Page 1 of 3 123 LastLast
Results 1 to 25 of 56
Thread: How many power connectors do You use on Your DFI NF4 ???
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Exclamation How many power connectors do You use on Your DFI NF4 ???
    I'm still confused about it - myself only using the ATX and the 4pin 12V but many people say it's better to connect the floppy/HDD-like also.
    But what is the benefit at all? So let's see how You all handle it.
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Feb 2004
    Montreal
    1 20 pins psu (should be 24, but you know what i mean!)
    1 floppy type connector near the pcie connectors. Im guessing this helps when running SLI configs, which i am.
    1 molex type connector near the ide driver. General power throughout the board
    1 4pins connector near the 20-24pins psu connector. This is usually a cpu dedicated line.
    That is it for me, and that all of them afaik
    Mar 2004
    Isnt those requierd when you run SLI only? I don't use them at all. I do like you ATX + 4pin.
    Intel FTW!
    Beanna
    Jan 2005
    AMD factory
    Quote Originally Posted by NiCKE^
    This is exactly the question I have - nobody told for sure before. I also think so because I have a very nice stability of all voltages without using the HDD/floppy-like connectors.
    Previous system:
    I am Xtreme
    Dec 2003
    Talking plug em if ya got em...
    might as well give the board as much as you can. (I do)
    Xtreme Mentor
    Jun 2002
    all 4
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
    Jan 2005
    NJ
    I use all of them, but when i do a wiring job, Ill take the PCIE one off, because its ugly
    CPU Z:2700 2k1:27952 2k3:12282 2k5:5763 PCM05 AQ3
    Opteron 165 s939_____OCZ RAM/PSU_____BBATI X800xl
    Jan 2005
    AMD factory
    HAHA - now here just happens what I thought before - nobody knows it for sure, some use all 4 and some do not.
    Isn't there anybody offical out there from DFI ? I think it's important to know why this board has the 2 extra connections.
    Previous system:
    Dec 2004
    1) 24 pin ATX plug
    2) 4 pin plug next to it.
    Thats about it . Might try plugging in a molex connector and seeing if it helps my overclock any .
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by HARDCORECLOCKER
    huh there's only one extra near chipset heatsink for 2nd PCI-E card
    i use all of them
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    I would use all of them if I had the board. Why would you want to steal power from the cpu or other components? If they are there, use them.
    For those of you about to post:
    I am Xtreme
    Dec 2003
    Talking Ya forgot the plug for the FLOPPY POWER!!!!
    Quote Originally Posted by eva2000
    i use all of them
    Look right next to your block (white plug to left above inductor in piccie )
    Mar 2004
    Hmz that might be why my motherboard undervolted on the vcore, might the molex is needed
    Intel FTW!
    Beanna
    Feb 2005
    On a celestial body that revolves around a fusion ball of Hydrogen
    I use all four-power connector’s!
    Official Statement from “Angry Games” at “DFI street ” Regarding Power connector’s!
    Important Info (critical!) - updated 4/12/2005 (post #13 & #19)
    Quote: from post #13
    “If you use some high performance memories, the loading will be increased automatically. Power delivery might be insufficient, chipset fan and CPU fan might not work. For stability and safety, an external power delivery is required at this time; please connect the 5V/12V power connector on-board (4-pin molex + 4-pin floppy connector). Power delivery will be sufficient. Further more, to ensure sufficient power could be provided; we highly recommend using a minimum 480 Watt power supply unit”.
    http://www.dfi-street.com/forum/showthread.php?t=1541
    ASUS A7N8X Deluxe Rev II ~ Barton 2500 AQXEA0323 @ 2420MHZ
    2x512MB Corsair 3200LLPT BH-5 ~ BFG AGP 6800GT OC
    2x80GB Seagate SATA in RAID 0 ~ SB Live Plat 5.1 ~ Live Drive
    Princeton LCD19D ~ Enermax EG651P-VE FMA ~ Enermax EG465P-VE(D)
    DD M4 ~ M4 A ~ BIX II ~ Eheim 1260
    DFI NForce4 SLI-DR ~ Winnie 3200 CBBHD 0449 MPM @ 2700MHZ
    2x512MB G.Skill 4800LA ~ 2xBFG 8800GTX
    2x74 GB Raptors in RAID 0 ~ Audigy II ZS
    ViewSonic VP201s ~ PCP&C 510 SLI ~ Enermax EG465P-VE FMA
    DD TDX ~ 2xM4 A ~ Weapon ~ Iwaki MD20
    Jun 2004
    The Baltics
    Have used all 4, just 3 (without the floppy) and just 2 (the main + P4). Have not noticed any difference at all (but I'm not running SLI).
