I have finish the review of my San Diego 4000+ !
In french, but you can look the screens ...
Also a Translation : http://translate.google.com/translat...language_tools
only 15250 marks with a diego and 6600gt? I get well over 20k with my winny at those clocks, 23.6k at 2GHz on the winny. Looks like aa/af was turned on for that score or pci-e chipset drivers werent installed, its that bad2.78GHz isnt bad for chilled water. Probably 2.65GHz on air cooling but another guy hit 2.72 though. AMD may be speed binning, I say this because even the old 130nm fx55 often hit 2.8GHz or even 2.9GHz on air. It may take a 90nm fx55 to hit near or even 3GHz on air, its known that amd saves the best yields and silcon for the fx chips but compare at $900 for 90nm fx55 at say 3GHz vs. $350 for 3700+ diego at say 2.7GHz. Thats more than 2.5x the price for about 11% more cpu clocks! Nice review and gives us a good idea of the cpus overclockability
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!![]()
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
hot damn!! looking good....hopefully my 3700 SD will do just as well, keep in mind that every single chip clock differently but as far as I can tell the 1MB definitely worth the extra cash over 512KB!!![]()
he was running water cooling not chilled
Originally Posted by Review
15c is chilled, regular water is room temp but the cpu warms it up to like 40c. Id like to see what you get with regular room temp air cooling, please?![]()
Don't you think this is all relative to one's location and what the ambient temperature is? Room temperature varies from one region to another.Originally Posted by Geforce4ti4200
his rad is in an underground well i think![]()
Thanks for your efforts !!!
excellent results, looks like they have alot of potential !
24/7 Work & Play Rig
Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
Geforce,.....
convert Celcius to Farenheit, then get back to us.
Official ORB bottom feeder.
Um im not sure about strikeing down a FX55 CPU just yet![]()
Tba
I think similar results on air would be possible. His temps were only 39c! with 1.5v
Temps would likely be acceptable on air with those volts, maybe mid 50's. Very promising
strange review config didnt mention what ram you used for test ?
3ghz @ 1.46v and 39c looks very promising to me![]()
Looks good so far now the any other chips?? to test
The point is not his score, but the score in comparison to the winny with same settings. Argh, you're irritating.Originally Posted by Geforce4ti4200
Cursed be the ground for our sake. Both thorns and thistles it shall bring forth for us. For out of the ground we are taken for the dust we are and to the dust we shall return
Heat
hmm
though charts look so misleading
it shows the sandiego so far ahead
but really ti's not i mean it is.. but the graph makes it look like it's soooooooooooooo ahead
They're that way so that those used to looking at pretty pictures and then running to the forums saying "OMG SANDIEGO THE R0X0RZ TH3 B7G ON3 !!!"....look closer at the charts to see the REAL difference lol.Originally Posted by lastdon00
Perkam
cannot wait for mine to get in...
i reallllllly hope it works correctly at -100C....
I used to have links here demonstrating how awesome I am, but it's been so long that they're not very relevant (and the pictures have disappeared), so I guess I'll have to get working on new stuff.
FX55=what like 800+ dollars?Originally Posted by Unrealcpu
diago=sub 500 and needs less volts
We still havent seen a diago under phase have we? Either way the FX55 may or may not still be king but the diago is the obvious winner if you don't have unlimited funds.
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
Originally Posted by SPQQKY
thats irrevelent if both are scoring abnormally low, then how would I know if the difference shouldnt be alot greater? 15c is about 60f which is quite a bit cooler than what most of us keep our rooms at, my rooms near 80f
I hate translations.....comes out horribly screwed lol.
Cool I guess? hehe
I hope I can afford a san diego
DFI nf4 Ultra-D 704-2bta BIOS
PREVIOUS SYSTEM
(3200+ Venice LBBLE 0518APFW @ 2.565GHz - Water Cooled by DangerDen TDX
1gb PC3200 PDP SYS XBL Ram @ DDR466 2-3-3-6)
NOW RUNNING/TESTING
Opty 165 CCBWE 0551WPMW @ 2.7GHz (Still in Testing Stage)
Thermaltake 560w PSU
eVGA 6800GT PCI-E 450/1200 - Water Cooled by DangerDen MAZE4
Self-Modded 2-302 heatercore
D4 Pump
Get your facts straight, that 2.72 was a WINCHESTER.Originally Posted by Geforce4ti4200
All along the watchtower the watchmen watch the eternal return.
Reading geforce's post makes my brain hurt![]()
funny i have thick balnket over my window with ac unit on during the day and window open at night keeping it arround 50*f trust it would be more like -10*c with chilled water tops 2*c that is normal water coolingOriginally Posted by Geforce4ti4200
puit cooling with water temp at 10-15°C
I dont think it's a great stepping coz the F is bad but nice ocing
I love XS
Road to CompTIA A+ (601, 602) and Network+ (N10-003) Certifications
I want a Penryn 3.33G 12MB & quad sli Nvidia G92
