Hello,
Just started testing my new fx55 0508 under my 3 stager
3600Mhz 3d mark 01 stable on only 1,88v is dam nice
http://service.futuremark.com/compare?2k1=8529082
wil test more later to day.
Hello,
Regards
Overklokk
First in world over 90k in 3D Mark 03 with 90400p
http://service.futuremark.com/compare?2k3=5160409
Sems very promisingOriginally Posted by Overklokk
So we will see some high 3dmark scores soon?![]()
AMD 3500+, Geforce 6800LE@16/6 1.42v 459/955
Geforce 6800LE power!
#2 in 3mark01 29.3k #3 3dmark03 13654p 5626p 3dmark05
Nice lobbys![]()
What nice chip you have therecan you run all tests @ 3600mhz?
yes i run all test @ 3600mhz but witout multiprosessor..... lets hope it can do 3600 with multi tweakOriginally Posted by Pedro Rocha
Regards
Overklokk
That poor X300 video card, I can smell it sweating from here.
Looks like AMD is really fine tuning FX-55 now on 130nm, wonder what it will be like on 90nm ?
FX-57 looks like it will be a killer chip when it arrives.
Good luck
Regards
Andy
even the 4000+ will be HOT, probably 12 x 310 3D stable on cascade!!!Originally Posted by zakelwe
C
Second to get a 4ghz screenshot ?
Blue Dolphin Reviews & Guides
Blue Reviews:
Gigabyte G-Power PRO CPU cooler
Vantec Nexstar 3.5" external HDD enclosure
Gigabyte Poseidon 310 case
Blue Guides:
Fixing a GFX BIOS checksum yourself
98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
Now this is the kind of thread I like to see!Good to see another new chip clocking good.
But you're Car High is about 150fps low![]()
6654 is the record for the lowest 3.6GHz score ever![]()
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!![]()
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
I hawe tested some more and it looks good. With the X200se card i can run 01 @ 3600 even with multi tweak
But i tested my x850xt and then i only can do 3560 mhz... think i need a better PSU
with w2k sp4 and the only tweak i hawe done is multi prosesssor i godt this:
This is with X850 @ stock![]()
Regards
Overklokk
OK>
can you please finish all the 2k1 tests so we can see a final score wiht the x850 stock "please"
ricky and perdo never got a chance too themselves
thanks and awosme cpu clocks atm![]()
I wil give it a try tomorrow. And se if i can get a better PSUOriginally Posted by sandybeach
Regards
Overklokk
nice one![]()
cpu:qx9650@4ghz
ram: gskill pc8000qt 4*2gb
MB GB X48-DQ6
Gfx 9800gx2
Disk:2*1tb raid0
Nice!
I wouldn't like to be that poor X300SE![]()
I understand you dont wanna rush it, but you know how crazy things get when benching... i dont wanna jinx it but make the most of what you can!
Give er' hell man....![]()
dont forget to video tape the hellish sceneOriginally Posted by k|ngp|n
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
Wonder whether it will be Opp, Redro/Ricky or Overklokk to get to 44k first, all have 3600Mhz cpu's but at present only Opp has video card working well also ( but is testing Sli it would seem ).
Not too hard to get a better PSU for Overklokk though, should be interesting.
k|ngp|n, you going to be getting one of these late dated uber FX-55's ?
Regards
Andy
Looking good KEB. Can't wait to see some serious benches from you againOriginally Posted by Overklokk
I wil get a new Asus X800XT from MPX.no today so i wil try it under my GPU cascade as soon as possible![]()
Regards
Overklokk
Too busy w/work and no decent cooling atm. My cascade has been at chilly's getting a 3 stage/2head/sli re-workOriginally Posted by zakelwe
. I should have it back just in time for the diegos. There is a DFI nf4/ mushkinlv2 bh5 1gig kit that can bench stable up to 279 1:1 tight as nails, just sitting on my shelf collecting dust. I have yet to do any serious 3d benching with the dfi/1gig. I cant wait to bench it with a good chip tho....speaking of the new chips.... I had a chance to grab a new 0509 fx55 yesterday for CHEAP, as well as another two weeks prior, but I turned them down. It was very hard to do seeing the results these guys are getting, believe me
'FX-55' and 'Cheap' in the same sentance? NeverI had a chance to grab a new 0509 fx55 yesterday for CHEAP![]()
Any news on the PSU front?
Lookin very good Overklok, I think you have a very nice cascade![]()
I would love to try some -100 on my week 509 FX