    away & gone
    Mar 2004
    New York
    I use all four.. didnt try with any less because I figured if they are there plug em in..
    May 2004
    I have all of them apart from the FDD connector. Dont have any spare FDD connector that can reach the plug on the mobo.
  18. #18
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by mad mikee
    doh didn't see that i thought that was regular fan header lol :o
  19. #19
    Aug 2004
    Sydney, AUSTRALIA
    I use all of them
    MoBo: DFI Ultra D R.A01
    BIOS: 18/6 -3
    CPU: AMD 64 3000+ (0435) Winchester
    RAM:2*512 Corsair XMS 3200C2 rev 4.3 TCCD - Brainpower PCB
    GFX: Xpertvision 6600GT
    PSU: Tagan 550W ATX 2.0
    HS/F: Water cooling
    HDD: WD 200G SATA, WD 120G 8MB PATA, Seagate 40G 2mb PATA
    OC: Ram> 270Mhz 2.5 3 3 7 2.8V 1:1ratio
    OC: CPU> 9*270 2430Mhz 1.5v
  20. #20
    Dec 2004
    Czech Rep.
    I'm using them all.
    "Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
  21. #21
    Mar 2004
    I will be using ATX, 12v and the Molex when I get my winnie back.
    Intel FTW!
    Beanna
  22. #22
    Xtreme Recruit
    Mar 2005
    I wasn't using them all [just the original 24-pin and 4-pin] at first, but then I finally wanted to see what the big deal was.
    I was running at 2520MHz [280x9] and wouldn't budge, but when I plugged em in I was able to go to 2.7 [300x9]. Unfortunately it wasn't bench stable, only Windows / Screenshot / Daily BS stable.
    So yeah, definately plug them in! Worked for me
    AMD64 3000+ Winchester [0449 MPM]
    Thermalright XP-90 w/ Panaflo 92MM
    DFI LanParty Ultra-D nF4
    Patriot 1GB[512x2] PC3200 XBL
    ATI X800XL PCIe 256MB w/ VF-700Cu
    Antec NeoPower 480W
  23. #23
    Jan 2005
    AMD factory
    Quote Originally Posted by magg
    Hm........., maybe I should give it a try !
    Previous system:
  24. #24
    Oct 2003
    Terra
    Only ATX 24-pin and 4-pin ( no sli here )
    But i gonna plug in the other ones , maybe i get lucky to
    CPU : Intel Core 2 Extreme QX9650
    MB : Asus P5E X38 Rampage bios
    RAM : Team Xtreem 4x1GB DDR2 OPB handpicked
    VGA : Sapphire 4870
    Power : Antec Quattro 850w
    Storage : 1 x 60GB OCZ Vertex + 2 x 750gb WD 32Mb
    DVD : Samsungs DVDwriter Sata + Liteon DVD
    Sound : Creative XFI Xtrememusic
    Cooling : D-Tek Fusion + D-Tek Fusion GFX
    Monitor : Samsung 226BW
    Errorcode : An error occurred at address AC 20 DE AE FF BC ...... System halted.
  25. #25
    XS News
    Jul 2004
    Using em all here....
    AMD Athlon 64 3700+ @ 300x10________15" Macbook Pro
    2x 512mb Mushkin DDR _______________2x 1Gb DDR2
    Sapphire X850XT____________________X1600M
    DFI Ultra-D_________________________2.16Ghz Merom C2D
    Lian-Li PC7A________________________OS X/XP
    PCP&C 610w Silencer
