Results 1 to 25 of 25
Thread: X850 PRO VIVO ---> X850 XT PE mod possible?
    Feb 2005
    Well I have never owned an ATi card in my life but now I may have to get an X850PRO instead of my planned 6800 ultra in order to have enough funds to complete my new venice rig.
    Anyways is this possible? I see on newegg that the X850pro has only 12 pipelines, is there a mod to get it to x850 xt or xt pe spec? And excuse the nubness in advance. I have already searched for this but haven't come up with anything.
    Live Long And Overclock
    Sep 2004
    Nope just as X800PRO PCI-E cant be flashed to XT, neither can this, srry.
    Perkam
    Feb 2005
    Quote Originally Posted by perkam
    Perkam
    Wut? Says right here on this guide that the x800pro VIVO PCI-E to x800 xt pe BIOS flash can be done: link
    It will only work on the X800 Pro VIVO. Manufacturer does not matter. It will not work on the X800 Pro (without VIVO). The modified flashrom has been updated on Jan 03 2005 to support both AGP and PCI-Express X800 Pro VIVO cards. The mod is the same, just get a X800 XT PE PCI-E BIOS when flashing a PCI-E card.
    "I eat motherboards"
    Dec 2004
    Topeka, KS
    Now, they physically cut the traces on the chip to make it nearly impossible to softmod or hardmod
    Xtreme Legend
    Dec 2004
    Sweden
    Perkam
    Have worked for me with 2 different PCIex ASUS X800Pro ViVo card, no laser cut and the flash succesfully unlocks all 16 pipes. One of the cards wouldn't do more than 520MHz core (stock 1.39V), the other would do 588MHz on stock vpgu (1.43V).
    Feb 2005
    Ok so what about the X850 pro? Any info?
    Xtreme Legend
    Dec 2004
    Sweden
    X850 Pro i no go
    Apr 2005
    Maybe the first batch of X850pro are not laser cut...
    i7 4770 | 24GB | Z87 Mpower | 1070FE | 512GB/1TB/2TB | WiNDy FC500 | 2713hm | 2.0 | 650w
    May 2004
    Perth, Western Australia
    x800p is better neway, if only you can find one
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
    Feb 2005
    Palm Beach, FL
    Yeah, you will probably have a higher likelihood of successful Pro->XT/XT-PE flash with an X800Pro VIVO rather than with a X850Pro
    CPU AMD Athlon64 Venice 3000+ @ 2.7GHz
    MTB DFI Lanparty nF4 UT @ 300MHz/900HTT
    RAM 1x512MB Corsair TwinX PC4400 @ DDR600
    HDD 2x36GB WD Raptor R-1 // 3x80GB WD S.E.
    VPU ATi Radeon X850XT Platinum Edition @ 602/618
    DVD NEC 3520A 16x DVD-RW
    PSU OCZ PowerStream 520w
    AUD Creative Audigy II
    NFO 9x300 ]|[ 1.55vCore - 2.9vDIMM ]|[ 2.5-4-3-7 ]|[ 1:1 1T
    3DM 01: 30208 03: 14449 05: 6918
    Rig revision in da workz: Opty 148, 1GB PC5000(Need 2GB but none are fast enough.), Another X850 to go crossfire, and W/C from the den.
    Xtreme Team D²OL
    Nov 2003
    Melbourne
    Hate to say this but it's near impossible to unlock the extra pipelines on the X850Pro VIVO as I'm sure ATI would've learned their lesson from the X800Pro VIVO cards as well as the 9800/9700 series cards before it...
    Plus, there's way too many models now to fill in the gaps...
    I would recommend just getting the X850XT non-VIVO as they're pretty cheap compared the the X850XT VIVO/PE models...
    Think about the line-up...
    X800
    X800XL - well, those 2 cards are not the same as the others but anyways..
    X850Pro??
    X850Pro VIVO
    X850XT
    X850XT VIVO
    X850XT PE...
    There's only a small percentage that are "bios" locked whereas the majority of them are either laser vut or disabled in the core so it would be near impossible to mod them to 16 pipes...
    Plus the fact that the X800/X850 cores have matured a lot since the introduction of the X800 might mean that there's less "left-overs" now..
    Just my 2 cents...
