First of all I have stability problems overclocked when it's enabled it seems. Took me awhile to come to this conclusion. I thought it was cooling so I've been playing with higher CFM fans, open case, and everything other setting imaginable. What exactly is bank interleaving and why does disabling it make my 2.7 GHZ overclock suddenly stable? Disabling seems to let me go farther.
However in the bios when I disable it, save changes and go back it will show that it's enabled again. I think part of my issue and the reason why stability is so spotty is because I will disable it run a bunch of tests to confirm stability then go back into the bios to make other changes at which point the board is re-enabling it on it's own - then I have problems so I back it down to still have issues (which is why this is so frustrating). Till now I wasn't paying attention to the setting when I went back into the bios. However I think this is the setting that I've been looking for!
If anyone can confirm that they see it auto enabling upon re-entering the bios or having stability issues that are resolved once it's disabled - please let me know. Thanks!!
Dean
