Results 1 to 9 of 9
Thread: DFI NF4 vcore and possible vdimm mods
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    Saaya requested vcore mod for this board. So, here it is. Also, that could be vdimm mod, but I was told this board doesn't need it. But if someone is interested in using the 3.3v rail, instead of the 5v rail, for vdimm, here is the possible mod. If someone tries it, please report back with results for vdimm.
    Vcore: 50k trimmer via pin 10 of ISL6559CB to ground (pin 15). Lower resistance for more vcore.
    Vdimm: 50k trimmer via pin 6 of LM358 to ground (pin 4). Lower resistance for more vdimm.
    For vdimm, try soldering the trimmer and check to see if it works. If it doesn't then get back to me and i'll give you other ideas to try. You can use other grounds instead of pin 4, since it looks like it's a lil tight there.
    As usual, do it at your own risk.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    thx buddy!
    Jun 2004
    Oregon
    nice work on the vcore malves, i doubt the vDimm is going to work though, its gonna be more complicated than just soldering to the pins on that IC.
    -CaT
    Send Me Your Broken Hardware! - Repair Parts and vMod Research!
    Need vMods? PM Me!
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    Quote Originally Posted by CaTalyst.X
    -CaT
    I guess this board really doesn't need vdimm. So, there's no need to take the risk.
    Jun 2004
    USA, Vermont
    What about a smoothing circuit for Vdiim and cpu...like some caps and a diode bridge...and maybe a circuit with an LCD/DIMM and better Vdimm and cpu voltage adjustment so that it is very fine that you can set...so through the refining circuit to set the volts then the smoothing voltage then have the LCD display the voltage then tot he CPU...just somethoughts maybe i will work on this at school...
    Dragon
    http://smbach.com/mad.gif
    Opty 175 Rig
    Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
    AM3 Rig
    Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
    DFI NF4 BIOS Guide
    Xtreme X.I.P.
    Nov 2002
    Shipai
    -CaT
    why do you think so?
    Nov 2002
    North America
    this mod can directly kill a dfi?
    I love XS
    Road to CompTIA A+ (601, 602) and Network+ (N10-003) Certifications
    I want a Penryn 3.33G 12MB & quad sli Nvidia G92
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    Quote Originally Posted by cpulloverclock
    Which one?
    Nov 2002
    North America
    Quote Originally Posted by Malves
    Which one?
    vdimm
    if it doesnt work... there will be just a black screen, always the same voltage or regulator dead
    I believe dfi nf4 have a vdimm protection around 4.15v
    I love XS
