ASUSTeK [ P5WD2 Premium ] 955X sells Retail edition Review
ASUS this P5WD2 the Premium MB needed materials and the design are quite splendid, today discovers this main engine board the author after ASUS and the PM thorough understanding The specification and needed materials unexpectedly specialness, indicates ASUS regarding this 955X chip group main engine board hoping! ! Back I just for each illustration this main engine board specially place! ! !
P5WD2 the Premium feature article chart
first comes the main engine board all according to the chart
The model is P5WD2 Premium, the edition is 1.02 edition
The P5WD2 Premium I/O output, this time partial increased much in BACK IO quite special, e-SATA outside meets
The VRM power unit, ASUSTeK has intimately made the radiator fin design
in EATX the 12V partial uses, supports 4Pin and the 8Pin intimate design
south the bridge partial outputs port uses Intel ICH7R+ ITE 8211F IDE to supports six group of PATA and four group of SATA II design
The expansion slot aspect, supports PCI Express16X*2, PCI Express1X*1, PCI*3
other ASUS specially emphasized P5WD2 Premium second group of PCIe the x16 slot especially pulls out four PCIe channel from the south bridge, may support highest 2GB/s the transmission speed.
Supports Intel LGA775 Pentium 4 CPU series CPU, contains Dual-Core CPU which soon promotes
LGA (LAN Grid Array) 775 Socket
The Texas Instruments (Texas Instruments) TSB43AB the FireWire chip, supports the IEEE1394a two groups
The Intel new network chip (82573V) is uses for to substitute for the PHY design, supports 10/100/1000 design
besides Intel network chip, moreover a group is Marvell 88E8001 the Gigabit network chip
but (outside SATA meets) above northern bridge support SATA ON The Go the chip is, SLICONIMAGE 3,132 supports of Serial ATA II
the sound effect uses Realtek sound effect chip ALC882D to support 7.1 High Definition (HD) the sound design
Winbond hardware monitoring chip (W83627EHG-A)
discovered a PI2PCIE chip, understands the person knew this chip acts what kind of role............ Time also not to therefore does not have heh heh hey.............
P5WD2 in the Premium this main engine board, the capacitance section has used the entire date is an electric capacity The date is the electric capacity
this Mainboard extremely special place lay in Stack Cool2 is the whole piece Mainboard (represents radiation potency to be better), but was not is restricted in nearby Stack Cool1 CPU
Digital-info
- You may not post replies
- You may not edit your posts
Forum Rules
