my sig (stable at 280mhz, with no errors after 600%), but was thinking of using the DOS memtest...or should i not bother if it passes in windows?
    My Athlon64 System:
    A64 3200+ (0517 GPBW) - 270x10 @ 1.52v
    Stock HSF - Idle: 33/28 & Load: 48/33
    MSI K8N Neo2 - 0506 Taiwan, 1.B Mod bios
    Patriot 1GB PC3200 - 270mhz @ 2.5-3-3-8 @ 2.70v
    Inno3D 128mb 6200- 500/640mhz (3d'01 - 20.3k & 3d'03 - 7.7k)
    120Gb HDD 7200rpm, 8mb cache
    Colors-IT 550w PSU - 3.3v @ 3.34v / 5v @ 5.02v / 12v @ 11.80v
    Optical: Ltd-166s / NEC-3520A / Ltr-48125w / Px-R820Ti
    My Site - you might even learn something!
    Bandwidth Freak
    Dec 2003
    Quote Originally Posted by chunkylover77
    The exact date I dont know. I will ask OPB when this RAM will be released.
    Nov 2004
    Take a look at what it says here:
    As the fine tune process is very complicated and arduous, we only provide 50 sets - G.Skill F1-4800DSU2-1GBFF plus DFI LANParty UT nF4 Ultra-D to worldwide overclockers.
    Jan 2004
    UK
    It's a pity that my G.skill doesn't work as well as that on the DFI NF4 . It needs over 3 volts to be semi stable.
    £58.73 - This is the amount of money a loyal customer is worth to Overclockers.co.uk
    Beware of buying from overclockers.co.uk, they will swindle you by abusing the consumer law if they need to refund you for faulty hardware. Thieving gits
    Xtreme X.I.P.
    Dec 2003
    Quote Originally Posted by CD 1986
    "DOS memtest" in my opinion cannot be trusted at all as far as overall stability goes. Only because memory sticks are "error-free" according to "DOS Memtest" means nothing. It's a good tool to only determine faulty sticks but not "Windows stability". For overall memory stability in Windows enviroment, different tool is needed. That's where "Memtest for Windows" and Prime95 come into action.
    If you can run "Memtest for Windows" for at least 3-6hrs then from my experience you are as stable as it comes
    Sep 2004
    I agree. But drop the multi down to 9 so so the CPU ceiling doesn't come into play. If you can do 2.5-3-3 1T at 300 and run it through 32M SuperPi you'll really kick off the launch of this stuff with a bang.
    Sourcing parts for a mildly over clocked abacus.
    Dec 2004
    The Holy Land
    and that is a good stuff like most of the tccd memory and gskill of course
    Asus P5-E X38 Intel QX9650 INOO3D 9800 Gx2 4x Super Talent's T800UX2GC4
    Creative X-Fi Raid 0 Raptors 36Gb data 1Tb Seasonic M12 700w
    Dell 2407WFP Lian-Li Pc-65 mod Custom Built Phase Change Unit |Logitech G25|
    RIG#2: DFI LANPARTY LT X48-T2R|Q9550| INOO3D 9800GTX|
    2xCellshok 1000| PC Power and cooling 750w Thermaltake v1
    Wife: DFI LANPARTY UT P35-T2R|Q930|BFG 8800GTS 512MB|
    Samsung ddrII 667| PC Power and cooling 610eps12v Thermaltake v1
    Htpc:Dfi Sli-Dr Venus|3700+|2x1gb Team Group ddr500|Thermaltake Mozart TX
    Nov 2004
    Amsterdam, The Netherlands
    Personally I think it's a bit strange that even though TCCD production stopped months ago we're still seeing new chips.
    I bet this is the last TCCD we're going to see though.
    Looks like a happy end.
    Quote Originally Posted by kakaroto
    Which one? 4.14-1, 4.14-3 or a different one?
    Edit: Nevermind... I can see you're using 4.14-1.
    Xtreme X.I.P.
    Aug 2004
    Chile
    Quote Originally Posted by PicaXuu
    Take a look at what it says herehere:
    i dont like this, in this forum are more than 50 people that could use those mems, bad for g.skill should make more of this mems, this looks like the papaer launchs from ati
  18. #18
    Dec 2004
    Picaxuu, what does that mean? Only 50 packages will be manufactured?
  19. #19
    XS News
    Dec 2003
    North Carolina
    I cant imagine that they would go through the trouble of making this ram only to make 50 sticks.
  20. #20
    Feb 2004
    USA, SC
    only 50 sticks? why would they even bother?
    Pc Power and Cooling SILENCER® 750W
    Q6600 (kentsfield) @ 3870
    asus p5k-e
    Gskill 800 @ 1032
    bfg 8800gt
    Creative SB XFI plat
  21. #21
    Nov 2004
    That's exactly what it says but I don't know if it's really true...
    Just strange...
    I'm totally agree with you but...
    Don't really know if it's true or not...
  22. #22
    Feb 2005
    can one of the G.Skill reps comment on this?
    DFI LanParty UT NF4 Ultra-D
    AMD Athlon 64 X2 4200+ | Stock
    OCZ OC3200 EL Platinum Rev. 2 1GB kit | Stock
    OCZ PowerStream 520W
    Thermalright XP-120 heatsink with Panaflo M1A fan
    eVGA 6600GT | Stock
  23. #23
    XS News
    Dec 2003
    North Carolina
    They must be talking about prereleasing sticks to maybe build some hype. I know that Pc Ice used these when he tested the Venice's.
  24. #24
    Feb 2005
    USA
    NICE!! now please put them in the real test and see how high they can do on both 2.5-3-3-7 and 2.5-4-3-7, if these bad boys can do 330 @2.5-4-3-7 1T then I know what I'm going to upgrade next
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
  25. #25
    Nov 2004
    They are only going to release 50 sets. So there will be more G.Skill FF, just without the DFI motherboard.
