Results 1 to 8 of 8
Thread: need BIOS tester for Leadtek 6200
    Jul 2004
    France
    Leadtek 6200 with 6600 BIOS better ???
    here is my result with one BIOS of original 6200TD (Leadtek)
    and with one of 6600TD (Leadtek to)
    6200 with 6200 BIOS :
    6200 with 6600 BIOS :
    anyone can test theses two BIOS and report his result pleas.
    i would know if it same with all Leadtek 6200 ,beacause Ebola have try and the results are same betwen two BIOS :
    BIOS links :
    6200 BIOS Origina (temperature moded)
    6600 BIOS Original (temperature moded)
    the command line to bypass the not maching is :
    nvflash -4 -5 -6 6600_new_tem.rom
    I am not responsible for the which can damage to be caused by the flashage BIOS
    thanks.
    sorry for my bad english
    French Overclockers roxxxxxx
    OCM Team addict
    Jan 2005
    I'm curious about something... would you mind trying something for me?
    After using the 6600 flashed bios, change your GPU ID to 6200 (in rivatuner) and see what kind of scores you get. I'd like to know if your score improvements are the result of the flash or of the drivers being optimized for more pipes/faster clocks.
    I changed my ID from 6200 to 6600GT in rivatuner and I found an increase in performance without doing anything else. Please let us know!
    DFI nF4 Ultra-D
    1 GB of OCZ PC3700EL Platinum TCCD
    AMD 3500+ Clawhammer (XP-120)
    eVGA 6200 -> 6600 softmod
    Jul 2004
    France
    Quote Originally Posted by Ackbar
    unknown device
    i'll try later
    OCM Team addict
    Feb 2005
    Southern California
    use the arrows to change.
    Xtreme X.I.P.
    Aug 2002
    Gt1 gets over 10% increase whereas the more gpu intensive GT2, GT3 and GT4 get 5% or less.
    I think this would suggest that the 6600BIOS might have better video card RAM timings ????
    Any thoughts?
    Regards
    Andy
    Jul 2004
    France
    Quote Originally Posted by zakelwe
    Any thoughts?
    Regards
    Andy
    isn't only timing ,i've try with the 6200 BIOS and 6600 timing ,and not better ,or just few
    (with NiBiTorv21)
    Quote Originally Posted by fatfreepork
    i'v alredy tryed it ,but i didn't find it in list
    the 6200 ID is 014F ...
    OCM Team addict
    Jan 2005
    Quote Originally Posted by overcrash86
    (with NiBiTorv21)
    What RivaTuner version are you using? Also, I read another thread where someone went through the 6200, 6600, and 6600GT bioses and found that the 6200 and 6600 have the same timings.
    DFI nF4 Ultra-D
    Jul 2004
    France
    i use riva tuner v2.0 RC 15.4
    with unknow device in riva tuner windows have 6200 detected ,then :
    just with 6600 BIOS and 6200 ID ;thats odd
    i'll try with 6200 BIOS and 6600 ID
    OCM Team addict