    Cheers,
    Minh
    Mine:3770k @ 4.6Ghz @1.25v, Corsair H80, Asus SabreTooth Z77, 4 x 4GB Corsair Vengeance 1600C8, XFX 7870DD, Corsair HX850w, Sandisk 240GB Extreme SSD, Corsair Graphite 600T
    Kids: 2500k @ 4.6Ghz @1.368v, TRUE120, 2 x 4Gb Corsair Vengeance 1600C9, Gigabyte Z68X-UD4-B3, Gigabyte HD6870, Sandisk 240GB Extreme SSD, 850w Thermaltake 850w PSU, Antec P182 Case
    Kids2: i3 3225, 2 x 4Gb Kingston HyperX 1600C9, ASUS P8Z68-M PRO, Sapphire HD4870 1GB, 128GB Samsung 830 SSD
    Server: Core2Quad 9450, 2 x 2Gb Kingston HyperX 1066, 2 x 2Gb Corsair XMS1066, Gigabyte EP45-DS5, Corsair HX650w, OCZ 120GB Vertex 2E SSD, WD 1TB Black, 2TB Seagate 5900rpm, 2TB Seagate 7200rpm
    Apr 2005
    I think the late batches of X800pro VIVO are laser cut, so one will have a lesser chance of unlocking to full 16.
    Jun 2002
    Austria, Europe
    Did someone have success in unlocking the 4 pipes on a X800Pro VIVO PCI-E ?
    AMD Phenom II 940 black edition, DFI LP DK790FXB-M2RSH @ 240 x 15.5 | 4GB OCZ Platinum CL4 | NexXxos X² Highflow | 2x Eheim 1048 | Enermax EG701 | 2x WD3200AAKS Raid 0 | HD4870 watercooled | Win7 64bit
    silver wall jumper X
    Apr 2005
    Las Vegas
    I tried on 3 different X800 PRO VIVOs - all were lasercut - another big thing is that most of the PCI-E X800 PRO Vivos have 2.0ns memory not 1.6ns ( all 3 that I had were 2.0ns)
    Jun 2002
    Austria, Europe
    hmm...that's bad news.
    thx anyway!
    May 2005
    Dubai,UAE
    i found Club3D X850 Pro Agp slot..the i searched online about it ,, and i found almost nothing but this small info.
    core = 507
    mem = 520
    Linky
    anything about it?
    although Agp perform Better than PCI?
    Check Here
    Feb 2004
    I had 3 x800pro and they can't be modded. I tried flashing, filling lasor cut and whatever but it just won't unlock 4 extra line. I belive x850 pro is the same but you can try it and let us know
    Mobo: MSI P35 platinum
    CPU:e8400
    Mem: 4x512mb Patriot fatbody
    Vid Card: 8800gts 512mb
    Cooling: Thermalright 120 ultra
    HD's: 80x2 raid and 320gb
    Case: cooler master cm690
  18. #18
    Sep 2004
    Only improvement of the X850pro over the X800pro is a core that is practically guaranteed to go higher...and because none of the top X850XTs have 2.0ns ram...none of the X850PROs do either (afaik) so 1.6ns ram is another plus.
    All in all, means you're paying for higher clocks. But ofcourse, the XL at 16 pipes is hefty competition, though I dont like low core OCs...If I'm spending ~$350 on a card, me wants 580/580 at least
    Perkam
  19. #19
    May 2005
    Dubai,UAE
    whats the deffrence between 2.0ns ram and 1.6ns ram ?
  20. #20
    Feb 2005
    MANCHESTER - UK
    Quote Originally Posted by SNIPoR
    2.0ns ram is rated at 1000mhz and can be overclocked upto 1100->1150
    1.6ns ram is rated at 1200mhz and can be overclocked to 1300 or over.
  21. #21
    Sep 2004
    Quote Originally Posted by -=PRA3TOR=-
    Yup, goes something like:
    2.0ns___1000Mhz (so its not really an overclock unless its over 500Mhz )
    1.6ns___1200Mhz Effective (600 Mem)
    1.4ns___1400Mhz Effective (700 Mem) (Thought currently to be R520 spec)
    1.2ns___1600Mhz Effective (800 Mem) (Currently only reacheable with Phase Change)
    Other than that, there is XDR ram which runs quite fast too, but not much is known of its implemenation.
    Perkam
  22. #22
    Feb 2004
    this sux, the newer cards are getting harder and harder to mod.
    CPU:e8400
  23. #23
    May 2005
    Dubai,UAE
    whats (Phase Change)? any linky or pic ?
  24. #24
    Mar 2005
    expensive
    the simple answer is ripping the guts out of a freezer and cooling a chip to sub zero, there is a longer more accurate answer, but i am lazy and ignorant, try surfing the cooling section.
    Microsoft's homepage can be found at: thesource-dot-ofallevil-dot-com - interesting, no?
    Think of something witty and imagine it here.
  25. #25
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    It's -100C for continuous use. LN2 for -196C for short term use.
    For those of you about to post:
