MSI P4N Diamond uses Intel the P4 platform, origination Digital Switch transformation the SLI model design, matches outstanding hardware CREATIVE SB Live! 24bit 7.1 sound tracks designs !
This is not the market sale edition, therefore use yellow PCB layout, looked here has "SAMPLE" the character, the market sale edition uses black PCB, similar K8N Diamond.
mother board a full view:
Socket T (LGA775) supports newest double core Pentium D 8x0 series CPU
PWM power source supply part:
Uses the most high-grade 4 phases design!
Nearby the CPU capacity also uses the most high-grade the OS-CON capacity, total outputs achieved 150W the superelevation power (present highest class's CPU TPD only has 120W)
DDR II memory part:4 DIMM, supports the overclock to the DDR II 900 specifications
C19 north bridge chip looked:
MCP04 south bridge chip looked:
The SLi series transmission surface:
Most is worth as soon as raising is this:
The over surmounting M/B industrial technology, Use by 12pcs PI2PCIE IC electronic model Switch SLI (Digital SLi Switch)!
The support S-ATA II storage surface and S-ATA II RAID 0,1,0+1,5.
But outside use Silicon 3,124 IC have 2 s-ata II, total connects 6 s-ata II installment.
Inset Marvell 88E1111 and the 88E8053 double network chips, coordinates which the MCP04 south bridge chip composes (Active Armor) the hardware network firewall is very safety!
Sound surface:
Use CA0106-DAT IC's hardware CREATIVE SB Live! 24bit 7.1 sound tracks designs
Power source :
Use 24-pin EPS connection M/B , and support 4 IDE ATA133 channel 1 FDD device.
Back output surface:
SPDF & Digital fiber sound output and IEEE1394 ,USB 2.0
Test to be continue.......
